查看: 1672|回复: 21
[美国VPS] 某些冷门的域名居然不支持dnspod 和华为解析
发表于 2023-2-17 08:08:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
RT 换了阿里正常。。。
 楼主| 发表于 2023-2-17 08:25:13 | 只看该作者
改完NS服务器。。保存会自动改回默认。。发了工单。。说不支持。。。CF ali都可以
 楼主| 发表于 2023-2-17 08:26:22 | 只看该作者
没反。。DNSPOD和华为能添加上。。只是在注册商那改不了
发表于 2023-2-17 08:30:03 | 只看该作者
what 啥注册商?
是不是后面多了 个 .?
发表于 2023-2-17 08:51:51 | 只看该作者
确实存在这种情况,让注册商帮忙注册一下host或者Gluerecord就行了
 楼主| 发表于 2023-2-17 09:01:20 | 只看该作者
The Nameservers are not configured correctly for your .DE name(s), that is why we are failing to publish them. To test if a Nameserver is configured correctly for your .DE name you can use this tool: https://nast.denic.de/
You can find the test results for this case here: https://nast.denic.de/result/XX.de?ns1=bernie.dnspod.net&ns2=oleander.dnspod.net
Please note that the IP addresses of each Nameserver should differ by at least one number in any octet and at least one of them must be connected via IPv4. A zone file for your domain name should also be created on the DNS service provider's side in advance.
We recommend to contact the DNS service provider with these results for help. In the meantime, please use our default Nameservers to connect your domain name:
NS1.DNSOWL.COM
NS2.DNSOWL.COM
NS3.DNSOWL.COM
If anything isn't clear or if you need help with anything else please do not hesitate to contact us.
发表于 2023-2-17 09:12:13 | 只看该作者
why 发表于 2023-2-17 09:01
The Nameservers are not configured correctly for your .DE name(s), that is why we are failing to p ...
我去康康
发表于 2023-2-17 09:17:36 | 只看该作者
会不会namesilo的问题导致改不了
GMT+8, 2025-12-25 08:46 , Processed in 0.096840 second(s), 9 queries , Gzip On, MemCache On.
