查看: 1376|回复: 4
出个机-Server-Factory Anniversary 2023 VPS
发表于 2023-8-3 12:22:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
AMD RYZEN™ Anniversary 2023 VPS
DATACENTER: Serverius Data Center 1, De Linge 26, 8253PJ Dronten, The Netherlands
CPU:A MD RYZEN™ 9 5950X
BASE CLOCK: 3.4 GHZ
BOOST CLOCK: UP TO 4.9 GHZ
CORES:2 (fair usage)
RAM: 4 GiB DDR4 2666 MHZ ECC
STORAGE: 100 GiB NVME PCIe 4.0 SSD
SNAPSHOTS:1
UPLINK: 1 GBIT
INCOMING TRAFFIC: UNMETERED
OUTGOING TRAFFIC: 8 TiB
IPv4 ADDRESS: 1
IPV6 SUBNET: /64
FEATURE: RDNS MANAGEMENT
FEATURE: UPLOAD OWN ISO
48 € / year
Expiry Date:30.03.2024
这玩意有人要不
  1. Basic System Information:
  3. Uptime     : 0 days, 0 hours, 2 minutes
  4. Processor  : AMD Ryzen 9 5950X 16-Core Processor
  5. CPU cores  : 2 [url=home.php?mod=space&uid=175]@[/url] 3393.624 MHz
  6. AES-NI     : ✔ Enabled
  7. VM-x/AMD-V : ✔ Enabled
  8. RAM        : 3.8 GiB
  9. Swap       : 0.0 KiB
  10. Disk       : 98.3 GiB
  11. Distro     : Debian GNU/Linux 11 (bullseye)
  12. Kernel     : 5.10.0-23-amd64
  13. VM Type    : KVM
  14. IPv4/IPv6  : ✔ Online / ✔ Online
  15. IPv6 Network Information:
  16. ---------------------------------
  17. ISP        : Serverius Holding B.V.
  18. ASN        : AS211895 Serverius Holding B.V.
  19. Location   : Dronten, Flevoland (FL)
  20. Country    : Netherlands
  21. fio Disk Speed Tests (Mixed R/W 50/50):
  23. Block Size | 4k            (IOPS) | 64k           (IOPS)
  24.   ------   | ---            ----  | ----           ----
  25. Read       | 247.44 MB/s  (61.8k) | 4.63 GB/s    (72.4k)
  26. Write      | 248.09 MB/s  (62.0k) | 4.66 GB/s    (72.8k)
  27. Total      | 495.54 MB/s (123.8k) | 9.30 GB/s   (145.3k)
  28.            |                      |
  29. Block Size | 512k          (IOPS) | 1m            (IOPS)
  30.   ------   | ---            ----  | ----           ----
  31. Read       | 3.95 GB/s     (7.7k) | 4.10 GB/s     (4.0k)
  32. Write      | 4.16 GB/s     (8.1k) | 4.37 GB/s     (4.2k)
  33. Total      | 8.12 GB/s    (15.8k) | 8.47 GB/s     (8.2k)
  34. iperf3 Network Speed Tests (IPv4):
  35. ---------------------------------
  36. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  37. -----           | -----                     | ----            | ----            | ----
  38. Clouvider       | London, UK (10G)          | 1.04 Gbits/sec  | 1000 Mbits/sec  | 6.83 ms
  39. Scaleway        | Paris, FR (10G)           | 1.04 Gbits/sec  | 999 Mbits/sec   | 11.2 ms
  40. NovoServe       | North Holland, NL (40G)   | busy            | busy            | 9.08 ms
  41. Uztelecom       | Tashkent, UZ (10G)        | 893 Mbits/sec   | 900 Mbits/sec   | 87.3 ms
  42. Clouvider       | NYC, NY, US (10G)         | 893 Mbits/sec   | 951 Mbits/sec   | 76.5 ms
  43. Clouvider       | Dallas, TX, US (10G)      | 674 Mbits/sec   | 916 Mbits/sec   | 122 ms
  44. Clouvider       | Los Angeles, CA, US (10G) | 589 Mbits/sec   | 888 Mbits/sec   | 146 ms
  45. iperf3 Network Speed Tests (IPv6):
  46. ---------------------------------
  47. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  48. -----           | -----                     | ----            | ----            | ----
  49. Clouvider       | London, UK (10G)          | 1.04 Gbits/sec  | 986 Mbits/sec   | 6.76 ms
  50. Scaleway        | Paris, FR (10G)           | 1.04 Gbits/sec  | busy            | 12.0 ms
  51. NovoServe       | North Holland, NL (40G)   | 1.04 Gbits/sec  | busy            | 9.09 ms
  52. Uztelecom       | Tashkent, UZ (10G)        | 800 Mbits/sec   | 933 Mbits/sec   | 87.3 ms
  53. Clouvider       | NYC, NY, US (10G)         | 903 Mbits/sec   | busy            | 76.5 ms
  54. Clouvider       | Dallas, TX, US (10G)      | 639 Mbits/sec   | 900 Mbits/sec   | 122 ms
  55. Clouvider       | Los Angeles, CA, US (10G) | 588 Mbits/sec   | 786 Mbits/sec   | 147 ms
  56. Geekbench 6 Benchmark Test:
  57. ---------------------------------
  58. Test            | Value
  59.                 |
  60. Single Core     | 2116
  61. Multi Core      | 3756
  62. Full Test       | https://browser.geekbench.com/v6/cpu/2131302
发表于 2023-8-3 12:26:18 | 只看该作者
没有,下一个
发表于 2023-8-3 12:28:49 | 只看该作者
发表于 2023-8-3 13:01:44 来自手机 | 只看该作者
他家不是首年36刀么
发表于 2023-8-3 13:09:14 | 只看该作者
同出,楼主优先。
  1. ---------------------------- network-speed.xyz ----------------------------
  2.       A simple script to test network performance using speedtest-cli
  3. ---------------------------------------------------------------------------
  4. Version            : v2023.07.24
  5. Global Speedtest   : wget -qO- network-speed.xyz | bash
  6. Region Speedtest   : wget -qO- network-speed.xyz | bash -s -- -r <region>
  7. ---------------------------------------------------------------------------
  8. Basic System Info
  9. ---------------------------------------------------------------------------
  10. CPU Model          : AMD Ryzen 9 5950X 16-Core Processor
  11. CPU Cores          : 2 @ 3393.622 MHz
  12. CPU Cache          : 512 KB
  13. AES-NI             : ✔ Enabled
  14. VM-x/AMD-V         : ✔ Enabled
  15. Total Disk         : 96.9 GB (3.9 GB Used)
  16. Total RAM          : 3.8 GB (861.8 MB Used)
  17. Total Swap         : 976.0 MB (768.0 KB Used)
  18. System uptime      : 0 days, 14 hour 25 min
  19. Load average       : 0.00, 0.00, 0.00
  20. OS                 : Debian GNU/Linux 12
  21. Arch               : x86_64 (64 Bit)
  22. Kernel             : 6.1.0-10-amd64
  23. Virtualization     : KVM
  24. ---------------------------------------------------------------------------
  25. Basic Network Info
  26. ---------------------------------------------------------------------------
  27. Primary Network    : IPv4
  28. ISP                : Serverius Holding B.V.
  29. ASN                : AS211895 Serverius Holding B.V.
  30. Host               : Maximilian Jacobsen
  31. Location           : Dronten, Flevoland-FL, Netherlands
  32. ---------------------------------------------------------------------------
  33. Speedtest.net (Region: GLOBAL)
  34. ---------------------------------------------------------------------------
  35. Location         Latency     Loss    DL Speed       UP Speed       Server
  36. ISP: server-factory.com
  37. Nearest          0.19 ms     0.0%    940.81 Mbps    914.28 Mbps    Tanhost - NL - Dronten
  38. Kochi, IN        165.26 ms   0.0%    988.52 Mbps    121.46 Mbps    Asianet Broadband - Cochin
  39. Bangalore, IN    171.47 ms   0.0%    965.40 Mbps    173.41 Mbps    Bharti Airtel Ltd - Bangalore
  40. Chennai, IN      147.53 ms   0.0%    990.15 Mbps    205.86 Mbps    Tata Play Fiber - Chennai
  41. Mumbai, IN       198.61 ms   0.0%    981.38 Mbps    186.74 Mbps    i3D.net - Mumbai
  42. Delhi, IN        215.97 ms   0.0%    982.20 Mbps    160.01 Mbps    Tata Teleservices Ltd - New Delhi
  43. Seattle, US      171.59 ms   0.5%    846.80 Mbps    29.96 Mbps     DediPath - Seattle, WA
  44. Los Angeles, US  142.93 ms   0.0%    1005.11 Mbps   210.00 Mbps    ReliableSite Hosting - Los Angeles, CA
  45. Dallas, US       126.74 ms   0.0%    809.70 Mbps    45.07 Mbps     Hivelocity - Dallas, TX
  46. Miami, US        127.31 ms   0.0%    945.20 Mbps    193.29 Mbps    AT&T - Miami, FL
  47. New York, US     76.98 ms    0.0%    999.24 Mbps    257.13 Mbps    Clouvider Ltd - New York, NY
  48. Toronto, CA      89.66 ms    0.0%    1000.75 Mbps   232.09 Mbps    Rogers - Toronto, ON
  49. London, UK       7.72 ms     0.0%    979.30 Mbps    1008.92 Mbps   VeloxServ Communications - London
  50. Amsterdam, NL    7.29 ms     0.0%    1001.24 Mbps   1001.36 Mbps   Clouvider Ltd - Amsterdam
  51. Paris, FR        16.50 ms    N/A     1001.13 Mbps   716.30 Mbps    Axione - Paris
  52. Frankfurt, DE    7.67 ms     0.0%    1001.35 Mbps   1035.73 Mbps   23M GmbH - Frankfurt Am Main
  53. Warsaw, PL       23.34 ms    0.0%    994.95 Mbps    560.54 Mbps    UPC Polska - Warszawa
  54. Bucharest, RO    37.06 ms    0.0%    1004.21 Mbps   509.98 Mbps    Vodafone Romania Fixed – Bucharest - Bucharest
  55. Jeddah, KSA      72.81 ms    0.0%    1007.71 Mbps   160.35 Mbps    Saudi Telecom Company
  56. Dubai, AE        120.93 ms   0.0%    1007.26 Mbps   209.90 Mbps    du - Dubai
  57. Fujairah, AE     124.19 ms   0.0%    984.59 Mbps    216.34 Mbps    ETISALAT-UAE - Fujairah
  58. Tokyo, JP        253.79 ms   N/A     806.41 Mbps    115.84 Mbps    fdcservers.net - Tokyo
  59. Shanghai, CU-CN  178.70 ms   0.0%    822.06 Mbps    149.23 Mbps    China Unicom 5G - ShangHai
  60. Nanjing, CT-CN   258.89 ms   11.7%   697.71 Mbps    1.10 Mbps      China Telecom JiangSu 5G - Nanjing
  61. Hong Kong, HKG   198.65 ms   N/A     1007.36 Mbps   148.04 Mbps    STC - Hong Kong
  62. Singapore, SG    151.80 ms   0.0%    1002.97 Mbps   110.90 Mbps    i3D.net - Singapore
  63. Jakarta, ID      181.50 ms   0.0%    915.52 Mbps    135.81 Mbps    PT. Telekomunikasi Indonesia - Jakarta
  64. ---------------------------------------------------------------------------
  65. Avg DL Speed       : 951.44 Mbps
  66. Avg UL Speed       : 326.28 Mbps
  67. Total DL Data      : 35.22 GB
  68. Total UL Data      : 7.96 GB
  69. Total Data         : 43.17 GB
  70. ---------------------------------------------------------------------------
  71. Duration           : 12 min 6 sec
  72. System Time        : 03/08/2023 - 10:31:01 CST
  73. Total Script Runs  : 20158
  74. ---------------------------------------------------------------------------
  75. Unable to share result online - There is some issue with the provider.
  76. Result stored locally in /root/network-speed.txt
  77. ---------------------------------------------------------------------------
GMT+8, 2026-4-24 06:31 , Processed in 0.070534 second(s), 10 queries , Gzip On, MemCache On.
