查看: 1659|回复: 1
[秒出,不好意思了]明盘出台PQS Hinet 555
发表于 2023-4-13 16:20:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1C 555MB
无限流量@55Mbps(预设555G,工单无限免费重置)
一天可更换 100 次,您剩馀 100 次。不怕墙
1 动态V4,1静态V6
当前最便宜的Hinet机器了
續約價格¥555.00 CNY帳單周期年付下次付款日期2023-11-25
站内私信TG,工单Push出(需要你注册号账号)
剩余价值320+600=920出
  1. ** 正在测试IPv4解锁情况
  2. --------------------------------
  3. ** 您的网络为: Chunghwa Telecom (1.170.*.*)
  4. ============[ Multination ]============
  5. Dazn:                                        Yes (Region: TW)
  6. HotStar:                                No
  7. Disney+:                                Yes (Region: TW)
  8. Netflix:                                Yes (Region: TW)
  9. 有图比 Premium:                        Yes (Region: TW)
  10. Amazon Prime Video:                        Yes (Region: TW)
  11. TVBAnywhere+:                                Yes
  12. iQyi Oversea Region:                        TW
  13. Viu.com:                                No
  14. 有图比 CDN:                                Associated with [HINET]
  15. Netflix Preferred CDN:                        Associated with [Chunghwa Telecom] in [**ei ]
  16. Spotify Registration:                        Yes (Region: TW)
  17. Steam Currency:                        TWD
  18. =======================================
  19. ==============[ Taiwan ]===============
  20. KKTV:                                        Yes
  21. LiTV:                                        Yes
  22. MyVideo:                                Yes
  23. 4GTV.TV:                                Yes
  24. LineTV.TW:                                Yes
  25. Hami Video:                                Yes
  26. CatchPlay+:                                Yes
  27. HBO GO Asia:                                Yes (Region: TW)
  28. Bahamut Anime:                                Yes
  29. Bilibili Taiwan Only:                        Yes
  30. =======================================
  1. -------------------- A Bench.sh Script By Teddysun -------------------
  2. Version            : v2022-06-01
  3. Usage              : wget -qO- bench.sh | bash
  4. ----------------------------------------------------------------------
  5. CPU Model          : Intel(R) Xeon(R) CPU E5-2680 v2 [url=home.php?mod=space&uid=175]@[/url] 2.80GHz
  6. CPU Cores          : 1 @ 2799.980 MHz
  7. CPU Cache          : 16384 KB
  8. AES-NI             : Enabled
  9. VM-x/AMD-V         : Enabled
  10. Total Disk         : 3.9 GB (3.0 GB Used)
  11. Total Mem          : 513.6 MB (104.4 MB Used)
  12. Total Swap         : 555.0 MB (268.0 KB Used)
  13. System uptime      : 7 days, 6 hour 46 min
  14. Load average       : 0.12, 0.04, 0.01
  15. OS                 : Debian GNU/Linux 11
  16. Arch               : x86_64 (64 Bit)
  17. Kernel             : 5.10.0-21-amd64
  18. TCP CC             : bbr
  19. Virtualization     : KVM
  20. Organization       : AS3462 Data Communication Business Group
  21. Location           : Yuanlin / TW
  22. Region             : Taiwan
  23. ----------------------------------------------------------------------
  24. Not enough space for I/O Speed test!
  25. ----------------------------------------------------------------------
  26. Node Name        Upload Speed      Download Speed      Latency
  27. Speedtest.net    55.55 Mbps        54.42 Mbps          3.84 ms
  28. Los Angeles, US  57.47 Mbps        53.86 Mbps          232.31 ms
  29. Dallas, US       62.85 Mbps        54.15 Mbps          232.31 ms
  30. Montreal, CA     59.85 Mbps        55.55 Mbps          257.97 ms
  31. Paris, FR        57.02 Mbps        55.15 Mbps          275.50 ms
  32. Amsterdam, NL    61.25 Mbps        54.56 Mbps          219.41 ms
  33. Shanghai, CN     56.85 Mbps        53.40 Mbps          53.91 ms
  34. Nanjing, CN      48.48 Mbps        53.73 Mbps          115.07 ms
  35. Guangzhou, CN    7.71 Mbps         52.24 Mbps          31.09 ms
  36. Hongkong, CN     56.93 Mbps        54.48 Mbps          52.11 ms
  37. Singapore, SG    56.27 Mbps        53.94 Mbps          83.15 ms
  38. Tokyo, JP        56.62 Mbps        53.55 Mbps          92.14 ms
  39. ----------------------------------------------------------------------
  40. Finished in        : 6 min 14 sec
  41. Timestamp          : 2023-04-13 04:16:04 EDT
  42. ----------------------------------------------------------------------
发表于 2023-4-13 16:24:01 | 只看该作者
已发tg,我要了
GMT+8, 2026-4-21 17:33 , Processed in 0.057993 second(s), 9 queries , Gzip On, MemCache On.
