查看: 2818|回复: 18
[疑问] (已解决)dedipath带宽不足100Mbps客服的话我不明白
发表于 2022-12-29 14:26:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
刚刚买的dedipath kvm 10刀年付的机器,标的是1Gbps ,但是我用yabs脚本测速时带宽不到100M,我提交了工单,客户给我的话我看不明白,有没有懂英文的Mjj忙我翻译一下:
You are using a shared server bandwidth limitations will occur. But, after running a ping.pe scan i noticed you are dropping connection within the US which can be fixed via an IP swap.
百度机翻:
您正在使用共享服务器带宽限制。但是,在运行ping.pe扫描后,我注意到您正在断开美国境内的连接,这可以通过IP交换进行修复。
测速贴:dedipath 10刀年付KVM测评
https://loc.qiche.eu.org/thread-1119983-1-1.html
工单给客服要求换一个节点,给换了,不丢包了,速度也能达到G口的水平了!给客服点赞!
  1. Thu Dec 29 06:22:41 EST 2022
  2. Basic System Information:
  3. ---------------------------------
  4. Uptime     : 0 days, 0 hours, 9 minutes
  5. Processor  : Intel(R) Xeon(R) CPU E5-2670 0 @ 2.60GHz
  6. CPU cores  : 1 @ 2599.998 MHz
  7. AES-NI     : ✔ Enabled
  8. VM-x/AMD-V : ❌ Disabled
  9. RAM        : 486.7 MiB
  10. Swap       : 768.0 MiB
  11. Disk       : 18.9 GiB
  12. Distro     : CentOS Linux 7 (Core)
  13. Kernel     : 3.10.0-1160.81.1.el7.x86_64
  14. fio Disk Speed Tests (Mixed R/W 50/50):
  15. ---------------------------------
  16. Block Size | 4k            (IOPS) | 64k           (IOPS)
  17.   ------   | ---            ----  | ----           ----
  18. Read       | 49.14 MB/s   (12.2k) | 89.06 MB/s    (1.3k)
  19. Write      | 49.22 MB/s   (12.3k) | 89.53 MB/s    (1.3k)
  20. Total      | 98.36 MB/s   (24.5k) | 178.59 MB/s   (2.7k)
  21.            |                      |
  22. Block Size | 512k          (IOPS) | 1m            (IOPS)
  23.   ------   | ---            ----  | ----           ----
  24. Read       | 126.66 MB/s    (247) | 178.81 MB/s    (174)
  25. Write      | 133.39 MB/s    (260) | 190.72 MB/s    (186)
  26. Total      | 260.06 MB/s    (507) | 369.54 MB/s    (360)
  27. iperf3 Network Speed Tests (IPv4):
  28. ---------------------------------
  29. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  30. -----           | -----                     | ----            | ----            | ----
  31. Clouvider       | London, UK (10G)          | 783 Mbits/sec   | 159 Mbits/sec   | 130 ms
  32. Scaleway        | Paris, FR (10G)           | 771 Mbits/sec   | 115 Mbits/sec   | 137 ms
  33. NovoServe       | North Holland, NL (40G)   | 791 Mbits/sec   | 555 Mbits/sec   | 135 ms
  34. Uztelecom       | Tashkent, UZ (10G)        | 451 Mbits/sec   | 105 Mbits/sec   | 227 ms
  35. Clouvider       | NYC, NY, US (10G)         | 818 Mbits/sec   | 302 Mbits/sec   | 62.4 ms
  36. Clouvider       | Dallas, TX, US (10G)      | 814 Mbits/sec   | 272 Mbits/sec   | 30.7 ms
  37. Clouvider       | Los Angeles, CA, US (10G) | 888 Mbits/sec   | 708 Mbits/sec   | 5.47 ms
  38. iperf3 Network Speed Tests (IPv6):
  39. ---------------------------------
  40. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  41. -----           | -----                     | ----            | ----            | ----
  42. Clouvider       | London, UK (10G)          | 781 Mbits/sec   | 122 Mbits/sec   | 129 ms
  43. ping: ping6.online.net: Name or service not known
  44. Scaleway        | Paris, FR (10G)           | 790 Mbits/sec   | 143 Mbits/sec   |
  45. NovoServe       | North Holland, NL (40G)   | 762 Mbits/sec   | 557 Mbits/sec   | 135 ms
  46. Uztelecom       | Tashkent, UZ (10G)        | 458 Mbits/sec   | 54.2 Mbits/sec  | 227 ms
  47. Clouvider       | NYC, NY, US (10G)         | 811 Mbits/sec   | 265 Mbits/sec   | 62.4 ms
  48. Clouvider       | Dallas, TX, US (10G)      | 826 Mbits/sec   | 353 Mbits/sec   | 30.4 ms
  49. Clouvider       | Los Angeles, CA, US (10G) | 844 Mbits/sec   | 815 Mbits/sec   | 5.63 ms
  50. Geekbench 5 Benchmark Test:
  51. ---------------------------------
  52. Test            | Value
  53.                 |
  54. Single Core     | 486
  55. Multi Core      | 478
  56. Full Test       | https://browser.geekbench.com/v5/cpu/19576964
  57. YABS completed in 12 min 24 sec
发表于 2022-12-29 14:27:35 | 只看该作者
听不懂。啥玩意 啊 。断开美国境内的连接?
发表于 2022-12-29 14:41:05 来自手机 | 只看该作者
您正在使用共享服务器,是存在带宽限制的,因为带宽共享。但是,在运行ping.pe扫描后,我注意到,您服务器在美国境内存在断连,这可以通过改IP进行修复。
发表于 2022-12-29 14:48:13 | 只看该作者
意思是换IP吧?
你使用的是共享服务器,会出现带宽限制。但是,在运行ping.pe扫描后,我注意到你在美国境内的连接正在下降,这可以通过IP交换来解决。
发表于 2022-12-29 14:50:52 | 只看该作者
注意付费换ip后也不能解决问题
发表于 2022-12-29 14:51:34 | 只看该作者
 楼主| 发表于 2022-12-29 14:52:02 | 只看该作者
繁星若尘 发表于 2022-12-29 14:48
意思是换IP吧?
你使用的是共享服务器,会出现带宽限制。但是,在运行ping.pe扫描后,我注意到你在美国境 ...
问题是我IP没有被q啊,干嘛要换IP,这样不是浪费钱
 楼主| 发表于 2022-12-29 14:54:36 | 只看该作者
mayige 发表于 2022-12-29 14:50
注意付费换ip后也不能解决问题
嗯,不换IP,就这样先放阵子再说
发表于 2022-12-29 14:55:19 | 只看该作者
问问商家是免费换吗  是免费 就让他换,
你不换 美国境内链接也差,这就没法用吧。。。
发表于 2022-12-29 14:57:26 | 只看该作者
很多人说不要上车,非要硬着头皮上
我ddp的io最多就30M左右,还不如u盘、TF卡
  1. curl -sL yabs.sh | bash -s -- -ig
  2. fio Disk Speed Tests (Mixed R/W 50/50):
  4. Block Size | 4k            (IOPS) | 64k           (IOPS)
  5.   ------   | ---            ----  | ----           ----
  6. Read       | 11.46 MB/s    (2.8k) | 19.92 MB/s     (311)
  7. Write      | 11.47 MB/s    (2.8k) | 20.38 MB/s     (318)
  8. Total      | 22.94 MB/s    (5.7k) | 40.30 MB/s     (629)
  9.            |                      |
  10. Block Size | 512k          (IOPS) | 1m            (IOPS)
  11.   ------   | ---            ----  | ----           ----
  12. Read       | 14.42 MB/s      (28) | 18.91 MB/s      (18)
  13. Write      | 15.87 MB/s      (31) | 21.02 MB/s      (20)
  14. Total      | 30.30 MB/s      (59) | 39.94 MB/s      (38)
GMT+8, 2026-5-2 20:28 , Processed in 0.066256 second(s), 10 queries , Gzip On, MemCache On.
