查看: 816|回复: 0
AMD高防云服务器 5950X游戏云 1核2G 30G NVMe 仅需12.5元/月
发表于 2022-12-6 17:47:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
GFRack是智简魔方付费专业版商家 使用5000元财务主控 1000元单个母鸡VPS被控 稳定靠谱 支持按天付款
查询地址:https://www.idcsmart.com/verifydomain.html
GFRack为所有mjj定制五折优惠码:mjj
AMD Ryzen高性能云服务器:采用AMD Ryzen 处理器,超高性能、支持随时升级/降级,可选法国,加拿大机房,无计量防御、支持Windows/Linux系统
1核2G内存 50G NVMe 100M带宽 12.5元/月(优惠码:mjj)
购买链接:https://www.gfrack.com/cart?fid=1&gid=6
高频NAT游戏云:采用AMD Ryzen 9 5950X处理器,超高性能、支持随时升级/降级,支持Windows/Linux系统、适用于开设MC服和各类游戏服。
1核2G内存 30G NVMe 5M带宽 12.5元/月(优惠码:mjj)
购买链接:https://www.gfrack.com/cart?fid=1&gid=8
5950X游戏云柠檬脚本跑分
  1. LemonBench Server Test Tookit 20201005 Intl BetaVersion (C)iLemonrain. All Rights Reserved.
  2. ==========================================================================================
  3. [Info] Bench Start Time: 2022-10-01 16:59:31
  4. [Info] Test Mode: Fast Mode
  5. -> System Information
  6. OS Release:            Debian GNU/Linux "Sid (Testing)" 11.3 (x86_64)
  7. CPU Model:             AMD Ryzen 9 5950X 16-Core Processor  3.39 GHz
  8. CPU Cache Size:        512 KB
  9. CPU Number:            2 vCPU
  10. VirtReady:             Yes (Nested Virtualization)
  11. Virt Type:             KVM
  12. Memory Usage:          122.58 MB / 3.84 GB
  13. Swap Usage:            [ No Swapfile/Swap Partition ]
  14. Boot Device:           /dev/vda1
  15. Disk Usage:            1.08 GB / 61.75 GB
  16. CPU Usage:             0.0% used, 0.0% iowait, 0.0% steal
  17. Load (1/5/15min):      1.59 0.37 0.12
  18. Uptime:                0 Days, 1 Hours, 3 Minutes, 34 Seconds
  19. Kernel Version:        5.10.0-14-cloud-amd64
  20. Network CC Method:     cubic + pfifo_fast
  21. -> Network Infomation
  22. -> Media Unlock Test
  23. HBO Now:                               No
  24. Bahamut Anime:                         Failed (due to parse fail)
  25. Abema.TV:                              No
  26. Princess Connect Re:Dive Japan:        No
  27. BBC:                                   No
  28. BiliBili China Mainland Only:          Yes
  29. BiliBili Hongkong/Macau/Taiwan:        No
  30. Bilibili Taiwan Only:                  No
  31. -> CPU Performance Test (Fast Mode, 1-Pass [url=home.php?mod=space&uid=175]@[/url] 5sec)
  32. 1 Thread Test:                 4734 Scores
  33. 2 Threads Test:                9288 Scores
  34. -> Memory Performance Test (Fast Mode, 1-Pass [url=home.php?mod=space&uid=175]@[/url] 5sec)
  35. 1 Thread - Read Test :         54145.65 MB/s
  36. 1 Thread - Write Test:         31236.09 MB/s
  37. -> Disk Speed Test (4K Block/1M Block, Direct Mode)
  38. Test Name              Write Speed                             Read Speed
  39. 100MB-4K Block         102 MB/s (0.04 IOPS, 1.03s))            125 MB/s (30413 IOPS, 0.84s)
  40. 1GB-1M Block           1.9 GB/s (1820 IOPS, 0.55s)             5.5 GB/s (5278 IOPS, 0.19s)
  41. -> Speedtest.net Network Speed Test
  42. Node Name                      Upload Speed    Download Speed  Ping Latency    Server Name
  43. Speedtest Default              1.12 MB/s       110.18 MB/s     25.45 ms        China Unicom HeNan 5G (China Zhengzhou)
  44. China, Beijing CU              Fail: Timeout Exceeded after 60 seconds
  45. China, Shanghai CT             1.13 MB/s       107.18 MB/s     24.68 ms        China Telecom (China Shanghai)
  46. China, Hangzhou CM             Fail: Timeout Exceeded after 60 seconds
  47. ==========================================================================================
  48. [Info] Bench Finish Time: 2022-10-01 17:01:47
  49. [Info] Time Elapsed: 136 seconds
  50. [Info] Please wait, collecting results ...
  51. [Info] Generating Report ...
  52. [Info] Saving local Report ...
  53. [Info] Generating Report URL ...
  54. [Success] Report Generate Success!Please save the follwing link:
  55. [Info] Report URL: https://paste.ubuntu.com/p/WCNkBsyrb7/
法国锐龙yabs脚本跑分
  1. ---------------------------------
  2. Uptime     : 0 days, 0 hours, 1 minutes
  3. Processor  : AMD Ryzen 7 3800X 8-Core Processor
  4. CPU cores  : 1 [url=home.php?mod=space&uid=175]@[/url] 3899.992 MHz
  5. AES-NI     : ✔ Enabled
  6. VM-x/AMD-V : ✔ Enabled
  7. RAM        : 1.9 GiB
  8. Swap       : 0.0 KiB
  9. Disk       : 29.5 GiB
  10. Distro     : Debian GNU/Linux 11 (bullseye)
  11. Kernel     : 5.10.0-14-cloud-amd64
  12. fio Disk Speed Tests (Mixed R/W 50/50):
  13. ---------------------------------
  14. Block Size | 4k            (IOPS) | 64k           (IOPS)
  15.   ------   | ---            ----  | ----           ----
  16. Read       | 208.77 MB/s  (52.1k) | 2.41 GB/s    (37.6k)
  17. Write      | 209.32 MB/s  (52.3k) | 2.42 GB/s    (37.8k)
  18. Total      | 418.09 MB/s (104.5k) | 4.83 GB/s    (75.5k)
  19.            |                      |
  20. Block Size | 512k          (IOPS) | 1m            (IOPS)
  21.   ------   | ---            ----  | ----           ----
  22. Read       | 2.78 GB/s     (5.4k) | 2.74 GB/s     (2.6k)
  23. Write      | 2.93 GB/s     (5.7k) | 2.92 GB/s     (2.8k)
  24. Total      | 5.72 GB/s    (11.1k) | 5.67 GB/s     (5.5k)
  25. iperf3 Network Speed Tests (IPv4):
  26. ---------------------------------
  27. Provider        | Location (Link)           | Send Speed      | Recv Speed
  28.                 |                           |                 |
  29. Clouvider       | London, UK (10G)          | 477 Mbits/sec   | 512 Mbits/sec
  30. Online.net      | Paris, FR (10G)           | busy            | 471 Mbits/sec
  31. Hybula          | The Netherlands (40G)     | 477 Mbits/sec   | 928 Mbits/sec
  32. Uztelecom       | Tashkent, UZ (10G)        | 447 Mbits/sec   | 128 Mbits/sec
  33. Clouvider       | NYC, NY, US (10G)         | 449 Mbits/sec   | 124 Mbits/sec
  34. Clouvider       | Dallas, TX, US (10G)      | 87.5 Mbits/sec  | 38.3 Mbits/sec
  35. Clouvider       | Los Angeles, CA, US (10G) | 189 Mbits/sec   | busy
  36. Geekbench 5 Benchmark Test:
  37. ---------------------------------
  38. Test            | Value
  39.                 |
  40. Single Core     | 1249
  41. Multi Core      | 1246
  42. Full Test       | https://browser.geekbench.com/v5/cpu/17653103
GMT+8, 2026-4-15 16:15 , Processed in 0.059057 second(s), 10 queries , Gzip On, MemCache On.
