查看: 3030|回复: 16
[美国VPS] Scaleway 星辰安装Alpine 出问题?
发表于 2023-4-27 11:33:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我按照帖子操作
https://loc.qiche.eu.org/thread-1145636-1-1.html
进行第6步
“6.打开控制台(Console),没有意外会自动进入Alpine。”
无法进入Alpine,有大佬能帮忙下吗?
UEFI Interactive Shell v2.2
EDK II
UEFI v2.70 (EDK II, 0x00010000)
Mapping table
     BLK0: Alias(s):
          PciRoot(0x0)/Pci(0x1,0x0)/Floppy(0x0)
     BLK1: Alias(s):
          PciRoot(0x0)/Pci(0x1,0x0)/Floppy(0x1)
     BLK2: Alias(s):
          PciRoot(0x0)/Pci(0x4,0x0)
Press ESC in 1 seconds to skip startup.nsh or any other key to continue.
Shell>
 楼主| 发表于 2023-4-27 11:38:11 | 只看该作者
  Station IP address is 10.70.3.23
  Server IP address is 10.194.3.9
  NBP filename is undionly.kpxe
  NBP filesize is 88751 Bytes
Downloading NBP file...
  NBP file downloaded successfully.
>>Start HTTP Boot over IPv4..
EDK II
Mapping table
     BLK0: Alias(s):
     BLK1: Alias(s):
     BLK2: Alias(s):
Shell>
发表于 2023-4-27 11:42:07 来自手机 | 只看该作者
可以2G装个最小的debian9 没必要用这系统 属实用不习惯
发表于 2023-4-27 11:42:52 | 只看该作者
Mapping table
     BLK0: Alias(s):
     BLK1: Alias(s):
     BLK2: Alias(s):
硬盘哪去了?硬盘都没检测到,重来吧。。
 楼主| 发表于 2023-4-27 11:57:15 | 只看该作者
从 Use rescue image 进入系统后,输入如下
Welcome to Ubuntu 22.04.2 LTS (GNU/Linux 5.15.0-69-generic x86_64)
* Documentation:  https://help.ubuntu.com
* Management:     https://landscape.canonical.com
* Support:        https://ubuntu.com/advantage
  System information as of Thu Apr 27 03:52:42 UTC 2023
  System load:    0.1650390625   Processes:             92
  Usage of /home: unknown        Users logged in:       0
  Memory usage:   19%            IPv4 address for ens2: 10.69.84.197
  Swap usage:     0%             IPv6 address for ens2: 2001:bc8:62c:262::1
  => /media/root-ro is using 96.5% of 1.96GB
Expanded Security Maintenance for Applications is not enabled.
0 updates can be applied immediately.
Enable ESM Apps to receive additional future security updates.
See https://ubuntu.com/esm or run: sudo pro status
The list of available updates is more than a week old.
To check for new updates run: sudo apt update
tmpfs-root /media/root-rw tmpfs rw,relatime,inode64 0 0
overlayroot / overlay rw,relatime,lowerdir=/media/root-ro,upperdir=/media/root-rw/overlay,workdir=/media/root-rw/overlay-workdir/_ 0 0
/dev/sda1 /media/root-ro ext4 ro,relatime 0 0
The programs included with the Ubuntu system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Ubuntu comes with ABSOLUTELY NO WARRANTY, to the extent permitted by
applicable law.
root@scw-par:~# wget -qO- http://dl-cdn.alpinelinux.org/al ... t-3.11.9-x86_64.iso | dd of=/dev/vda
77824+0 records in
77824+0 records out
39845888 bytes (40 MB, 38 MiB) copied, 3.42086 s, 11.6 MB/s
root@scw-par:~# fdisk /dev/vda
Welcome to fdisk (util-linux 2.37.2).
Changes will remain in memory only, until you decide to write them.
Be careful before using the write command.
The device contains 'iso9660' signature and it will be removed by a write command. See fdisk(8) man page and --wipe option for more details.
Command (m for help): t
Partition number (1,2, default 2): 1
Hex code or alias (type L to list all): ef
Changed type of partition 'Empty' to 'EFI (FAT-12/16/32)'.
Command (m for help): w
The partition table has been altered.
Calling ioctl() to re-read partition table.
Syncing disks.
root@scw-par:~# lsblk
NAME    MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
loop0     7:0    0  63.3M  1 loop /snap/core20/1852
loop1     7:1    0 111.9M  1 loop /snap/lxd/24322
loop2     7:2    0  49.8M  1 loop /snap/snapd/18596
sda       8:0    0   9.3G  1 disk
├─sda1    8:1    0   2.1G  1 part /media/root-ro
├─sda14   8:14   0     4M  1 part
└─sda15   8:15   0   106M  1 part /boot/efi
vda     252:0    0   1.9G  0 disk
├─vda1  252:1    0    38M  0 part
└─vda2  252:2    0   1.4M  0 part
 楼主| 发表于 2023-4-27 11:58:33 | 只看该作者
然后 power off,  Use local boot->Save, power on , 控制台显示
EDK II
Mapping table
     BLK0: Alias(s):
     BLK1: Alias(s):
     BLK2: Alias(s):
Shell>
发表于 2023-4-27 12:05:13 | 只看该作者
没必要用这个系统,我按照帖子安完了,但是系统几乎没法用
 楼主| 发表于 2023-4-27 12:33:28 | 只看该作者
尝尝鲜嘛,我第一次用
 楼主| 发表于 2023-4-27 12:34:29 | 只看该作者
流星 发表于 2023-4-27 11:42
Mapping table        ...
我重新弄了一遍,还是相同的错误, 5楼是输出
发表于 2023-4-27 12:44:25 来自手机 | 只看该作者
我没有poweroff poweron的操作,直接网页上点reboot的,不知道是不是这个区别
GMT+8, 2026-5-6 06:13 , Processed in 0.065480 second(s), 10 queries , Gzip On, MemCache On.
