查看: 2305|回复: 0
Virtualmin update error: Suexec command on your system is..
发表于 2010-3-6 21:28:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
The Suexec command on your system is configured to only run scripts under /var/www, but the Virtualmin base directory is /home. CGI and PHP scripts run as domain owners will not be executed.
To fix this:
1. Use the Virtualmin framed layout;
2. On the left top; click on Virtualmin;
3. Open the + on "System settings";
4. Click "Server Templates";
5. On the right screen; click "Default Settings";
6. On the select box "Edit template section" choose "Apache website";
7. Find the radio button: "Automatically add appropriate SuExec directive?"
8. Choose "no", scroll down and "save".
收藏一下先。
GMT+8, 2026-4-20 12:39 , Processed in 0.054309 second(s), 9 queries , Gzip On, MemCache On.
