查看: 1778|回复: 2
[疑问] docker 运行容器报错
发表于 2023-6-7 10:46:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
root@89:~# docker ps
CONTAINER ID   IMAGE     COMMAND   CREATED   STATUS    PORTS     NAMES
root@89:~# docker pull pengzhile/pandora
Using default tag: latest
latest: Pulling from pengzhile/pandora
f03b40093957: Pull complete
05c2151a829c: Pull complete
413e4e4760ae: Pull complete
92ec8b395aa1: Pull complete
295d2f1818b0: Pull complete
b161d91fdb6b: Pull complete
0bb6c060da43: Pull complete
2a5bb1e631c2: Pull complete
Digest: sha256:a93ce3b59c1ac7b3ebee11a61e36188401565ce8808f3a2c1d9ea0bb03353c0d
Status: Downloaded newer image for pengzhile/pandora:latest
docker.io/pengzhile/pandora:latest
root@89:~# docker run  -e PANDORA_CLOUD=cloud -e PANDORA_SERVER=0.0.0.0:8899 -p 8899:8899 -d pengzhile/pandora
1cf69db64dd571ea32e0e10e1df2155fe6d0848373105222fd0f1113de58b63c
docker: Error response from daemon: failed to create task for container: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error setting cgroup config for procHooks process: bpf_prog_query(BPF_CGROUP_DEVICE) failed: invalid argument: unknown.
这个怎么处理?
发表于 2023-6-7 11:53:51 | 只看该作者
升级kernel和docker版本
发表于 2023-6-7 12:21:17 | 只看该作者
楼上说的很对
GMT+8, 2026-4-25 23:37 , Processed in 0.063675 second(s), 10 queries , Gzip On, MemCache On.
