查看: 3679|回复: 13
关于刚更新的GPT3.5-16K
发表于 2023-6-14 14:03:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
openai更新的GPT3.5-16K有什么特殊之处吗
发表于 2023-6-14 14:05:47 | 只看该作者
GPT-3.5 Turbo
This model has been updated with a new version: gpt-3.5-turbo-0613 which is more steerable with the system message and includes a new capability: function calling. By describing functions in your prompts, the model can intelligently output a JSON object containing arguments to call these functions based on user input — perfect for integrating with other tools or APIs. Learn more in our function calling documentation.
Plus enjoy a 25% cost reduction for input tokens on GPT-3.5 Turbo (now $0.0015 per 1K input tokens), effective immediately.
Longer Context
We’re also introducing gpt-3.5-turbo-16k. This model offers four times the context length of the 4k base model and is priced at $0.003 per 1K input tokens and $0.004 per 1K output tokens.
Model Transitioning
You can begin using the new gpt-3.5-turbo-0613 model today. On June 27th, the stable gpt-3.5-turbo will be automatically upgraded to this new version. If you need more time to transition, you can specify gpt-3.5-turbo-0301 to keep using the older version, which will remain available until September 13th as part of our upgrade and deprecation process.
 楼主| 发表于 2023-6-14 14:07:41 | 只看该作者
fule 发表于 2023-6-14 14:05
GPT-3.5 Turbo
This model has been updated with a new version: gpt-3.5-turbo-0613 which is more stee ...
感谢大佬
发表于 2023-6-14 14:08:35 | 只看该作者
Token长度达到16K
发表于 2023-6-14 14:23:15 来自手机 | 只看该作者
16K:增加上下文长度达到16K,token价格为gpt-3.5的2倍(由于gpt3.5降价25%,相当于是原来3.5价格的1.5倍)。
发表于 2023-6-14 14:46:32 | 只看该作者
话说怎么申请4.0 申请两次都没反应 都俩月了
发表于 2023-6-14 15:11:56 | 只看该作者
都两三个月了还在等
发表于 2023-6-14 15:33:26 | 只看该作者
tirophy 发表于 2023-6-14 15:11
都两三个月了还在等
已经绑卡用着了api了目前 就是4.0没出来
发表于 2023-6-16 19:47:39 | 只看该作者
4我4月底就出来了
发表于 2023-6-16 19:56:16 | 只看该作者
挺好
GMT+8, 2026-1-3 09:11 , Processed in 0.127286 second(s), 10 queries , Gzip On, MemCache On.
