查看: 1119|回复: 0
[疑问] 请教爱快异地组网 openv批恩
发表于 2023-3-11 13:26:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. 2023 Mar 11 Sat 13:12:38
  2. Open扶墙 2.4.7 i486-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
  3. 2023 Mar 11 Sat 13:12:38
  4. library versions: OpenSSL 1.0.2u 20 Dec 2019, LZO 2.10
  5. 2023 Mar 11 Sat 13:12:38
  6. WARNING: No server certificate verification method has been enabled. See http://open扶墙.net/howto.html#mitm for more info.
  7. 2023 Mar 11 Sat 13:12:38
  8. NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
  9. 2023 Mar 11 Sat 13:12:38
  10. WARNING: normally if you use --mssfix and/or --fragment, you should also set --tun-mtu 1500 (currently it is 1400)
  11. 2023 Mar 11 Sat 13:12:38
  12. TCP/UDP: Preserving recently used remote address: [AF_INET]公网IP:openv批恩服务端口
  13. 2023 Mar 11 Sat 13:12:38
  14. UDPv4 link local: (not bound)
  15. 2023 Mar 11 Sat 13:12:38
  16. UDPv4 link remote: [AF_INET]公网IP:open扶墙服务端口
上面是openv批恩的客户端日志
以下是openv批恩的服务端日志
异地两端都是爱快主路由,想实现异地组局域网互通。现在客户端始终连不上,不显示IP。
全部步骤都是按照官方指导的视频教程来的。
  1. 2023 Mar 11 Sat 04:31:10
  2. WARNING: Using --management on a TCP port WITHOUT passwords is STRONGLY discouraged and considered insecure
  3. 2023 Mar 11 Sat 04:31:10
  4. WARNING: POTENTIALLY DANGEROUS OPTION --verify-client-cert none|optional (or --client-cert-not-required) may accept clients which do not present a certificate
  5. 2023 Mar 11 Sat 04:31:10
  6. Open扶墙 2.4.7 i486-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
  7. 2023 Mar 11 Sat 04:31:10
  8. library versions: OpenSSL 1.0.2u 20 Dec 2019, LZO 2.10
  9. 2023 Mar 11 Sat 04:31:10
  10. NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
  11. 2023 Mar 11 Sat 04:31:10
  12. WARNING: normally if you use --mssfix and/or --fragment, you should also set --tun-mtu 1500 (currently it is 1400)
  13. 2023 Mar 11 Sat 04:31:10
  14. TUN/TAP device so扶墙 opened
  15. 2023 Mar 11 Sat 04:31:10
  16. /sbin/ifconfig so扶墙 10.7.7.1 netmask 255.255.255.0 mtu 1400 broadcast 10.7.7.255
  17. 2023 Mar 11 Sat 04:31:10
  18. Could not determine IPv4/IPv6 protocol. Using AF_INET
  19. 2023 Mar 11 Sat 04:31:10
  20. UDPv4 link local (bound): [AF_INET][undef]:【openv批恩服务端口】
GMT+8, 2026-1-12 14:14 , Processed in 0.057918 second(s), 9 queries , Gzip On, MemCache On.
