查看: 2567|回复: 14
最近有遇到dmit强制换ip的不
发表于 2023-7-9 19:55:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
HK 6.9刀,之前ip可以解锁奈飞,收到邮件后看了下新的解锁不行。。。这种情况也不能要求换回去吧。。。
Services Name: DMIT-ubPehvq7P7
Dear Client, we are sorry to let you know we have to re-assign your IP immediately.
If you have multiple IP addresses, you have to configure the new IPs on your own;
If your VM didn't install cloud-init, you have to manually configure on your own;
If you find your VM cannot be accessed, please try to reboot;
Please check the noVNC console if you still cannot access the VM after all the checklist and configure it manually.
We are sorry again to let you know this so late, this subnet was only have few IP in use, and we already wait for months to see if every IP could be replaced out automatically. But it seems not, so we have to do this manually.
Since cloud-init has changed on the Debian package, you may need to change the IP manually. Please delete the [.cfg] for the file /etc/network/interfaces.d/50-cloud-init.cfg ]
Please contact us here if you have any issues or questions.The IP 103.135.250.X has been updated to 154.3.39.X
发表于 2023-7-9 20:15:02 | 只看该作者
这家是非常不稳定,价格向大厂看看齐,服务向ONEMAN看齐,之前大批量事故,所有数据没了。
发表于 2023-7-9 19:56:33 | 只看该作者
  1. 由于运营商特殊限制,以下IP段(HKG.EB)可能出现无法预知的问题,我们将在短期内批量更换。
  2. 如果更换后无法访问可以联系DMIT再次更换。
  3. 103.117.101.0/24
  4. 103.117.102.0/24
  5. 103.135.248.0/24
  6. 103.135.249.0/24
  7. 103.135.250.0/24
  8. 103.135.251.0/24
来源:https://t.me/DMIT_INC_CN
发表于 2023-7-9 19:57:15 来自手机 | 只看该作者
这是老的HKG?
 楼主| 发表于 2023-7-9 19:57:29 | 只看该作者
没看公告,不过不解锁有点麻烦
发表于 2023-7-9 19:59:11 来自手机 | 只看该作者
是的,ipv4死活不通,重新安装了事,解锁倒是无所谓
 楼主| 发表于 2023-7-9 20:02:33 | 只看该作者
22年6月的
发表于 2023-7-9 21:17:16 来自手机 | 只看该作者
103.117.101网段很好的,可惜我的也被强制换了
发表于 2023-7-9 22:06:43 | 只看该作者
v2w3.com 发表于 2023-7-9 20:15
这家是非常不稳定,价格向大厂看看齐,服务向ONEMAN看齐,之前大批量事故,所有数据没了。 ...
是的,之前HKG是香饽饽,后来废了,后来又成香饽饽,再次废了。
我抄底收一个。
发表于 2023-7-11 10:44:57 | 只看该作者
楼主的6.9是月付吗?如果不打算要了 我收一个
GMT+8, 2026-4-18 08:49 , Processed in 0.063389 second(s), 11 queries , Gzip On, MemCache On.
