查看: 2241|回复: 9
月付14元土耳其机评测
发表于 2023-1-1 14:25:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
dehost.com.tr最低配,用完折扣约14人民币
  1. root@194:~# curl -sL yabs.sh | bash -s -- -
  2. # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## #
  3. #              Yet-Another-Bench-Script              #
  4. #                     v2022-12-04                    #
  5. # https://github.com/masonr/yet-another-bench-script #
  6. # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## #
  7. Sat 31 Dec 2022 01:04:00 PM EST
  8. Basic System Information:
  9. ---------------------------------
  10. Uptime     : 0 days, 0 hours, 3 minutes
  11. Processor  : Intel(R) Xeon(R) CPU E5-2695 v2 [url=home.php?mod=space&uid=175]@[/url] 2.40GHz
  12. CPU cores  : 2 @ 2393.999 MHz
  13. AES-NI     : ✔ Enabled
  14. VM-x/AMD-V : ❌ Disabled
  15. RAM        : 1.9 GiB
  16. Swap       : 0.0 KiB
  17. Disk       : 29.4 GiB
  18. Distro     : Debian GNU/Linux 11 (bullseye)
  19. Kernel     : 5.10.0-19-amd64
  20. fio Disk Speed Tests (Mixed R/W 50/50):
  21. ---------------------------------
  22. Block Size | 4k            (IOPS) | 64k           (IOPS)
  23.   ------   | ---            ----  | ----           ----
  24. Read       | 49.50 MB/s   (12.3k) | 206.72 MB/s   (3.2k)
  25. Write      | 49.58 MB/s   (12.3k) | 207.81 MB/s   (3.2k)
  26. Total      | 99.08 MB/s   (24.7k) | 414.53 MB/s   (6.4k)
  27.            |                      |
  28. Block Size | 512k          (IOPS) | 1m            (IOPS)
  29.   ------   | ---            ----  | ----           ----
  30. Read       | 373.94 MB/s    (730) | 383.73 MB/s    (374)
  31. Write      | 393.81 MB/s    (769) | 409.29 MB/s    (399)
  32. Total      | 767.76 MB/s   (1.4k) | 793.02 MB/s    (773)
  33. iperf3 Network Speed Tests (IPv4):
  34. ---------------------------------
  35. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  36. -----           | -----                     | ----            | ----            | ----
  37. Clouvider       | London, UK (10G)          | busy            | 573 Mbits/sec   | 56.5 ms
  38. Scaleway        | Paris, FR (10G)           | busy            | 559 Mbits/sec   | 53.0 ms
  39. NovoServe       | North Holland, NL (40G)   | busy            | 713 Mbits/sec   | 55.0 ms
  40. Uztelecom       | Tashkent, UZ (10G)        | 452 Mbits/sec   | 200 Mbits/sec   | 234 ms
  41. Clouvider       | NYC, NY, US (10G)         | busy            | 256 Mbits/sec   | 128 ms
  42. Performing IPv4 iperf3 send test to Clouvider (Attempt #3 of 3)...
  43. Clouvider       | Dallas, TX, US (10G)      | 509 Mbits/sec   | 169 Mbits/sec   | 160 ms
  44. Clouvider       | Los Angeles, CA, US (10G) | busy            | 269 Mbits/sec   | 183 ms
  45. Geekbench 5 Benchmark Test:
  46. ---------------------------------
  47. Test            | Value
  48.                 |
  49. Single Core     | 374
  50. Multi Core      | 611
  51. Full Test       | https://browser.geekbench.com/v5/cpu/19622930
  52. YABS completed in 12 min 16 sec
 楼主| 发表于 2023-1-1 14:27:23 | 只看该作者
  1. -------------------- A Bench Script By spiritlhl ---------------------
  3. 版本:2022.12.31
  4. 更新日志:融合怪九代目(集合百家之长)(专为测评频道小鸡而生)
  5. -----------------感谢teddysun和misakabench和yabs开源------------------
  6. CPU 型号          : Intel(R) Xeon(R) CPU E5-2695 v2 [url=home.php?mod=space&uid=175]@[/url] 2.40GHz
  7. CPU 核心数        : 2
  8. CPU 频率          : 2393.999 MHz
  9. CPU 缓存          : 30720 KB
  10. 硬盘空间          : 30.0 GB (2.0 GB 已用)
  11. 内存              : 1982 MB (111 MB 已用)
  12. Swap              : 0 MB (0 MB 已用)
  13. 系统在线时间      : 0 days, 10 hour 27 min
  14. 负载              : 0.23, 0.31, 0.19
  15. 系统              : Debian GNU/Linux 11 (bullseye)
  16. AES-NI指令集      : ✔ Enabled
  17. VM-x/AMD-V支持    : ❌ Disabled
  18. 架构              : x86_64 (64 Bit)
  19. 内核              : 5.10.0-19-amd64
  20. TCP加速方式       : cubic
  21. 虚拟化架构        : VMware
  22. ASN组织           : AS206995 TEKNOFIRST VERI MERKEZI YAZILIM BILISIM SANAYI VE TICARET LIMITED SIRKETI
  23. 位置              : Ankara / TR
  24. 地区              : Ankara
  25. -------------------CPU测试--感谢lemonbench开源------------------------
  26. -> CPU 测试中 (Fast Mode, 1-Pass @ 5sec)
  27. 1 线程测试(1核)得分:                 596 Scores
  28. 2 线程测试(多核)得分:                 1164 Scores
  29. -------------------内存测试--感谢lemonbench开源-----------------------
  30. -> 内存测试 Test (Fast Mode, 1-Pass @ 5sec)
  31. 单线程读测试:                11378.72 MB/s
  32. 单线程写测试:                7668.34 MB/s
  33. ----------------磁盘IO读写测试--感谢lemonbench开源--------------------
  34. -> 磁盘IO测试中 (4K Block/1M Block, Direct Mode)
  35. 测试操作                写速度                                        读速度
  36. 100MB-4K Block                17.0 MB/s (4139 IOPS, 6.18s)                16.7 MB/s (4073 IOPS, 6.28s)
  37. 1GB-1M Block                418 MB/s (398 IOPS, 2.51s)                969 MB/s (924 IOPS, 1.08s)
  38. -------------------磁盘IO读写测试--感谢yabs开源-----------------------
  39. Block Size | 4k            (IOPS) | 64k           (IOPS)
  40.   ------   | ---            ----  | ----           ----
  41. Read       | 49.67 MB/s   (12.4k) | 229.87 MB/s   (3.5k)
  42. Write      | 49.74 MB/s   (12.4k) | 231.08 MB/s   (3.6k)
  43. Total      | 99.42 MB/s   (24.8k) | 460.96 MB/s   (7.2k)           |                      |
  44. Block Size | 512k          (IOPS) | 1m            (IOPS)
  46. Read       | 383.85 MB/s    (749) | 347.88 MB/s    (339)
  47. Write      | 404.25 MB/s    (789) | 371.05 MB/s    (362)
  48. Total      | 788.10 MB/s   (1.5k) | 718.94 MB/s    (701)
  49. --------------------流媒体解锁--感谢sjlleo开源------------------------
  50. 以下测试的解锁地区是准确的,但是不是完整解锁的判断可能有误,这方面仅作参考使用
  51. 有图比
  52. [IPv4]
  53. 连接方式: Google Global CacheCDN (ISP Cooperation)
  54. ISP运营商: TURKCELL
  55. 视频缓存节点地域: ESB(ESB2)
  56. 有图比识别地域: 土耳其(TR)
  57. Netflix
  58. [IPv4]
  59. 您的出口IP完整解锁Netflix,支持非自制剧的观看
  60. NF所识别的IP地域信息:土耳其
  61. [IPv6]
  62. 您的网络可能没有正常配置IPv6,或者没有IPv6网络接入
  63. DisneyPlus
  64. [IPv4]
  65. 当前IPv4出口解锁DisneyPlus
  66. 区域:土耳其区
  67. 解锁有图比,Netflix,DisneyPlus上面和下面进行比较,不同之处自行判断
  68. ---------------流媒体解锁--感谢RegionRestrictionCheck开源-------------
  69. 以下为IPV4网络测试,若无IPV4网络则无输出
  70. ============[ Multination ]============
  71. Dazn:                                        No
  72. HotStar:                                Failed (Network Connection)
  73. Disney+:                                Yes (Region: TR)
  74. Netflix:                                Failed (Network Connection)
  75. 有图比 Premium:                        Yes (Region: TR)
  76. Amazon Prime Video:                        Unsupported
  77. TVBAnywhere+:                                Failed (Network Connection)
  78. iQyi Oversea Region:                        INTL
  79. Viu.com:                                No
  80. 有图比 CDN:                                Associated with [TURKCELL]
  81. Netflix Preferred CDN:                        Failed
  82. Spotify Registration:                        Yes (Region: TR)
  83. Steam Currency:                        Failed (Network Connection)
  84. =======================================
  85. 以下为IPV6网络测试,若无IPV6网络则无输出
  86. ----------------TikTok解锁--感谢superbench的开源脚本------------------
  87. TikTok               : Yes (Region: US)
  88. -----------------欺诈分数以及IP质量检测--本频道原创-------------------
  89. 得分仅作参考,不代表100%准确,IP类型如果不一致请手动查询多个数据库比对
  90. 欺诈分数(越低越好):0
  91. 匿名代理: No
  92. Tor出口节点: No
  93. 服务器IP: Yes
  94. 公共代理: No
  95. 网络代理: No
  96. 搜索引擎机器人: No
  97. abuse得分: 0
  98. IP2Location数据库IP类型: Data Center/Web Hosting/Transit
  99. ping0数据库IP类型:IDC机房IP
  100. Google搜索可行性:NO
  101. -----------------三网回程--感谢zhanghanyun/backtrace开源--------------
  102. 2022/12/31 23:32:25 正在测试三网回程路由...
  103. 2022/12/31 23:32:26 北京电信 219.141.136.12  电信163 [普通线路]
  104. 2022/12/31 23:32:26 北京联通 202.106.50.1    联通4837[普通线路]
  105. 2022/12/31 23:32:26 北京移动 221.179.155.161 移动CMI [普通线路]
  106. 2022/12/31 23:32:26 上海电信 202.96.209.133  电信163 [普通线路]
  107. 2022/12/31 23:32:26 上海联通 210.22.97.1     联通4837[普通线路]
  108. 2022/12/31 23:32:26 上海移动 211.136.112.200 移动CMI [普通线路]
  109. 2022/12/31 23:32:26 广州电信 58.60.188.222   电信163 [普通线路]
  110. 2022/12/31 23:32:26 广州联通 210.21.196.6    联通4837[普通线路]
  111. 2022/12/31 23:32:26 广州移动 120.196.165.24  移动CMI [普通线路]
  112. ------------------回程路由--感谢fscarmen开源及PR----------------------
  113. 依次测试电信,联通,移动经过的地区及线路,核心程序来由: ipip.net ,请知悉!
  114. 广州电信 58.60.188.222
  115. 1.38 ms  *  局域网
  116. 1.59 ms  *  局域网
  117. 5.06 ms  *  局域网
  118. 7.36 ms  *  局域网
  119. 2.23 ms  *  局域网
  120. 58.80 ms  AS3356  英国, 伦敦, level3.com
  121. 65.36 ms  AS3356  英国, 伦敦, level3.com
  122. 251.70 ms  AS4134  中国, 广东, 广州, chinatelecom.com.cn, 电信
  123. 274.86 ms  AS4134  中国, 广东, 广州, chinatelecom.com.cn, 电信
  124. 247.12 ms  AS134774  中国, 广东, 深圳, chinatelecom.com.cn, 电信
  125. 广州联通 210.21.196.6
  126. 1.41 ms  *  局域网
  127. 1.77 ms  *  局域网
  128. 4.82 ms  *  局域网
  129. 5.93 ms  *  局域网
  130. 3.49 ms  *  局域网
  131. 185.02 ms  AS3356  美国, 加利福尼亚州, 洛杉矶, level3.com
  132. 280.68 ms  AS3356  美国, 加利福尼亚州, 洛杉矶, level3.com
  133. 274.66 ms  AS4837  中国, 广东, 广州, chinaunicom.com, 联通
  134. 279.54 ms  AS4837  中国, 广东, 广州, chinaunicom.com, 联通
  135. 287.44 ms  AS17623  中国, 广东, 深圳, chinaunicom.com, 联通
  136. 274.15 ms  AS17623  中国, 广东, 深圳, chinaunicom.com, 联通
  137. 广州移动 120.196.165.2
  138. 1.60 ms  *  局域网
  139. 5.65 ms  *  局域网
  140. 6.06 ms  *  局域网
  141. 5.97 ms  *  局域网
  142. 2.24 ms  *  局域网
  143. 58.42 ms  AS3356  英国, 伦敦, level3.com
  144. 56.77 ms  AS3356  英国, 伦敦, level3.com
  145. 70.51 ms  AS58453  英国, 伦敦, chinamobile.com, 移动
  146. 250.57 ms  AS58453  中国, 广东, 广州, chinamobile.com, 移动
  147. 257.90 ms  AS9808  中国, 广东, 广州, chinamobile.com, 移动
  148. 258.55 ms  AS9808  中国, 广东, 广州, chinamobile.com, 移动
  149. 253.83 ms  AS9808  中国, 广东, 广州, chinamobile.com, 移动
  150. 250.65 ms  AS9808  中国, 广东, 广州, chinamobile.com, 移动
  151. 258.06 ms  AS56040  中国, 广东, 深圳, chinamobile.com, 移动
  152. --------网络测速--由teddysun和superspeed开源及spiritlhls整理----------
  153. 测速点位置         上传速度         下载速度         延迟
  154. speedtest         657.27 Mbps         746.84 Mbps         2.71 ms
  155. 洛杉矶                    253.94Mbps         581.19Mbps         190.95ms
  156. 新加坡                    379.31Mbps         807.42Mbps         213.89ms
  157. 中国香港           360.72Mbps         490.38Mbps         232.16ms
  158. 电信上海           232.00Mbps         473.29Mbps         273.76ms
  159. 电信广东广州5G         15.70Mbps         164.37Mbps         257.08ms
  160. 联通上海           312.24Mbps         13.17Mbps         272.95ms
  161. 联通湖南长沙         295.11Mbps         427.21Mbps         288.47ms
  162. 移动广西南宁         378.14Mbps         449.69Mbps         224.80ms
  163. 移动宁夏银川         12.43Mbps         40.47Mbps         481.15ms
  164. ----------------------------------------------------------------------
  165. 总共花费        : 11 分 59 秒
  166. 时间          : Sat Dec 31 23:40:26 EST 2022
  167. ----------------------------------------------------------------------
发表于 2023-1-1 15:21:08 来自手机 | 只看该作者
只能信用卡支付么??
发表于 2023-1-1 15:26:06 | 只看该作者
这个脚本能分享一下吗,感谢
 楼主| 发表于 2023-1-1 15:38:25 | 只看该作者
茎肛互撸娃 发表于 2023-1-1 15:21
只能信用卡支付么??
应该是没看到paypal
发表于 2023-1-1 15:40:24 | 只看该作者
山本大意失仙人 发表于 2023-1-1 15:26
这个脚本能分享一下吗,感谢
https://www.918789.cn/128.html
  1. bash <(wget -qO- --no-check-certificate https://gitlab.com/spiritysdx/za/-/raw/main/ecs.sh)
 楼主| 发表于 2023-1-1 15:54:19 | 只看该作者
这个脚本能分享一下吗,感谢
发表于 2023-1-1 16:06:39 | 只看该作者
发表于 2023-1-1 16:14:33 | 只看该作者
好谢谢
发表于 2023-1-1 18:39:47 | 只看该作者
本来也想搞台试试,结果付款不成功
GMT+8, 2026-4-16 03:16 , Processed in 0.070458 second(s), 10 queries , Gzip On, MemCache On.
