查看: 2770|回复: 10
这服务器是不是可以扔了?上跑分
发表于 2022-11-30 22:21:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
闲来无事,想看看杜甫和小鸡到底有多大差距,跑了一下分,结果如下:
  1. Basic System Information:
  3. Uptime     : 0 days, 0 hours, 0 minutes
  4. Processor  : Intel(R) Xeon(R) CPU D-1581 [url=home.php?mod=space&uid=175]@[/url] 1.80GHz
  5. CPU cores  : 32 @ 2400.000 MHz
  6. AES-NI     : ✔ Enabled
  7. VM-x/AMD-V : ✔ Enabled
  8. RAM        : 94.0 GiB
  9. Swap       : 4.0 GiB
  10. Disk       : 472.7 GiB
  11. Distro     : CentOS Stream 8
  12. Kernel     : 4.18.0-408.el8.x86_64
  13. fio Disk Speed Tests (Mixed R/W 50/50):
  14. ---------------------------------
  15. Block Size | 4k            (IOPS) | 64k           (IOPS)
  16.   ------   | ---            ----  | ----           ----
  17. Read       | 533.73 MB/s (133.4k) | 619.93 MB/s   (9.6k)
  18. Write      | 535.14 MB/s (133.7k) | 623.19 MB/s   (9.7k)
  19. Total      | 1.06 GB/s   (267.2k) | 1.24 GB/s    (19.4k)
  20.            |                      |
  21. Block Size | 512k          (IOPS) | 1m            (IOPS)
  22.   ------   | ---            ----  | ----           ----
  23. Read       | 739.90 MB/s   (1.4k) | 798.41 MB/s    (779)
  24. Write      | 779.21 MB/s   (1.5k) | 851.58 MB/s    (831)
  25. Total      | 1.51 GB/s     (2.9k) | 1.65 GB/s     (1.6k)
  26. iperf3 Network Speed Tests (IPv4):
  27. ---------------------------------
  28. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  29. -----           | -----                     | ----            | ----            | ----
  30. Clouvider       | London, UK (10G)          | 41.5 Mbits/sec  | 69.1 Mbits/sec  | 269 ms
  31. Scaleway        | Paris, FR (10G)           | 48.9 Mbits/sec  | 61.7 Mbits/sec  | 236 ms
  32. NovoServe       | North Holland, NL (40G)   | 48.6 Mbits/sec  | 69.4 Mbits/sec  | 235 ms
  33. Uztelecom       | Tashkent, UZ (10G)        | 48.7 Mbits/sec  | 62.6 Mbits/sec  | 324 ms
  34. Clouvider       | NYC, NY, US (10G)         | 50.1 Mbits/sec  | 43.2 Mbits/sec  | 263 ms
  35. Clouvider       | Dallas, TX, US (10G)      | 48.1 Mbits/sec  | 55.4 Mbits/sec  | 228 ms
  36. Clouvider       | Los Angeles, CA, US (10G) | 48.8 Mbits/sec  | 55.1 Mbits/sec  | 211 ms
  37. Geekbench 5 Benchmark Test:
  38. ---------------------------------
  39. Test            | Value
  40.                 |
  41. Single Core     | 683
  42. Multi Core      | 8468
  43. Full Test       | https://browser.geekbench.com/v5/cpu/18985249
好像比一些小鸡。。。。还不如。。。。。。。优点是放家里省电。。。。
发表于 2022-11-30 22:27:34 | 只看该作者
硬件比小鸡强完了,你这放家里的网络不太行罢了
 楼主| 发表于 2022-11-30 22:30:15 | 只看该作者
没办法,家庭宽带只有50M上行。。。这些测速地址,根据规则,应该是全部走IPLC去了。。。
发表于 2022-11-30 22:30:47 | 只看该作者
别扔,包邮给我谢谢 我是小学生
记得塞100块钱我买书用,谢谢
 楼主| 发表于 2022-11-30 22:33:13 | 只看该作者
hostlocmjj 发表于 2022-11-30 22:30
别扔,包邮给我谢谢 我是小学生
记得塞100块钱我买书用,谢谢
大佬就是大佬。。。。。
发表于 2022-12-1 00:19:32 来自手机 | 只看该作者
还是租用商家的合适,维护一律不用管,最主要的是网络,要的就是没有任何限制大带宽,放在家里我觉得意义不大
发表于 2022-12-1 00:40:20 | 只看该作者
除网络差点,其他比KS-1强多了
 楼主| 发表于 2022-12-2 10:02:34 | 只看该作者
darius 发表于 2022-12-1 00:19
还是租用商家的合适,维护一律不用管,最主要的是网络,要的就是没有任何限制大带宽,放在家里我觉得意义不 ...
也对,也不对,看具体应用场景吧。。。放家里,主要数据有保障。。除了上行小一些,其他问题不是太大
 楼主| 发表于 2022-12-2 10:03:34 | 只看该作者
hostv 发表于 2022-12-1 00:40
除网络差点,其他比KS-1强多了
是的,主要受限于上行。。。我这走的已经是IPLC了,整体体验还行。
发表于 2022-12-2 10:03:36 来自手机 | 只看该作者
D系列cpu 适合突发型应用。
GMT+8, 2026-4-17 01:30 , Processed in 0.067406 second(s), 10 queries , Gzip On, MemCache On.
