查看: 3870|回复: 7
[Windows VPS] 第一次用VPS 被投诉,求帮忙
发表于 2012-4-16 14:09:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
下面是收到的邮件, 第一次被投诉,我该这么回复呢?求帮忙
没有乱发邮件,只是用来注册文章站发文章的。
There has been a report of abuse on your server.
Per our policies, we require that all our clients respond to abuse notices as they come in. Failure to do so within a timely manner (within 24 hours) will result in a suspension of services until the server administrator has time to resolve the issue.
The initial complaint is attached to this ticket. If you don't see it under my signature, please log in to your billing interface and view the ticket there.
We will await your response indicating that you have complied with the order, dispute it, or require a reasonable extension of time to resolve the issue.
Awaiting your timely response,
-Jack
Support Supervisor
QuadraNet, Inc
530 W 6th Street #901
Los Angeles, CA 90014
---- Original message ----
> Hello Abuse-Team,
> your Server with the IP: 67.215.235.228 has attacked one of our
> server/partner on the service:
> "badbot"  on Time: Sun, 15 Apr 2012 03:42:07 +0000. The time is from
> the Server of the blocklist-user
>  (so, please check it +-10 minutes, when the time is false).
> The IP was automatically blocked for more than 10 minutes. To block
> an IP, it needs
> 3 failed Logins (ssh, imap....), one match for "invalid user" or a
> 5xx-Error-Code (eg. Blacklist on mail...)!
> The IP has send a SPAM-Comment on a Honeypot-Forum or Honeypot-Wiki
> with URLs to e.g. buy viagra
> or link to other spamvertised sites. He used xrumer or other Tools or
> had a false configured mod_rewrite/mod_proxy who is abused:
> http://blog.blocklist.de/2011/03/14/erlauterung-der-einzelnen-dienste-badbots-apacheddos-postfix/#badbots
> Please check the machine behind the IP 67.215.235.228
> (67.215.235.228.static.quadranet.com) and fix the problem.
> Search for AS-Number/IPs from you, look at
> https://www.blocklist.de/en/search.html?as=29761
> You can parse this Mail with X-ARF-Tools from
> http://www.x-arf.org/tools.html e.g. validatexarf-php.tar.gz.
> You found more Information about X-Arf under
> http://www.x-arf.org/specification.html
> This mail will be sent again after one day if more attacks are
> recognized.
> In the attachment of this mail you can find the original protocols of
> our systems.
> To pause this message for one week, you can insert the IP and
> E-Mailaddress to our Blocklist.
> If more attacks of your network are recognized after the pause of
> seven days, the block will
> be canceled and you will get new reports.
> https://www.blocklist.de/en/insert.html?ip=67.215.235.228&email=noc@securedprivatenetwork.net
> We found your address in the Whois-Data from the IP under the
> SearchString "abuse-mailbox"
> Answer us to rewrite the address (to abuse-quiet or a special
> address) for all upcoming reports.
> Abuse-Team
> This message was sent automatically, please answer us for Questions
> to abuse-team@blocklist.de
> or go to: https://www.blocklist.de/en/contact.html?RID=22739542
发表于 2012-4-16 14:12:17 | 只看该作者
没经验..
发表于 2012-4-16 14:13:01 | 只看该作者
你用来做VPN?
发表于 2012-4-16 14:16:41 | 只看该作者
domin 发表于 2012-4-16 14:13
你用来做VPN?
好像被人用来搞了spam
发表于 2012-4-16 14:17:49 | 只看该作者
haoxiang是乱发邮件?
发表于 2012-4-16 14:18:46 | 只看该作者
SPAM
发表于 2012-4-16 14:25:02 | 只看该作者
投诉有什么后果?
发表于 2012-4-16 14:51:42 | 只看该作者
。。。乱发邮件吧,唉。。蛋定
GMT+8, 2026-4-20 12:39 , Processed in 0.139793 second(s), 13 queries , Gzip On, MemCache On.
