查看: 1789|回复: 2
【chatgpt3.5】轻量级邮件服务器
发表于 2023-6-9 16:45:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <iostream>
#include <string>
#include <cstring>
#include <fstream>
#include <filesystem>
#include <winsock2.h>
#pragma comment(lib, "ws2_32.lib")
#define MAKE_INT32(str) \
    (static_cast<uint32_t>(str[0]) << 24 | \
     static_cast<uint32_t>(str[1]) << 16 | \
     static_cast<uint32_t>(str[2]) << 8 | \
     static_cast<uint32_t>(str[3]))
namespace fs = std::filesystem;
const int BUFFER_SIZE = 4096;
bool receiveCommand(SOCKET clientSocket, std::string& command) {
    char buffer[BUFFER_SIZE];
    int bytesRead = recv(clientSocket, buffer, BUFFER_SIZE - 1, 0);
    if (bytesRead <= 0) {
        return false;
    buffer[bytesRead] = '\0';
    command = buffer;
    return true;
std::string parseSender(const std::string& command) {
    std::size_t start = command.find('<');
    std::size_t end = command.find('>', start);
    if (start != std::string::npos && end != std::string::npos) {
        return command.substr(start + 1, end - start - 1);
    return "";
std::string parseRecipient(const std::string& command) {
    return "";
bool createFolder(const std::string& folderPath) {
    try {
        fs::create_directory(folderPath);
        return true;
    catch (const std::exception& e) {
        std::cerr << "Failed to create folder: " << e.what() << std::endl;
        return false;
void saveEmailToFile(const std::string& emailContent, const std::string& sender, const std::string& recipient) {
    std::string folderPath = "email";  // 文件夹路径
    // 检查文件夹是否存在
    if (createFolder(folderPath)) {
        std::cout << "Folder created successfully." << std::endl;
    std::string fileName = "email/" + sender + "_" + recipient + ".txt";
    std:fstream file(fileName);
    if (file.is_open()) {
        file << emailContent;
        file.close();
        std::cout << "Email saved to file: " << fileName << std::endl;
    else {
        std::cerr << "Failed to save email to file." << std::endl;
int main() {
    // 初始化 Winsock
    WSADATA wsaData;
    if (WSAStartup(MAKEWORD(2, 2), &wsaData) != 0) {
        std::cerr << "Failed to initialize Winsock." << std::endl;
        return 1;
    // 创建套接字
    SOCKET serverSocket = socket(AF_INET, SOCK_STREAM, 0);
    if (serverSocket == INVALID_SOCKET) {
        std::cerr << "Failed to create socket." << std::endl;
        WSACleanup();
        return 1;
    // 绑定地址和端口
    sockaddr_in serverAddress{};
    serverAddress.sin_family = AF_INET;
    serverAddress.sin_port = htons(25);  // SMTP默认端口
    serverAddress.sin_addr.s_addr = INADDR_ANY;
    if (bind(serverSocket, (struct sockaddr*)&serverAddress, sizeof(serverAddress)) == SOCKET_ERROR) {
        std::cerr << "Failed to bind." << std::endl;
        closesocket(serverSocket);
        WSACleanup();
        return 1;
    // 监听连接请求
    if (listen(serverSocket, SOMAXCONN) == SOCKET_ERROR) {
        std::cerr << "Failed to listen." << std::endl;
        WSACleanup();
        return 1;
    std::cout << "Server started. Listening for incoming connections..." << std::endl;
    while (true) {
        // 接受客户端连接
        SOCKET clientSocket = accept(serverSocket, nullptr, nullptr);
        if (clientSocket == INVALID_SOCKET) {
            std::cerr << "Failed to accept client connection." << std::endl;
            WSACleanup();
            return 1;
        std::cout << "Client connected." << std::endl;
        const std::string welcomeMessage = "220 Welcome to My Mail Server\r\n";
        send(clientSocket, welcomeMessage.c_str(), welcomeMessage.size(), 0);
        // 接收客户端的命令
        std::string command;
        if (!receiveCommand(clientSocket, command)) {
            std::cerr << "Error receiving command." << std::endl;
            closesocket(clientSocket);
            continue;
        // 判断命令是否为 EHLO
        if (command.substr(0, 4) == "EHLO") {
            // 发送 EHLO 响应
            std::string response = "250-Hello gru.win\r\n"
                "250-SIZE 52428800\r\n"
                "250-8BITMIME\r\n"
                "250-ENHANCEDSTATUSCODES\r\n"
                "250-PIPELINING\r\n"
                "250-CHUNKING\r\n"
                "250 OK\r\n";
            send(clientSocket, response.c_str(), static_cast<int>(response.size()), 0);
                continue;
        std::string sender;
        std::string recipient;
        while (command.length() >= 4)
            switch (MAKE_INT32(command))
            case MAKE_INT32("MAIL"):
                // 收到 MAIL FROM 命令,获取发件人信息
                sender = parseSender(command);
                break;
                    // 判断下一个命令是否为 RCPT TO
            case MAKE_INT32("RCPT"):
                // 获取收件人信息
                recipient = parseRecipient(command);
                break;
                //const std::string welcomeMessage = "250 OK\r\n";
                //send(clientSocket, welcomeMessage.c_str(), welcomeMessage.size(), 0);
                // 接收下一个命令
                // 判断下一个命令是否为 DATA
            case MAKE_INT32("DATA"):
                // 发送接收数据的响应
                std::string dataResponse = "354 Start mail input; end with <CRLF>.<CRLF>\r\n";
                send(clientSocket, dataResponse.c_str(), static_cast<int>(dataResponse.size()), 0);
                // 接收邮件内容
                std::string emailContent;
                while (true) {
                        std::cerr << "Error receiving email content." << std::endl;
                        break;
                    emailContent += buffer;
                    // 判断是否接收完毕
                    if (emailContent.length() >= 5 && emailContent.substr(emailContent.length() - 5) == "\r\n.\r\n") {
                        break;
                // 保存邮件到文件
                saveEmailToFile(emailContent, sender, recipient);
                break;
            case MAKE_INT32("QUIT"):
                break;
            default:
                break;
            // 发送接收成功的响应
            std::string response = "250 OK\r\n";
                break;
        // 关闭客户端连接
        std::cout << "Client disconnected." << std::endl;
    // 关闭服务器套接字
    // 清理 Winsock
    WSACleanup();
    return 0;
将接收到的邮件保存到txt文本文件,用来接收验证码超级给力,纯中文与chatgpt3.5交互获得的代码,真没想到中文编程会以这种方式实现
发表于 2023-6-9 16:50:16 | 只看该作者
这个怎么解析mime呢?
邮件不都是纯plain的呀。
不过也够牛b啦。
 楼主| 发表于 2023-6-9 16:52:45 | 只看该作者
wise指南 发表于 2023-6-9 16:50
这个怎么解析mime呢?
邮件不都是纯plain的呀。
不知道,反正邮件以源文件保存到txt文件了,解析更多内容需要继续对gpt进行拷问才行,问了至少6个小时才给我这么点东西,不过测试确实能收邮件
GMT+8, 2026-4-25 06:30 , Processed in 0.058574 second(s), 9 queries , Gzip On, MemCache On.
