查看: 2559|回复: 16
400 出 ExtraVM 日本闪购年付 $43.68
发表于 2022-12-9 10:21:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
- 联通移动友好
- 日本 NTT
- 5T流量
注意: 不能改邮箱,可以开二验
# 来源
https://lowendtalk.com/discussion/comment/3554150/#Comment_3554150
# 账单
  1. 帳單項目
  2. 描述                單價
  3. 1GB RAM - XXXXXX.vps.extravm.com (11/27/2022 - 11/26/2023) *        $62.40 USD
  4. Promotional Code: LETBFTOKYO - 30.00% Recurring Discount *        $-18.72 USD
  5. 小計        $43.68 USD
  6. 帳戶餘額        $0.00 USD
  7. 合計        $43.68 USD
# 规格
  1. CPU: 1 vCPU (E-2388G)
  2. RAM: 1GB DDR4
  3. Storage: 12GB NVMe SSD
  4. Bandwidth: 5TB [url=home.php?mod=space&uid=175]@[/url] 10Gbps down / 1 Gbps up DDoS Protection
  5. Dedicated IP: 1 IPv4 + 1 IPv6
  6. Location: Tokyo, Japan
  7. Quantity: 10
  8. Order Link: https://extravm.com/billing/store/kvm-nvme-vps-tokyo-japan-ddos-protected
  9. Promo code: LETBFTOKYO
  10. Start from $4.55/m
# YABS
  1. Tue 29 Nov 2022 10:33:27 PM CST
  2. Basic System Information:
  3. ---------------------------------
  4. Uptime     : 1 days, 14 hours, 28 minutes
  5. Processor  : Intel(R) Xeon(R) E-2388G CPU @ 3.20GHz
  6. CPU cores  : 1 @ 3192.000 MHz
  7. AES-NI     : ✔ Enabled
  8. VM-x/AMD-V : ✔ Enabled
  9. RAM        : 964.2 MiB
  10. Swap       : 0.0 KiB
  11. Disk       : 11.8 GiB
  12. Distro     : Debian GNU/Linux 10 (buster)
  13. Kernel     : 4.19.0-22-cloud-amd64
  14. fio Disk Speed Tests (Mixed R/W 50/50):
  15. ---------------------------------
  16. Block Size | 4k            (IOPS) | 64k           (IOPS)
  17.   ------   | ---            ----  | ----           ----
  18. Read       | 34.96 MB/s    (8.7k) | 279.51 MB/s   (4.3k)
  19. Write      | 35.07 MB/s    (8.7k) | 280.99 MB/s   (4.3k)
  20. Total      | 70.04 MB/s   (17.5k) | 560.51 MB/s   (8.7k)
  21.            |                      |
  22. Block Size | 512k          (IOPS) | 1m            (IOPS)
  23.   ------   | ---            ----  | ----           ----
  24. Read       | 688.30 MB/s   (1.3k) | 646.15 MB/s    (631)
  25. Write      | 724.87 MB/s   (1.4k) | 689.18 MB/s    (673)
  26. Total      | 1.41 GB/s     (2.7k) | 1.33 GB/s     (1.3k)
  27. iperf3 Network Speed Tests (IPv4):
  28. ---------------------------------
  29. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  30. -----           | -----                     | ----            | ----            | ----
  31. Clouvider       | London, UK (10G)          | busy            | 40.4 Mbits/sec  | 706 ms
  32. Scaleway        | Paris, FR (10G)           | 201 Mbits/sec   | busy            | 305 ms
  33. NovoServe       | North Holland, NL (40G)   | busy            | 324 Mbits/sec   | 242 ms
  34. Uztelecom       | Tashkent, UZ (10G)        | 64.7 Mbits/sec  | 609 Mbits/sec   |
  35. Clouvider       | NYC, NY, US (10G)         | 96.8 Mbits/sec  | 870 Mbits/sec   |
  36. Clouvider       | Dallas, TX, US (10G)      | 202 Mbits/sec   | 148 Mbits/sec   | 146 ms
  37. Clouvider       | Los Angeles, CA, US (10G) | 549 Mbits/sec   | 704 Mbits/sec   | 99.2 ms
  38. iperf3 Network Speed Tests (IPv6):
  39. ---------------------------------
  40. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  41. -----           | -----                     | ----            | ----            | ----
  42. Clouvider       | London, UK (10G)          | 124 Mbits/sec   | 303 Mbits/sec   | 230 ms
  43. Scaleway        | Paris, FR (10G)           | busy            | busy            |
  44. NovoServe       | North Holland, NL (40G)   | 238 Mbits/sec   | 458 Mbits/sec   | 244 ms
  45. Uztelecom       | Tashkent, UZ (10G)        | busy            | busy            |
  46. Clouvider       | NYC, NY, US (10G)         | 195 Mbits/sec   | 550 Mbits/sec   | 159 ms
  47. Clouvider       | Dallas, TX, US (10G)      | 403 Mbits/sec   | 861 Mbits/sec   | 146 ms
  48. Clouvider       | Los Angeles, CA, US (10G) | 295 Mbits/sec   | 1.41 Gbits/sec  | 99.1 ms
  49. Geekbench 5 test failed. Run manually to determine cause.
# 网络
  1. China, Beijing        Aliyun        25.7%        101        63.76        65.1        63.43        80.53        3.41        show
  2. China, Beijing        Tencent        0%        101        60.81        60.74        60.09        61.64        0.36        show
  3. China, Jiangsu        China Telecom        15.8%        101        59.02        58.53        47.51        97.21        8.65        show
  4. China, Jiangsu        China Mobile        0%        101        74.14        73.6        72.99        74.89        0.42        show
  5. China, Jiangsu        China Unicom        0%        101        48.73        48.75        48        50.12        0.41        show
  6. China, Hangzhou        Aliyun        15.8%        101        54.81        56.13        49.27        61.62        2.14        show
  7. China, Qingdao        Aliyun        0%        101        153.71        154.28        153.62        159.98        0.7        show
  8. China, Zhejiang        China Telecom        18.8%        101        59.2        57.62        48.91        88.51        7.55        show
  9. China, Shanghai        Aliyun        19.8%        101        51.56        53.47        41.5        94.16        7.94        show
  10. China, Shanghai        Aliyun        0%        101        37.48        37.5        37.08        42.76        0.56        show
发表于 2022-12-9 10:22:37 | 只看该作者
大佬还是打算出了啊
这家估计被机场撸疼了,已改条款和线路。。
Tokyo, Japan - As of November 10, 2022, new plans are limited to 5TB, 10TB, and 20TB bandwidth instead of unmetered due to large scale abuse of our terms. More bandwidth can be added for free for legitimate use cases.
Important: Unmetered bandwidth is considered as fair use and not guaranteed. We do not allow applications and use cases such as torrent seeding, CDN nodes, proxy/扶墙 tunnels, or blockchain nodes.
日本东京 - 自 2022 年 11 月 10 日起,由于大规模滥用,我们的新计划限制为 5TB、10TB 和 20TB 带宽,而不是不按流量计费。 可以为合法用例免费添加更多带宽。
重要提示:未计量的带宽被视为合理使用且无法保证。 我们不允许使用种子下载、CDN 节点、代理/扶墙 隧道或区块链节点等应用程序。
发表于 2022-12-9 10:21:42 | 只看该作者
不是不能改邮箱吗?
发表于 2022-12-9 10:23:22 | 只看该作者
联通不是软银?
发表于 2022-12-9 10:23:33 | 只看该作者
你也收到邮件了啊
 楼主| 发表于 2022-12-9 10:23:48 | 只看该作者
CMT 发表于 2022-12-9 10:21
不是不能改邮箱吗?
不能改邮箱,可以开二验
 楼主| 发表于 2022-12-9 10:25:15 | 只看该作者
mourner 发表于 2022-12-9 10:23
你也收到邮件了啊
你是说商用扶墙吗?自用应该没有事。我是用来建站的。
发表于 2022-12-9 10:26:10 | 只看该作者
对,那没事了。
哎,又是一家被mjj曹蓝的商家
 楼主| 发表于 2022-12-9 10:26:59 | 只看该作者
mourner 发表于 2022-12-9 10:26
对,那没事了。
哎,又是一家被mjj曹蓝的商家
给的流量太多,这不是给别人乱玩的机会吗?!~
发表于 2022-12-9 10:28:01 来自手机 | 只看该作者
流量确实多 贵也是真贵…  ntt不是说很垃圾吗..
GMT+8, 2026-5-2 07:38 , Processed in 0.062366 second(s), 11 queries , Gzip On, MemCache On.
