查看: 2551|回复: 11
crunchbits 4.8刀2T大盘鸡测试
发表于 2023-1-24 15:55:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
2T HDD+测速
  1. Basic System Information:
  3. Uptime     : 0 days, 0 hours, 19 minutes
  4. Processor  : Intel(R) Xeon(R) CPU E5-2695 v4 [url=home.php?mod=space&uid=175]@[/url] 2.10GHz
  5. CPU cores  : 1 @ 2095.146 MHz
  6. AES-NI     : ✔ Enabled
  7. VM-x/AMD-V : ✔ Enabled
  8. RAM        : 940.7 MiB
  9. Swap       : 0.0 KiB
  10. Disk       : 2.0 TiB
  11. Distro     : Debian GNU/Linux 11 (bullseye)
  12. Kernel     : 5.10.0-21-amd64
  13. fio Disk Speed Tests (Mixed R/W 50/50):
  14. ---------------------------------
  15. Block Size | 4k            (IOPS) | 64k           (IOPS)
  16.   ------   | ---            ----  | ----           ----
  17. Read       | 3.09 MB/s      (773) | 43.10 MB/s     (673)
  18. Write      | 3.11 MB/s      (778) | 43.29 MB/s     (676)
  19. Total      | 6.20 MB/s     (1.5k) | 86.40 MB/s    (1.3k)
  20.            |                      |
  21. Block Size | 512k          (IOPS) | 1m            (IOPS)
  22.   ------   | ---            ----  | ----           ----
  23. Read       | 86.21 MB/s     (168) | 92.50 MB/s      (90)
  24. Write      | 90.79 MB/s     (177) | 98.67 MB/s      (96)
  25. Total      | 177.00 MB/s    (345) | 191.17 MB/s    (186)
  26. iperf3 Network Speed Tests (IPv4):
  27. ---------------------------------
  28. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  29. -----           | -----                     | ----            | ----            | ----
  30. Clouvider       | London, UK (10G)          | 984 Mbits/sec   | 142 Mbits/sec   | 142 ms
  31. Scaleway        | Paris, FR (10G)           | 965 Mbits/sec   | 133 Mbits/sec   | 155 ms
  32. NovoServe       | North Holland, NL (40G)   | 976 Mbits/sec   | 608 Mbits/sec   | 148 ms
  33. Uztelecom       | Tashkent, UZ (10G)        | 789 Mbits/sec   | 349 Mbits/sec   | 244 ms
  34. Clouvider       | NYC, NY, US (10G)         | 1.05 Gbits/sec  | 388 Mbits/sec   | 70.1 ms
  35. Clouvider       | Dallas, TX, US (10G)      | 1.05 Gbits/sec  | 571 Mbits/sec   | 68.8 ms
  36. Clouvider       | Los Angeles, CA, US (10G) | 1.07 Gbits/sec  | 712 Mbits/sec   | 43.7 ms
  37. iperf3 Network Speed Tests (IPv6):
  38. ---------------------------------
  39. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  40. -----           | -----                     | ----            | ----            | ----
  41. Clouvider       | London, UK (10G)          | 492 Mbits/sec   | 356 Mbits/sec   | 142 ms
  42. Scaleway        | Paris, FR (10G)           | busy            | 393 Mbits/sec   | 150 ms
  43. NovoServe       | North Holland, NL (40G)   | 730 Mbits/sec   | 635 Mbits/sec   | 148 ms
  44. Uztelecom       | Tashkent, UZ (10G)        | 748 Mbits/sec   | 269 Mbits/sec   | 243 ms
  45. Clouvider       | NYC, NY, US (10G)         | 1.03 Gbits/sec  | 329 Mbits/sec   | 70.1 ms
  46. Clouvider       | Dallas, TX, US (10G)      | 904 Mbits/sec   | 540 Mbits/sec   | 68.8 ms
  47. Clouvider       | Los Angeles, CA, US (10G) | 1.05 Gbits/sec  | 920 Mbits/sec   | 40.7 ms
  48. Geekbench 5 test failed. Run manually to determine cause.
  49. YABS completed in 9 min 2 sec
7G的SSD还行
  1. fio Disk Speed Tests (Mixed R/W 50/50):
  3. Block Size | 4k            (IOPS) | 64k           (IOPS)
  4.   ------   | ---            ----  | ----           ----
  5. Read       | 103.68 MB/s  (25.9k) | 142.12 MB/s   (2.2k)
  6. Write      | 103.95 MB/s  (25.9k) | 142.87 MB/s   (2.2k)
  7. Total      | 207.63 MB/s  (51.9k) | 284.99 MB/s   (4.4k)
  8.            |                      |
  9. Block Size | 512k          (IOPS) | 1m            (IOPS)
  10.   ------   | ---            ----  | ----           ----
  11. Read       | 123.90 MB/s    (242) | 90.92 MB/s      (88)
  12. Write      | 130.49 MB/s    (254) | 96.98 MB/s      (94)
  13. Total      | 254.40 MB/s    (496) | 187.90 MB/s    (182)
发表于 2023-1-24 16:00:42 | 只看该作者
7G SSD精髓,装个系统 装个网盘程序没问题 这家太懂用户需求了。
发表于 2023-1-24 16:01:49 | 只看该作者
infplus 发表于 2023-1-24 16:00
7G SSD精髓,装个系统 装个网盘程序没问题 这家太懂用户了。
可是这是个2022年的新商家,有点怕怕,我也买了一个1H4G的
发表于 2023-1-24 16:02:05 | 只看该作者
流量太少了就是
发表于 2023-1-24 16:02:25 | 只看该作者
但是机械盘这个速度很拉跨。。
发表于 2023-1-24 16:09:07 来自手机 | 只看该作者
凡是流量少的大盘鸡就是骗局,量你不会装满,然后空间就可以超售
发表于 2023-1-24 16:10:41 | 只看该作者
大盘鸡流量等于或者略高于容量的我一律不碰
发表于 2023-1-24 16:39:35 | 只看该作者
吹风秀跳刀 发表于 2023-1-24 16:02
但是机械盘这个速度很拉跨。。
这不就是大家需要的东西?一点固态装系统和网盘程序,剩下的全是大盘。
有固态盘的存在,他这样的话4K读取就没啥用了,顺序读写快就行。
他们家的锐龙也是 建站神机。很明显是用心在做产品的。
发表于 2023-1-24 16:42:27 | 只看该作者
有固态盘的存在,他这样的话4K读 ...
HH的2T大盘能跑到300MB/s,crunchbits这个不到100。。
发表于 2023-1-24 16:57:02 | 只看该作者
能跑满端口就行,他这个估计硬盘不够多 阵列速度不快,刚开机人也比较多。
GMT+8, 2026-5-2 14:28 , Processed in 0.076267 second(s), 11 queries , Gzip On, MemCache On.
