CeraNetworks网络延迟测速工具IP归属甄别
查看: 4178|回复: 5
KT对云服务器性能充满信心
发表于 2012-4-7 00:44:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
亲爱的Krypt经销商,
Krypt请您阅读这篇文章:http://blog.vpls.net/2012/03/27/putting-our-cloud-servers-to-the-test/,了解与独享Atom D525服务器相比,我们的云服务器同样具有卓越的性能。在云服务器和专用服务器之间似乎一直存在着些许奥秘,尤其是我们最卓越的Atom D525与云服务器相比较。近日,我们的工程师以Atom D525 1.8GHz服务器为基准,对我们的云服务器进行了测试,其结果会另大多数客户感到惊喜,但却在我们的意料之中。Krypt一直以来都对我们的云服务器性能充满信心,我们使用行业流行的Passmark工具为性能测试基准。
服务器 1:
Atom D525 1.8GHz
2GB RAM DDR3
80GB HDD SATA 7200RPM
服务器2:
云服务器
1GHz 独享
1GB RAM独享
RAID10 SAN支持存储
服务器3:
云服务器
2GHz 独享
2GB RAM 独享
RAID10 SAN 支持存储
服务器4:
云服务器
4GHz 仅突发
4GB RAM仅突发
RAID10 SAN支持存储
总结果:
                               Atom D525        1/1 Cloud        2/2 Cloud        4/4 Burst Cloud
CPU Mark                859.7                 674                    1010.6                1123.8
Memory Mark        328.7                 335.1                 684.4                  692.9
Disk Mark                910.7                 682.1                 786.9                 989.1
PassMark Rating    510.9                 431.2                 673.6                 780.4
正如您所见,云服务器2的性能明显超越了Atom D525。虚拟环境的最大优势不仅在于性能卓越,而且其扩展空间。虚拟与独享相比通常都会扩展地更快,更有效。
更多技术细节请您比较此文章中的表格。
感谢您的支持!
KPP
Dear Krypt Resellers,
Please read this article, http://blog.vpls.net/2012/03/27/putting-our-cloud-servers-to-the-test/ and get to know why you should look at our cloud servers as the performance is the same if not better than a dedicated atom. There has always been a mystery between the Cloud and Dedicated.  Especially, our most notable Atom D525 verses the Cloud servers.  Recently, our engineers decided it’s time we demystified this and to bench mark our Cloud servers and the Atom.
Server 1:
Atom D525 1.8GHz
2GB RAM DDR3
Server 2:
Cloud Server
1GHz Dedicated
1GB RAM Dedicated
RAID10 SAN backed storage
Server 3:
Cloud Server
2GHz Dedicated
2GB RAM Dedicated
Server 4:
Cloud Server
4GHz Burst Only
4GB RAM Burst Only
Overall Results:
As you can see, The Cloud server 2 most definitely out performs the Atom D525.  Virtual Environment has the greatest Advantage not only from a performance view but at the scaling level too.  Virtual will always scale faster and efficiently compared to Dedicated.
To get the full technical details please review the Bench mark chart.
Thanks!
KPP
发表于 2012-4-10 12:48:14 | 只看该作者
可惜我对他没信心
发表于 2012-4-10 14:07:53 | 只看该作者
一般般吧,云其实都是浮云
发表于 2012-4-10 14:33:04 | 只看该作者
脑残了吧。  拿凌动的CPU来做对比,还信誓旦旦的有信心???
一个奔腾双核或者老的 i3, 立马拿下最高性能云。
 楼主| 发表于 2012-4-10 14:57:34 | 只看该作者
楼上各位的回复,KT的官方客服看到要伤心了。哈哈。
不过人家开篇就说了:与独享Atom D525服务器相比
发表于 2012-4-10 15:28:27 | 只看该作者
是这样啊。  比性能拿个 Atom D525, 这个就是关键所在 。
起码拿个  i3 - 2100 吧。   现在买机器, 除了1000 - 2000的上网本带 D525, 还有谁会考虑这个?
就D525 这个性能, 能超频不? 即使超频也弱爆了吧。
当然KT的云定价也算合理, 不过我刚刚试着配了他的测试的最高的这款,
4GHz Burst,  2G内存,  40G 硬盘,  500G流量每月,   到 $ 199 了。
这价格 可以拿到 E5, E3, I7 了吧 ???
E5, E3, i7  那是什么性能?  D525 10 个, 也靠不上边。  一个 D525 PM评分是 680 左右, 10个 也就 6800, 一个 i7-2600 的得分, 印象中就 8000 了。
小白看看就当玩笑了,同行们心里也都比我明白。
当然也别当真,机房忽悠是正常的,当真您就输了。
GMT+8, 2026-4-15 01:52 , Processed in 0.063331 second(s), 11 queries , Gzip On, MemCache On.
