查看: 3641|回复: 30
[特价VPS] 出terrahost的年付i5的8G的500G固态的千兆不限流特价机
发表于 2022-11-26 17:41:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
因为机器正在跑项目,不方便现在做测试,但我在刚发货时做了测试和获取了固态硬盘的信息,如下:
  3. #                     v2022-08-20                    #
  6. Sat 22 Oct 2022 08:10:26 AM CST
  7. Basic System Information:
  9. Uptime     : 0 days, 0 hours, 2 minutes
  10. Processor  : Intel(R) Core(TM) i5-4570S CPU [url=home.php?mod=space&uid=175]@[/url] 2.90GHz
  11. CPU cores  : 4 @ 2893.454 MHz
  12. AES-NI     : ✔ Enabled
  13. VM-x/AMD-V : ✔ Enabled
  14. RAM        : 7.7 GiB
  15. Swap       : 0.0 KiB
  16. Disk       : 456.4 GiB
  17. Distro     : Debian GNU/Linux 11 (bullseye)
  18. Kernel     : 5.15.64-1-pve
  19. fio Disk Speed Tests (Mixed R/W 50/50):
  20. ---------------------------------
  21. Block Size | 4k            (IOPS) | 64k           (IOPS)
  22.   ------   | ---            ----  | ----           ----
  23. Read       | 96.43 MB/s   (24.1k) | 114.82 MB/s   (1.7k)
  24. Write      | 96.69 MB/s   (24.1k) | 115.42 MB/s   (1.8k)
  25. Total      | 193.12 MB/s  (48.2k) | 230.25 MB/s   (3.5k)
  26.            |                      |
  27. Block Size | 512k          (IOPS) | 1m            (IOPS)
  28.   ------   | ---            ----  | ----           ----
  29. Read       | 129.79 MB/s    (253) | 137.70 MB/s    (134)
  30. Write      | 136.69 MB/s    (266) | 146.87 MB/s    (143)
  31. Total      | 266.49 MB/s    (519) | 284.57 MB/s    (277)
  32. iperf3 Network Speed Tests (IPv4):
  33. ---------------------------------
  34. Provider        | Location (Link)           | Send Speed      | Recv Speed
  35.                 |                           |                 |
  36. Clouvider       | London, UK (10G)          | 919 Mbits/sec   | 777 Mbits/sec
  37. Online.net      | Paris, FR (10G)           | 919 Mbits/sec   | 724 Mbits/sec
  38. Hybula          | The Netherlands (40G)     | 926 Mbits/sec   | 921 Mbits/sec
  39. Uztelecom       | Tashkent, UZ (10G)        | 859 Mbits/sec   | 321 Mbits/sec
  40. Clouvider       | NYC, NY, US (10G)         | 870 Mbits/sec   | 216 Mbits/sec
  41. Clouvider       | Dallas, TX, US (10G)      | 835 Mbits/sec   | 139 Mbits/sec
  42. Clouvider       | Los Angeles, CA, US (10G) | 806 Mbits/sec   | 95.8 Mbits/sec
  43. iperf3 Network Speed Tests (IPv6):
  44. ---------------------------------
  45. Provider        | Location (Link)           | Send Speed      | Recv Speed
  46.                 |                           |                 |
  47. Clouvider       | London, UK (10G)          | 908 Mbits/sec   | 852 Mbits/sec
  48. Online.net      | Paris, FR (10G)           | 904 Mbits/sec   | 752 Mbits/sec
  49. Hybula          | The Netherlands (40G)     | 912 Mbits/sec   | 913 Mbits/sec
  50. Uztelecom       | Tashkent, UZ (10G)        | 863 Mbits/sec   | 467 Mbits/sec
  51. Clouvider       | NYC, NY, US (10G)         | 857 Mbits/sec   | 239 Mbits/sec
  52. Clouvider       | Dallas, TX, US (10G)      | 827 Mbits/sec   | 156 Mbits/sec
  53. Clouvider       | Los Angeles, CA, US (10G) | 810 Mbits/sec   | 86.6 Mbits/sec
  54. Geekbench 5 Benchmark Test:
  55. ---------------------------------
  56. Test            | Value
  57.                 |
  58. Single Core     | 955
  59. Multi Core      | 2933
  60. Full Test       | https://browser.geekbench.com/v5/cpu/18113277
  1. smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.15.64-1-pve] (local build)
  2. Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
  3. === START OF INFORMATION SECTION ===
  4. Model Family:     WD Blue / Red / Green SSDs
  5. Device Model:     WDC  WDS500G2B0A-00SM50
  6. Serial Number:    2044FK483814
  7. LU WWN Device Id: 5 001b44 4a7ee6282
  8. Firmware Version: 415000WD
  9. User Capacity:    500,107,862,016 bytes [500 GB]
  10. Sector Size:      512 bytes logical/physical
  11. Rotation Rate:    Solid State Device
  12. Form Factor:      2.5 inches
  13. TRIM Command:     Available, deterministic, zeroed
  14. Device is:        In smartctl database [for details use: -P show]
  15. ATA Version is:   ACS-4 T13/BSR INCITS 529 revision 5
  16. SATA Version is:  SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
  17. Local Time is:    Sat Oct 22 08:22:31 2022 CST
  18. SMART support is: Available - device has SMART capability.
  19. SMART support is: Enabled
  20. === START OF READ SMART DATA SECTION ===
  21. SMART overall-health self-assessment test result: PASSED
  22. General SMART Values:
  23. Offline data collection status:  (0x00)        Offline data collection activity
  24.                                         was never started.
  25.                                         Auto Offline Data Collection: Disabled.
  26. Self-test execution status:      (   0)        The previous self-test routine completed
  27.                                         without error or no self-test has ever
  28.                                         been run.
  29. Total time to complete Offline
  30. data collection:                 (    0) seconds.
  31. Offline data collection
  32. capabilities:                          (0x11) SMART execute Offline immediate.
  33.                                         No Auto Offline data collection support.
  34.                                         Suspend Offline collection upon new
  35.                                         command.
  36.                                         No Offline surface scan supported.
  37.                                         Self-test supported.
  38.                                         No Conveyance Self-test supported.
  39.                                         No Selective Self-test supported.
  40. SMART capabilities:            (0x0003)        Saves SMART data before entering
  41.                                         power-saving mode.
  42.                                         Supports SMART auto save timer.
  43. Error logging capability:        (0x01)        Error logging supported.
  44.                                         General Purpose Logging supported.
  45. Short self-test routine
  46. recommended polling time:          (   2) minutes.
  47. Extended self-test routine
  48. recommended polling time:          (  10) minutes.
  49. SMART Attributes Data Structure revision number: 4
  50. Vendor Specific SMART Attributes with Thresholds:
  51. ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  52.   5 Reallocated_Sector_Ct   0x0032   100   100   ---    Old_age   Always       -       0
  53.   9 Power_On_Hours          0x0032   100   100   ---    Old_age   Always       -       13032
  54. 12 Power_Cycle_Count       0x0032   100   100   ---    Old_age   Always       -       7
  55. 165 Block_Erase_Count       0x0032   100   100   ---    Old_age   Always       -       22348049
  56. 166 Minimum_PE_Cycles_TLC   0x0032   100   100   ---    Old_age   Always       -       0
  57. 167 Max_Bad_Blocks_per_Die  0x0032   100   100   ---    Old_age   Always       -       50
  58. 168 Maximum_PE_Cycles_TLC   0x0032   100   100   ---    Old_age   Always       -       1
  59. 169 Total_Bad_Blocks        0x0032   100   100   ---    Old_age   Always       -       201
  60. 170 Grown_Bad_Blocks        0x0032   100   100   ---    Old_age   Always       -       0
  61. 171 Program_Fail_Count      0x0032   100   100   ---    Old_age   Always       -       0
  62. 172 Erase_Fail_Count        0x0032   100   100   ---    Old_age   Always       -       0
  63. 173 Average_PE_Cycles_TLC   0x0032   100   100   ---    Old_age   Always       -       0
  64. 174 Unexpected_Power_Loss   0x0032   100   100   ---    Old_age   Always       -       0
  65. 184 End-to-End_Error        0x0032   100   100   ---    Old_age   Always       -       0
  66. 187 Reported_Uncorrect      0x0032   100   100   ---    Old_age   Always       -       0
  67. 188 Command_Timeout         0x0032   100   100   ---    Old_age   Always       -       0
  68. 194 Temperature_Celsius     0x0022   065   039   ---    Old_age   Always       -       35 (Min/Max 19/39)
  69. 199 UDMA_CRC_Error_Count    0x0032   100   100   ---    Old_age   Always       -       0
  70. 230 Media_Wearout_Indicator 0x0032   001   001   ---    Old_age   Always       -       0x003600000036
  71. 232 Available_Reservd_Space 0x0033   100   100   004    Pre-fail  Always       -       100
  72. 233 NAND_GB_Written_TLC     0x0032   100   100   ---    Old_age   Always       -       125
  73. 234 NAND_GB_Written_SLC     0x0032   100   100   ---    Old_age   Always       -       2035
  74. 241 Host_Writes_GiB         0x0030   253   253   ---    Old_age   Offline      -       1655
  75. 242 Host_Reads_GiB          0x0030   253   253   ---    Old_age   Offline      -       218
  76. 244 Temp_Throttle_Status    0x0032   000   100   ---    Old_age   Always       -       0
  77. SMART Error Log Version: 1
  78. No Errors Logged
  79. SMART Self-test log structure revision number 1
  80. No self-tests have been logged.  [To run self-tests, use: smartctl -t]
  81. Selective Self-tests/Logging not supported
本机器我在2022年10月21日下单并年付2799.9挪威克朗,扣款了1930人民币。
既然黑五特惠有更大力度的促销,而且已经售罄,那么我就试试看能否出掉这台优惠力度没那么大的机器。
转让价88元+剩余价值(剩余天数/365*1930),直接交易。
请有意者回帖联系,或者私信留下联系方式。
 楼主| 发表于 2022-11-29 12:50:19 | 只看该作者
我先说说我的立场:我最烦的就是一群傻逼整天喜欢回帖说其他人的机器性价比不行,不如某某某。
就好比说这次,你**这么能咋不见到你秀一下你抢到的TH10刀?
平时酸我的论坛用户不少,但凡看过我发帖记录的人就都知道,我出不出根本没所谓。
只要是有溢价,不想交易不联系就是了,还JB话这么多。我他妈一个月的费用比你丫好几年的费用都多好吧。
我有时候真的觉得,这个论坛有些人是他妈真的穷,而且骨子更穷。
就當沒看見, 何必跟這些人認真, 只是糟蹋自己的時間.  发表于 2022-11-29 13:03
发表于 2022-11-27 09:49:58 | 只看该作者
年付就让了。
发表于 2022-11-29 09:17:53 | 只看该作者
1930人民币
 楼主| 发表于 2022-11-29 10:38:08 | 只看该作者
怎么,你有什么想说的?
发表于 2022-11-29 11:54:34 来自手机 | 只看该作者
还是闪购的10刀香啊
 楼主| 发表于 2022-11-29 12:05:46 | 只看该作者
derekyang 发表于 2022-11-29 11:54
还是闪购的10刀香啊
确实香,只可惜只有3台。
不知道咱们国人买到的有几位幸运儿?
GMT+8, 2026-4-17 07:33 , Processed in 0.076163 second(s), 15 queries , Gzip On, MemCache On.
