查看: 1938|回复: 9
DDP openvz 9刀年付这测速是什么意思?
发表于 2022-12-29 16:03:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
New Years 2022 1GB RAM OpenVZ SSD VPS -  (12/29/2022 - 12/28/2023)
Extra IP Address: 0 Extra IP
DDoS Protection: 20Gbps DDoS Protection (Network Level)
Operating System: Debian 10 64-bit
Network Speed: 1Gbps
-------------------- A Bench.sh Script By Teddysun -------------------
Version            : v2022-06-01
Usage              : wget -qO- bench.sh | bash
CPU Model          : Intel(R) Xeon(R) CPU E5-2690 0 @ 2.90GHz
CPU Cores          : 1 @ 3299.847 MHz
CPU Cache          : 20480 KB
AES-NI             : Enabled
VM-x/AMD-V         : Enabled
Total Disk         : 9.9 GB (1.1 GB Used)
Total Mem          : 1.0 GB (52.9 MB Used)
Total Swap         : 512.0 MB (31.3 MB Used)
System uptime      : 0 days, 0 hour 51 min
Load average       : 0.04, 0.31, 0.31
OS                 : Debian GNU/Linux 10
Arch               : x86_64 (64 Bit)
Kernel             : 4.19.0
TCP CC             :
Virtualization     : OpenVZ
Organization       : AS35913 DediPath
Region             : California
I/O Speed(1st run) : 213 MB/s
I/O Speed(2nd run) : 492 MB/s
I/O Speed(3rd run) : 526 MB/s
I/O Speed(average) : 410.3 MB/s
Speedtest.net    2073.36 Mbps      6753.13 Mbps        0.88 ms
Los Angeles, US  197.96 Mbps       1024.23 Mbps        1.73 ms
Dallas, US       468.21 Mbps       3591.64 Mbps        31.46 ms
Montreal, CA     213.19 Mbps       922.74 Mbps         78.72 ms
Paris, FR        398.35 Mbps       2128.85 Mbps        144.25 ms
Amsterdam, NL    518.76 Mbps       1139.63 Mbps        157.76 ms
Shanghai, CN     0.78 Mbps         16.97 Mbps          158.26 ms
Nanjing, CN      577.58 Mbps       3694.95 Mbps        148.14 ms
Guangzhou, CN    5.83 Mbps         94.20 Mbps          170.62 ms
Seoul, KR        113.16 Mbps       190.51 Mbps         177.71 ms
Singapore, SG    501.13 Mbps       2211.93 Mbps        171.51 ms
Tokyo, JP        358.16 Mbps       2197.68 Mbps        105.10 ms
Finished in        : 6 min 25 sec
Timestamp          : 2022-12-29 03:02:49 EST
发表于 2022-12-29 16:04:25 | 只看该作者
给你免费升级到10G口了
发表于 2022-12-29 16:07:56 | 只看该作者
我买的KVM速度很烂,才100M
  1. Thu Dec 29 00:27:00 EST 2022
  2. Basic System Information:
  3. ---------------------------------
  4. Uptime     : 0 days, 0 hours, 14 minutes
  5. Processor  : Intel(R) Xeon(R) CPU E5-2695 v2 [url=home.php?mod=space&uid=175]@[/url] 2.40GHz
  6. CPU cores  : 1 [url=home.php?mod=space&uid=175]@[/url] 2399.998 MHz
  7. AES-NI     : ✔ Enabled
  8. VM-x/AMD-V : ❌ Disabled
  9. RAM        : 486.7 MiB
  10. Swap       : 768.0 MiB
  11. Disk       : 18.9 GiB
  12. Distro     : CentOS Linux 7 (Core)
  13. Kernel     : 3.10.0-1160.81.1.el7.x86_64
  14. fio Disk Speed Tests (Mixed R/W 50/50):
  15. ---------------------------------
  16. Block Size | 4k            (IOPS) | 64k           (IOPS)
  17.   ------   | ---            ----  | ----           ----
  18. Read       | 44.99 MB/s   (11.2k) | 78.54 MB/s    (1.2k)
  19. Write      | 45.05 MB/s   (11.2k) | 78.95 MB/s    (1.2k)
  20. Total      | 90.04 MB/s   (22.5k) | 157.49 MB/s   (2.4k)
  21.            |                      |
  22. Block Size | 512k          (IOPS) | 1m            (IOPS)
  23.   ------   | ---            ----  | ----           ----
  24. Read       | 185.76 MB/s    (362) | 218.63 MB/s    (213)
  25. Write      | 195.63 MB/s    (382) | 233.19 MB/s    (227)
  26. Total      | 381.40 MB/s    (744) | 451.82 MB/s    (440)
  27. iperf3 Network Speed Tests (IPv4):
  28. ---------------------------------
  29. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  30. -----           | -----                     | ----            | ----            | ----
  31. Clouvider       | London, UK (10G)          | 70.6 Mbits/sec  | 31.9 Mbits/sec  | 143 ms
  32. Scaleway        | Paris, FR (10G)           | 38.0 Mbits/sec  | 64.2 Mbits/sec  | 166 ms
  33. NovoServe       | North Holland, NL (40G)   | 84.7 Mbits/sec  | 177 Mbits/sec   | 161 ms
  34. Uztelecom       | Tashkent, UZ (10G)        | busy            | 37.6 Mbits/sec  | 243 ms
  35. Clouvider       | NYC, NY, US (10G)         | busy            | 39.7 Mbits/sec  | 61.3 ms
  36. Clouvider       | Dallas, TX, US (10G)      | 23.4 Mbits/sec  | 63.8 Mbits/sec  | 39.3 ms
  37. Clouvider       | Los Angeles, CA, US (10G) | 133 Mbits/sec   | 138 Mbits/sec   | 6.15 ms
  38. iperf3 Network Speed Tests (IPv6):
  39. ---------------------------------
  40. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  41. -----           | -----                     | ----            | ----            | ----
  42. Clouvider       | London, UK (10G)          | 82.9 Mbits/sec  | 32.9 Mbits/sec  | 138 ms
  43. ping: ping6.online.net: Name or service not known
  44. Scaleway        | Paris, FR (10G)           | 23.7 Mbits/sec  | 22.0 Mbits/sec  |
  45. NovoServe       | North Holland, NL (40G)   | 21.5 Mbits/sec  | 214 Mbits/sec   |
  46. Uztelecom       | Tashkent, UZ (10G)        | 20.1 Mbits/sec  | 25.4 Mbits/sec  | 242 ms
  47. Clouvider       | NYC, NY, US (10G)         | 37.4 Mbits/sec  | 9.82 Mbits/sec  | 59.5 ms
  48. Clouvider       | Dallas, TX, US (10G)      | 70.0 Mbits/sec  | 83.6 Mbits/sec  | 31.5 ms
  49. Clouvider       | Los Angeles, CA, US (10G) | 111 Mbits/sec   | 185 Mbits/sec   |
  50. Geekbench 5 Benchmark Test:
  51. ---------------------------------
  52. Test            | Value
  53.                 |
  54. Single Core     | 352
  55. Multi Core      | 401
  56. Full Test       | https://browser.geekbench.com/v5/cpu/19572214
  57. YABS completed in 18 min 32 sec
 楼主| 发表于 2022-12-29 16:12:48 | 只看该作者
rooney 发表于 2022-12-29 16:04
给你免费升级到10G口了
脚本上写的 Network Speed: 1Gbps
发表于 2022-12-29 16:35:07 | 只看该作者
Frp大佬 发表于 2022-12-29 16:07
我买的KVM速度很烂,才100M
洛杉矶吗
发表于 2022-12-29 16:36:42 | 只看该作者
是的,洛杉矶 02号母鸡,但是11号母鸡的Ovz速度却比02号母鸡快点
发表于 2022-12-29 16:39:15 | 只看该作者
Speedtest.net    172.17 Mbps       58.51 Mbps          10.10 ms
Dallas, US       13.48 Mbps        14.74 Mbps          39.83 ms
Montreal, CA     113.12 Mbps       39.47 Mbps          90.48 ms
Paris, FR        43.25 Mbps        23.64 Mbps          143.75 ms
Amsterdam, NL    105.17 Mbps       7.14 Mbps           151.64 ms
Nanjing, CN      15.22 Mbps        6.57 Mbps           149.94 ms
Seoul, KR        44.99 Mbps        4.44 Mbps           144.38 ms
Singapore, SG    6.86 Mbps         2.55 Mbps           179.24 ms
Tokyo, JP        153.92 Mbps       28.32 Mbps          104.33 ms
我这速度说什么了吗?正让他们迁移下节点再试试
发表于 2022-12-29 17:08:07 | 只看该作者
那不是脚本上的
 楼主| 发表于 2022-12-29 17:19:18 | 只看该作者
larry 发表于 2022-12-29 17:08
那不是脚本上的
意思你就是ddp给我的模版是1g,但实际开的是10G?
GMT+8, 2026-5-1 02:39 , Processed in 0.075298 second(s), 10 queries , Gzip On, MemCache On.
