查看: 2092|回复: 5
E5的onedrive通过alist挂载的,现在突然显示API过期?
发表于 2023-1-26 21:25:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
E5的onedrive通过alist挂载的,现在突然显示API过期?试了同样的网盘,rclone的挂载的还可以正常使用啊
这是什么情况
  1. AADSTS700082: The refresh token has expired due to inactivity. The token was issued on 2022-10-28T07:44:26.3329713Z and was inactive for 90.00:00:00. Trace ID: a3085f67-22fa-42c6-b8ca-0ebc92f15b00 Correlation ID: 71aa0axx-779b-4650-aa67-bf9c03d835ad Timestamp: 2023-01-26 13:19:13Z
 楼主| 发表于 2023-1-26 21:27:22 | 只看该作者
我一些使用相同API的rclone在一些vps上也不能用了,但相同配置的rclone网盘,在另一些VPS却正常使用
这是什么情况啊
  1. 2023/01/26 21:26:28 Failed to create file system for "lxx2:/": failed to get root: Get "https://graph.microsoft.com/v1.0/drives/b!ONeaAv7NFU2gJlr4VDdq7iVpKQvqSDZPvfj3FBCWYvKSnk3jx0Ra3xm6cf9m9M/root": couldn't fetch token - maybe it has expired? - refresh with "rclone config reconnect lxx2:": oauth2: cannot fetch token: 400 Bad Request
  2. Response: {"error":"invalid_grant","error_description":"AADSTS700082: The refresh token has expired due to inactivity. The token was issued on 2022-06-27T14:30:32.2902402Z and was inactive for 90.00:00:00.\r\nTrace ID: cc07cc2a-e10e-4c4e-96bd-727e8c236100\r\nCorrelation ID: 53a9fbxx-9521-479e-9196-533864f79a77\r\nTimestamp: 2023-01-26 13:26:27Z","error_codes":[700082],"timestamp":"2023-01-26 13:26:27Z","trace_id":"cc07ccxx-e10e-4c4e-96bd-727e8c236100","correlation_id":"53a9fxx7-9521-479e-9196-533864f79a77","error_uri":"https://login.microsoftonline.com/error?code=700082"}
发表于 2023-1-26 21:42:07 | 只看该作者
好像是几个月不刷新令牌自动失效
 楼主| 发表于 2023-1-26 21:52:31 | 只看该作者
chxin 发表于 2023-1-26 21:42
好像是几个月不刷新令牌自动失效
是啊,但rclone复制的配置同样的令牌在不同的鸡上面,有个别就不能用了
发表于 2023-1-26 22:44:54 | 只看该作者
是令牌过期了,不是API过期了。rclone应该会告诉你使用rclone config reconnect xxx:命令刷新令牌
发表于 2023-1-26 23:39:05 来自手机 | 只看该作者
Alist不是可以直接挂onedrive,为什么还要挂rclone呢,下载?
GMT+8, 2026-4-16 08:37 , Processed in 0.069037 second(s), 10 queries , Gzip On, MemCache On.
