查看: 2035|回复: 7
[美国VPS] vultr 我申请通过Free Tier Program 但是不知道在哪里创建实例
发表于 2023-7-18 11:20:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
RT
他提示我Cloud Compute > Regular > Free Instance
这个路径,我还是找不到。
特来求助
发表于 2023-7-18 11:25:13 | 只看该作者
是那个免费机嘛 ?
发表于 2023-7-18 11:26:56 | 只看该作者
Vultr Free Tier Program
Application Received
If you are admitted into the program, you will be notified by email as well as here.
This is a new program that we are developing and inventory is limited. Early access is not guaranteed and we will be approving accounts on a rolling basis as we continue to refine this tier. Additionally, we will only reach out if you have been accepted into the program. Ineligible applicants will not be notified.
Please note that our support team is unable to answer questions about your application status. This program is administered outside of their purview. They do not have access to the process nor do they have insight in regards to the status of individual accounts.
 楼主| 发表于 2023-7-18 11:28:58 | 只看该作者
You were approved for early access to the Free Tier Program.
Your Free Tier starts on 2023-07-17 and will end on 2024-07-17.
During that year, you will be able to launch a Free Tier instance. You can only have 1 free instance running at a time. If you shut down the instance you can relaunch it up to twice per month.
The free instance can be deployed on the instance deploy page under:
发表于 2023-7-18 11:36:21 | 只看该作者
创建实例 选择西雅图  最原始的配置  我只能帮你到这了  如果还不懂  5U
 楼主| 发表于 2023-7-18 11:58:53 | 只看该作者
发现了,感谢楼上,要创建实例的时候一步步点下去才行。
 楼主| 发表于 2023-7-18 12:12:14 | 只看该作者
worryfree 发表于 2023-7-18 11:36
创建实例 选择西雅图  最原始的配置  我只能帮你到这了  如果还不懂  5U   ...
选择了西雅图,只能选择0tb的带宽,
这个有点过分啊。
发表于 2023-7-18 12:56:42 | 只看该作者
好几个月了,我依然显示等待中
GMT+8, 2026-4-16 21:43 , Processed in 0.074450 second(s), 10 queries , Gzip On, MemCache On.
