查看: 3112|回复: 17
[美国VPS] Hetnzer账户被黑,上个月被刷了9台服务器,290欧元
发表于 2023-3-15 12:42:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
很久没有登Hetnzer,邮箱突然收到账单290欧,进去看了下,九台服务器在运行,查看上个月登陆ip是45.136.248.X、45.154.98.X、45.140.174.X,请问写工单减免费用有希望吗?
 楼主| 发表于 2023-3-15 20:13:28 | 只看该作者
Hetnzer把账单销掉了,不用给了,大家尽量要二次验证
Support - Hetzner Online GmbH
18:49 (1小时前)
发送至 我
Dear Mr Woo
we have removed the invoice and set the balance to € 0.
Please enable 2FA for your account to secure it better.
Kind regards
Customer Data Analytics
Hetzner Online GmbH
Sigmundstrasse 135
90431 Nürnberg
发表于 2023-3-15 12:44:01 | 只看该作者
这个估计没戏
发表于 2023-3-15 12:45:12 | 只看该作者
HZ的密码设置要很复杂的,这别人怎么黑的?
 楼主| 发表于 2023-3-15 12:47:04 | 只看该作者
我也搞不清楚,刚看到官网有个提醒是钓鱼邮箱:
Phishing emails are currently being sent in the name of Hetzner. You can identify the email by the following signs:
- Subject: Hetzner: Ihr Domainname wurde gesperrt. / Ihr Domainname läuft innerhalb von 3 Tagen ab.
- Sender: "'ce04676a@atlasfisio.es" / "d94e7079@vurpillat.org" / "'8bde0c4d@atlasfisio.es" / Customer Service-TravelCenter "customerservice@travelcenter.uk" / Hetzner Online GmbH "04c7bb95@atlasfisio.es"
It tries to get you to go to a fake login site for Hetzner Accounts so that it can steal your login data. Do not open this email or click on any links it contains. If you accidentally went to this phishing site and entered your login data, please contact our support team as soon as possible. Write a support request using your account on konsoleH, Robot or Cloud Console. If that is not possible, call the relevant support team. If you are able to, we also recommend that you immediately change your password and that you delete the phishing mail.
You could also enable 2-Factor-Authentication (2FA) in Accounts which helps to protect your account.
发表于 2023-3-15 12:49:15 | 只看该作者
服务器有开通邮件,一个月了,你没发现?
 楼主| 发表于 2023-3-15 12:50:38 | 只看该作者
奧巴马 发表于 2023-3-15 12:49
服务器有开通邮件,一个月了,你没发现?
我之前自己新建,有发邮箱,这个都没有
发表于 2023-3-15 12:57:59 来自手机 | 只看该作者
wooxiaowei 发表于 2023-3-15 12:50
我之前自己新建,有发邮箱,这个都没有
有可能用api开的?看看有没api?
发表于 2023-3-15 13:01:33 | 只看该作者
有点怕啊,二次验证登录会不会安全点,我就是用的authy。
发表于 2023-3-15 13:02:01 | 只看该作者
设置了二次验证吗?如果没有的话建议考虑一下密码泄露或者session被盗用。后面那种建议你检查一下其他常用账号。不然还会有其他账单的。别问我怎么知道,都是教训
发表于 2023-3-15 13:50:57 | 只看该作者
吓的我直接开二次验证
GMT+8, 2026-4-26 19:03 , Processed in 0.064343 second(s), 11 queries , Gzip On, MemCache On.
