查看: 4410|回复: 14
[特价VPS] 收到vir警告信
发表于 2023-4-17 03:04:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
vir老板修改tos果然还是触发了,记录下信件,以后开oneman时强关mjj的小鸡能用上
流量警告
14天只允许用一半的流量(老板曾表示:东京的流量你们全用掉我就亏光**了)
  1. [Alert] Please normalize your network usage on: MJJ-VM
  2. While you may utilize your entire bandwidth allocation, please note that your share of bandwidth is expected to be utilized throughout the month to avoid network congestion.
  3. Your service was found to use more than 10% of your entire month of bandwidth in under 24 hours and/or above 50% of your entire month's bandwidth in under 14 days. This is just an advisory message and no action has been taken. If you did not expect this level of usage, we highly recommend checking your virtual server to ensure everything is running correctly and free of malware.
CPU警告
母鸡一直被爆屮,cpu动不动100%占用,硬盘读写就会随机卡一下
  1. Please reduce your CPU usage on "MJJ-VM"
  2. Hello,
  3. When you purchased your service, you opted in for the standard level of processing power, which is a semi-shared CPU.
  4. We've noticed that your service has been using lots of processing power, or more specifically 122.22% CPU for multiple hours. We just need you to reduce your usage to fall in line with our standard AUP, which allows you to burst to 100% but needs to be at a lower amount on average. You also have the option to have your CPU be dedicated to you, in which case you may purchase the high CPU addon if it's available for your plan.
  5. The system we used to identify your server's potential abuse is simple but unfortunately does not give us logs as to what occurred on your server that caused the higher usage. The system measures the CPU for each VPS separately over a 2 hour period and provides us the usage value that we've provided above to you, if that value is higher than what is allotted to your server according to our AUP more than 3 times in one week then we send out this warning.
  6. Please let us know if you have any questions or feel that this message was sent in error. We require an action (reducing usage or purchasing a dedicated core) or your service may be temporarily powered off in the future. We would like to ensure you and others have the best experience possible.
  7. Thank you.
CPU强制关机
  1. [Shutdown] Your service "MJJ-VM" is using high amounts of CPU
  2. Your service comes with a "fair share" CPU, as you do not have the dedicated "high CPU" addon. While we allow you to burst up to 100% of the core(s) you receive on your service, we have fair limits in place to reduce cost & ensure the best server performance for everyone. Unfortunately, your service is believed to have been using constant high levels of CPU. Your service was found to use an average of 144.44% CPU for multiple hours. As a result, your service has been powered off. Your server is not suspended and can be booted back up by pressing Boot from the service page.
  3. CAUTION: Please read this message before powering your service back on.
  4. Please either reduce your usage to fit in line with our AUP, or purchase the High CPU Addon, if it's available for your plan, which allows you to constantly utilize 100% processing power. If the high usage continues without the appropriate high CPU addon, your service may be powered off again or suspended.
  5. Feel free to reply to this ticket if you need assistance purchasing this addon, have any questions in regards to our policies or believe that this was sent in error.
  6. You may purchase the appropriate addon below:
  7. https://virmach.com/manage/cart.php?gid=addons
  8. You may see our Acceptable Use Policy below:
  9. https://virmach.com/terms-conditions/#tab1
  10. We would also recommend considering an upgrade to a larger package with more processing power, as your service is constantly maxing out and running out of CPU.
发表于 2023-4-17 03:26:13 | 只看该作者
滥用没的说 封了好 给大家腾地方
发表于 2023-4-17 03:59:19 来自手机 | 只看该作者
的确太苛刻了,有一个好几年的圣何塞不准备续费了
发表于 2023-4-17 04:00:34 | 只看该作者
1天100G,的确算是大客户了。我一年也就100G左右。从来没找过我的麻烦。
发表于 2023-4-17 07:39:18 | 只看该作者
* Linux常用命令:shutdown -h now 关闭系统
* 资源 https://t.me/MJJ_aliyundrive
* MJJ频道 https://t.me/wearemjj
* Linux命令大全 https://www.linuxcool.com
* DNS设置大全 https://dns.iui.im/
* 优质导航大全 https://www.chaidu.com/
* HostLoc频道 https://t.me/myhostloc
* A1Plus & G Suit & Workspace教育全局号https://sourl.cn/xq7iAZ
* OneDrive1T/5T网盘批发 iCloud苹果个人200G号https://nanguo.in/shop?ref=awtyBzywo
发表于 2023-4-17 08:03:03 来自手机 | 只看该作者
vir太正常了
发表于 2023-4-17 08:24:16 来自手机 | 只看该作者
我还想收8.88 jp
发表于 2023-4-17 08:54:00 来自手机 | 只看该作者
不错。这个月已经用了十几个g了。
GMT+8, 2026-4-23 01:12 , Processed in 0.065924 second(s), 11 queries , Gzip On, MemCache On.
