查看: 2446|回复: 11
[美国VPS] 【收】OVH KS-LE-1 14.99欧中奖款 溢价200
发表于 2023-2-23 17:05:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
剩余价值+溢价200。
要求v4 上下G口,v6有没有不重要,硬盘中奖没中奖不重要。
欧洲优先,先机(神仙除外)。
愿意出私聊我,发我参数截图
私信我联系方式。
附带出一台KS-LE-1 14.99欧中奖款  明盘300【已出】
V4下行G口 标配100M下行
V6双G口
硬盘两个1T SSD,算是小奖。
#              Yet-Another-Bench-Script              #
#                     v2022-12-29                    #
# https://github.com/masonr/yet-another-bench-script #
Wed Feb 22 09:43:19 UTC 2023
Basic System Information:
Uptime     : 0 days, 0 hours, 5 minutes
Processor  : Intel(R) Xeon(R) CPU E3-1245 V2 @ 3.40GHz
CPU cores  : 8 @ 1596.636 MHz
AES-NI     : ✔ Enabled
VM-x/AMD-V : ✔ Enabled
RAM        : 31.3 GiB
Swap       : 1024.0 MiB
Disk       : 1.7 TiB
Distro     : Ubuntu 18.04.6 LTS
Kernel     : 4.15.0-204-generic
fio Disk Speed Tests (Mixed R/W 50/50):
Read       | 188.81 MB/s  (47.2k) | 298.08 MB/s   (4.6k)
Write      | 189.31 MB/s  (47.3k) | 299.65 MB/s   (4.6k)
Total      | 378.13 MB/s  (94.5k) | 597.73 MB/s   (9.3k)
Read       | 400.72 MB/s    (782) | 393.32 MB/s    (384)
Write      | 422.01 MB/s    (824) | 419.52 MB/s    (409)
Total      | 822.73 MB/s   (1.6k) | 812.84 MB/s    (793)
Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
Clouvider       | London, UK (10G)          | 95.4 Mbits/sec  | 941 Mbits/sec   | 3.33 ms
Scaleway        | Paris, FR (10G)           | 95.4 Mbits/sec  | 941 Mbits/sec   | 4.75 ms
NovoServe       | North Holland, NL (40G)   | 95.2 Mbits/sec  | 938 Mbits/sec   | 11.4 ms
Uztelecom       | Tashkent, UZ (10G)        | 42.9 Mbits/sec  | 328 Mbits/sec   | 102 ms
Clouvider       | NYC, NY, US (10G)         | busy            | 663 Mbits/sec   | 82.9 ms
Clouvider       | Dallas, TX, US (10G)      | 26.4 Mbits/sec  | 121 Mbits/sec   | 114 ms
Clouvider       | Los Angeles, CA, US (10G) | 22.0 Mbits/sec  | 543 Mbits/sec   | 131 ms
iperf3 Network Speed Tests (IPv6):
Clouvider       | London, UK (10G)          | 914 Mbits/sec   | 928 Mbits/sec   | 3.51 ms
Scaleway        | Paris, FR (10G)           | 902 Mbits/sec   | 927 Mbits/sec   | 4.78 ms
NovoServe       | North Holland, NL (40G)   | 910 Mbits/sec   | 922 Mbits/sec   | 11.4 ms
Uztelecom       | Tashkent, UZ (10G)        | 844 Mbits/sec   | 403 Mbits/sec   | 101 ms
Clouvider       | NYC, NY, US (10G)         | 807 Mbits/sec   | 570 Mbits/sec   | 82.8 ms
Clouvider       | Dallas, TX, US (10G)      | 674 Mbits/sec   | 146 Mbits/sec   | 114 ms
Clouvider       | Los Angeles, CA, US (10G) | 594 Mbits/sec   | 349 Mbits/sec   | 131 ms
Geekbench 5 Benchmark Test:
Test            | Value
Single Core     | 896
Multi Core      | 3458
Full Test       | https://browser.geekbench.com/v5/cpu/20713791
YABS completed in 9 min 27 sec
ECC测试:
        Total Width: 64 bits
        Data Width: 64 bits
        Data Width: 64 bits
        Data Width: 64 bits
        Data Width: 64 bits
硬件信息:
                   This is the choice of Steins;Gate
  CPU 型号              Intel(R) Xeon(R) CPU E3-1245 V2 @ 3.40GHz
  CPU 核心              合计 4 核心,8 线程
  CPU 状态              当前主频 1913.367 MHz
  内存大小              32067 MB (186 MB 已用)
  交换分区              1023 MB (0 MB 已用)
  第 1 块硬盘           通电 12830 小时,型号 INTEL SSDSC2KB960G8
  第 2 块硬盘           通电 4957 小时,型号 INTEL SSDSC2KB960G8
  硬盘大小              1843.2 GB
  服务器时间            2023-02-22 09:42:58
  运行时间              0 days 0 hour 4 min
  系统负载              0.00, 0.00, 0.00
  虚拟化技术            No Virtualization Detected
  IPv4 地址             37.187.xxx.xxx
  IPv6 地址             2001:41d0:xxxx:xxxx
  运营商                AS16276 OVH SAS
  地理位置              FR, Hauts-de-France, Gravelines
  操作系统              Ubuntu 18.04.6 bionic (x86_64)
  系统内核              4.15.0-204-generic
  TCP 加速              cubic
  当前脚本版本          1.4.1.1
   ATTENTION  检测到你服务器里有固态硬盘,建议使用 fio 代替 dd 进行测试
              bash <(wget -qO- git.io/ceshi) -j
  顺序写入 (1st)        677 MB/s
  顺序写入 (2nd)        676 MB/s
  顺序写入 (3rd)        675 MB/s
  顺序写入 (4th)        677 MB/s
  顺序写入 (5th)        676 MB/s
  顺序写入 (avg)        676.3 MB/s
刚开通 IE区 无IPMI PUSH出
发表于 2023-2-23 17:08:04 | 只看该作者
E3-1245 v2
32 GB DDR3 (non-ECC) RAM
2x800 GB SATA SSD
100 Mbps bw unmetered
14.99 Eur + VAT
发表于 2023-2-23 17:31:22 | 只看该作者
中奖绝缘体
发表于 2023-2-23 17:34:12 | 只看该作者
燕十三丶 发表于 2023-2-23 17:08
E3-1245 v2
2x800 GB SATA SSD
老哥出吗
发表于 2023-2-23 18:36:36 | 只看该作者
兄弟 自用机 不出
 楼主| 发表于 2023-2-23 18:39:24 | 只看该作者
我楼下这个要么?加上机器和装机费,230左右。
发表于 2023-2-23 18:52:20 | 只看该作者
你这个是什么区的?
 楼主| 发表于 2023-2-23 18:53:54 | 只看该作者
MSN 发表于 2023-2-23 18:52
你这个是什么区的?
法国
发表于 2023-2-24 10:18:53 | 只看该作者
我主要想要ssd的呢。
GMT+8, 2026-4-17 07:22 , Processed in 0.062753 second(s), 10 queries , Gzip On, MemCache On.
