CeraNetworks网络延迟测速工具IP归属甄别
查看: 5237|回复: 6
KT新闻:Good News For International Customers
发表于 2010-3-10 11:42:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Tinet, formerly the carrier arm of Tiscali Group and the only global carrier exclusively committed to the IP and Ethernet wholesale market, and China Telecom (Europe) Ltd. (China Telecom Europe), the subsidiary of China Telecommunications Corporation (China Telecom), China’s principal telecom operator and comprehensive information provider and owner of the world’s largest fixed-line communication network, announce today China Telecom’s partnership with Tinet for International Ethernet Private Line service.
This service provides Layer 2 carrier Ethernet solution to customers in the metropolitan cities across the world. Through this partnership, the service expands to more than 220+ POPs in Mainland China, over 70 Pops in Europe and more than 15 global POPs in other regions. Through these and other efforts, China Telecom is aiming for regional development and market expansion into Europe, Middle East and Africa.
Krypt uses Tinet as a carrier, so this news means better network connectivity for all.
发表于 2010-3-10 11:45:51 | 只看该作者
好大一坨,简单的说就是以后速度会更好,是不
发表于 2010-3-10 12:51:59 | 只看该作者
强大是否该进军呢?
 楼主| 发表于 2010-3-10 17:55:19 | 只看该作者
回复 2# 的帖子
是说tinet线路跟中国电信的合作,线路会更好,而Krypt有tinet线路接入。
发表于 2010-3-10 20:41:45 | 只看该作者
喜事。
发表于 2010-3-11 20:43:18 | 只看该作者
tinet从来不看好。以前不看好,以后也不看好。
看看现在。300+MS
 楼主| 发表于 2010-3-12 14:48:04 | 只看该作者
回复 7# 的帖子
我访问PR的Nlayer一样是300ms+
Pinging www.pacificrack.com [216.144.225.250] with 32 bytes of data:
Reply from 216.144.225.250: bytes=32 time=301ms TTL=50
Reply from 216.144.225.250: bytes=32 time=322ms TTL=50
Reply from 216.144.225.250: bytes=32 time=328ms TTL=50
Reply from 216.144.225.250: bytes=32 time=325ms TTL=50
Ping statistics for 216.144.225.250:
    Minimum = 301ms, Maximum = 328ms, Average = 319ms
只能说杯具的国内ISP。
GMT+8, 2026-4-18 19:26 , Processed in 0.065118 second(s), 10 queries , Gzip On, MemCache On.
