查看: 1856|回复: 8
已出绿云达拉斯 5C5G55G5T,55刀2年
发表于 2023-7-13 10:13:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
拿来就挂了个探针,   55刀2年  5C5G55G5T  24th February 2024到期
剩余价值100出了        需要的MJJ TG联系我  @lqtest520
  IP        64.44.157.5X
已出已出已出已出已出已出已出已出已出已出已出已出已出已出已出已出已出已出已出已出已出已出已出已出已出已出
CPU Model          : Intel(R) Xeon(R) CPU E5-2650 v3 @ 2.30GHz
CPU Cores          : 5 @ 2299.994 MHz
CPU Cache          : 16384 KB
AES-NI             : Enabled
VM-x/AMD-V         : Disabled
Total Disk         : 52.1 GB (14.3 GB Used)
Total Mem          : 4.8 GB (1.4 GB Used)
Total Swap         : 2.0 GB (41.8 MB Used)
System uptime      : 4 days, 12 hour 25 min
Load average       : 0.05, 0.13, 0.10
OS                 : CentOS Linux release 7.9.2009 (Core)
Arch               : x86_64 (64 Bit)
Kernel             : 5.17.5
TCP CC             : bbr
Virtualization     : KVM
Organization       : AS40676 Psychz Networks
Region             : Texas
I/O Speed(1st run) : 483 MB/s
I/O Speed(2nd run) : 940 MB/s
I/O Speed(3rd run) : 1.0 GB/s
I/O Speed(average) : 815.7 MB/s
Speedtest.net    876.78 Mbps       884.43 Mbps         0.48 ms
Los Angeles, US  830.31 Mbps       622.71 Mbps         37.08 ms
Dallas, US       877.15 Mbps       886.53 Mbps         0.84 ms
Montreal, CA     822.64 Mbps       820.50 Mbps         43.79 ms
Paris, FR        731.78 Mbps       526.62 Mbps         112.71 ms
Amsterdam, NL    633.99 Mbps       546.78 Mbps         127.35 ms
Shanghai, CN     423.89 Mbps       541.92 Mbps         194.00 ms
Nanjing, CN      423.60 Mbps       374.48 Mbps         175.72 ms
Guangzhou, CN    188.40 Mbps       158.79 Mbps         192.62 ms
Hongkong, CN     320.44 Mbps       843.17 Mbps         248.82 ms
Seoul, KR        444.08 Mbps       532.31 Mbps         172.02 ms
Singapore, SG    383.70 Mbps       267.81 Mbps         204.66 ms
Tokyo, JP        394.31 Mbps       231.34 Mbps         202.97 ms
另外一个测试
Basic System Information:
Uptime     : 4 days, 12 hours, 43 minutes
Processor  : Intel(R) Xeon(R) CPU E5-2650 v3 @ 2.30GHz
CPU cores  : 5 @ 2299.994 MHz
AES-NI     : ✔ Enabled
VM-x/AMD-V : ❌ Disabled
RAM        : 4.8 GiB
Swap       : 2.0 GiB
Disk       : 52.1 GiB
Distro     : CentOS Linux 7 (Core)
Kernel     : 5.17.5
fio Disk Speed Tests (Mixed R/W 50/50):
Read       | 178.73 MB/s  (44.6k) | 1.56 GB/s    (24.4k)
Write      | 179.20 MB/s  (44.8k) | 1.57 GB/s    (24.6k)
Total      | 357.93 MB/s  (89.4k) | 3.14 GB/s    (49.0k)
Read       | 2.03 GB/s     (3.9k) | 2.05 GB/s     (2.0k)
Write      | 2.13 GB/s     (4.1k) | 2.19 GB/s     (2.1k)
Total      | 4.16 GB/s     (8.1k) | 4.25 GB/s     (4.1k)
Geekbench 5 Benchmark Test:
Test            | Value
Single Core     | 598
Multi Core      | 2566
Full Test       | https://browser.geekbench.com/v5/cpu/15283471
 楼主| 发表于 2023-7-13 15:30:37 | 只看该作者
h好鸡鸡  顶一顶
 楼主| 发表于 2023-7-14 10:15:33 | 只看该作者
有人要吗、?
发表于 2023-7-14 10:33:13 | 只看该作者
自鸡自顶?相信是JP肯定有人要,达拉斯什么鸟线路
发表于 2023-7-14 10:42:29 | 只看该作者
洛杉矶最香
 楼主| 发表于 2023-7-17 13:02:14 | 只看该作者
顶顶顶
发表于 2023-7-17 14:22:25 | 只看该作者
近期稳定吗?  绿云有啥暗坑吗?  例如  vir 限制 cpu  带宽  那些!
发表于 2023-7-17 15:34:54 | 只看该作者
10分钟内占用cpu80%将自动关机~
cpu限制很严重
GMT+8, 2026-4-16 21:33 , Processed in 0.063008 second(s), 10 queries , Gzip On, MemCache On.
