查看: 3346|回复: 5
[Windows VPS] 球个怎么看ioping的说明
发表于 2012-4-12 00:10:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ioping测试出来了,怎么看好坏呢。
irtuzzo OR OpenVZ Virtualisation detected
ioping code.google.com/p/ioping/
ioping.sh 0.9.8
shell wrapper script by George Liu (eva2000)
http://vbtechsupport.com
Virtuzzo or OpenVZ Virtualisation detected
dd (sequential disk speed test)...
dd if=/dev/zero of=testfilex bs=64k count=16k conv=fdatasync
16384+0 records in
16384+0 records out
1073741824 bytes (1.1 GB) copied, 10.7404 seconds, 100 MB/s
starting ioping tests...
ioping disk I/O test (default 1MB working set)
disk I/O: /
--- / (simfs /dev/simfs) ioping statistics ---
5 requests completed in 4008.0 ms, 11312 iops, 44.2 mb/s
min/avg/max/mdev = 0.1/0.1/0.1/0.0 ms
seek rate test (default 1MB working set)
seek rate: /
1398 requests completed in 3087.3 ms, 900 iops, 3.5 mb/s
min/avg/max/mdev = 0.0/1.1/272.7/10.3 ms
sequential test (default 1MB working set)
sequential: /
466 requests completed in 3005.4 ms, 196 iops, 48.9 mb/s
min/avg/max/mdev = 2.1/5.1/185.3/10.5 ms
sequential cached I/O: /
2788 requests completed in 3000.4 ms, 12174 iops, 3043.5 mb/s
min/avg/max/mdev = 0.1/0.1/0.7/0.0 ms
 楼主| 发表于 2012-4-12 00:27:54 | 只看该作者
没人懂吗,兄弟们给看看
发表于 2012-4-12 00:35:30 | 只看该作者
不懂
发表于 2012-4-12 12:16:05 | 只看该作者
嗯,一个年付15刀的结果让你参考参考。。。
  1. # ioping -c 5 /
  2. 5 requests completed in 6390.7 ms, 2 iops, 0.0 mb/s
  3. min/avg/max/mdev = 0.3/477.3/1479.2/533.2 ms
  1. # ioping -R /
  2. 1364 requests completed in 3502.8 ms, 889 iops, 3.5 mb/s
  3. min/avg/max/mdev = 0.0/1.1/564.0/19.0 ms
  1. # ioping -RL /
  2. 115 requests completed in 3083.1 ms, 39 iops, 9.8 mb/s
  3. min/avg/max/mdev = 4.2/25.5/600.5/93.7 ms
  4. # ioping -RLC /
  5. 3001 requests completed in 3000.5 ms, 11905 iops, 2976.2 mb/s
  6. min/avg/max/mdev = 0.1/0.1/0.2/0.0 ms
发表于 2012-4-12 12:19:20 | 只看该作者
11312 iops
什么硬盘IO这么高
 楼主| 发表于 2012-4-12 12:44:39 | 只看该作者
咩咩,我这是独服,感觉比不上你的。对比了,感觉有的高,有的低。
GMT+8, 2026-4-16 10:03 , Processed in 0.068303 second(s), 12 queries , Gzip On, MemCache On.
