查看: 1917|回复: 3
[lighttpd] DS的数据恢复,看起来是无望了。。
发表于 2012-4-12 08:39:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Alex T
Staff
04/11/2012 02:28        Hello,
At this time, we have experienced unauthorized remote access to some of our VPS nodes. Not all nodes were effected – as you are experiencing issues connecting to your VE, it has likely been involved in this matter. According to logs, the VEs were simply destroyed using OpenVZ functions – no data has been transferred out or copied. This issue is a severe inconvenience to you and all of our customers, and the primary reason all of our nodes are now locked down to local access only. We are currently provisioning new nodes so we can simply recreate the device with the same IP address.
If you have any specific questions on this matter, please do not hesitate to respond back to this ticket. At this time you should receive a new welcome email with your normal IP and login information.
Thank you for your understanding and patience in this matter – if you require assistance with restoring any type of self-taken backups, we can surely help.
Regards
Alex T.
DirectSpace Networks
wang
Client
04/11/2012 06:05        I truely understand ur difficult situation in current time.
The most important issue I want to make sure is whether I can get all my data back. And how long will u take to recover database?
Edward Evi
Staff
04/11/2012 06:10        wang
Due to the massive attack, and force removal of each VE, we do not have the copies available on a per VE basis. We are glad to help you restore any backups you may have.
We sincerely apologize for this inconvenience and are working hard to rememdy each client's situation with the best outcome we can possibly provide.
Regards
Edward Evi
DirectSpace Networks, LLC.
不知我理解的对不对
发表于 2012-4-12 08:41:56 | 只看该作者
大概是的了,正在下备份中……
发表于 2012-4-12 09:14:50 | 只看该作者
昨天就是这个答复了。
我开始以为只有我一个节点的问题,如果是大批量的,他也懒得替你弄备份了。
发表于 2012-4-12 09:58:46 | 只看该作者
又一次、再一次
GMT+8, 2026-4-29 06:06 , Processed in 0.241056 second(s), 13 queries , Gzip On, MemCache On.
