查看: 1712|回复: 7
OSJP10GbpsStorage0.5TB 跑分
发表于 2022-11-25 14:53:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
给兄弟们看看
YABS
Basic System Information:
Uptime     : 0 days, 4 hours, 7 minutes
Processor  : Intel(R) Xeon(R) CPU E5-2690 v3 @ 2.60GHz
CPU cores  : 2 @ 2599.998 MHz
AES-NI     : ✔ Enabled
VM-x/AMD-V : ✔ Enabled
RAM        : 3.9 GiB
Swap       : 2.0 GiB
Disk       : 490.6 GiB
Distro     : Debian GNU/Linux 10 (buster)
Kernel     : 4.19.0-6-amd64
fio Disk Speed Tests (Mixed R/W 50/50):
Read       | 4.27 MB/s     (1.0k) | 52.04 MB/s     (813)
Write      | 4.30 MB/s     (1.0k) | 52.45 MB/s     (819)
Total      | 8.57 MB/s     (2.1k) | 104.50 MB/s   (1.6k)
Read       | 179.95 MB/s    (351) | 196.15 MB/s    (191)
Write      | 189.51 MB/s    (370) | 209.21 MB/s    (204)
Total      | 369.47 MB/s    (721) | 405.36 MB/s    (395)
Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
Clouvider       | London, UK (10G)          | 441 Mbits/sec   | 92.9 Mbits/sec  | 244 ms
Scaleway        | Paris, FR (10G)           | busy            | 75.6 Mbits/sec  | 222 ms
NovoServe       | North Holland, NL (40G)   | 582 Mbits/sec   | 429 Mbits/sec   | 245 ms
Uztelecom       | Tashkent, UZ (10G)        | 813 Mbits/sec   | 151 Mbits/sec   | 316 ms
Clouvider       | NYC, NY, US (10G)         | 776 Mbits/sec   | 192 Mbits/sec   | 171 ms
Clouvider       | Dallas, TX, US (10G)      | 797 Mbits/sec   | 130 Mbits/sec   | 147 ms
Clouvider       | Los Angeles, CA, US (10G) | 823 Mbits/sec   | 135 Mbits/sec   | 104 ms
iperf3 Network Speed Tests (IPv6):
Clouvider       | London, UK (10G)          | 638 Mbits/sec   | 107 Mbits/sec   | 244 ms
Scaleway        | Paris, FR (10G)           | 641 Mbits/sec   | 105 Mbits/sec   | 249 ms
NovoServe       | North Holland, NL (40G)   | 590 Mbits/sec   | 481 Mbits/sec   | 237 ms
Uztelecom       | Tashkent, UZ (10G)        | 497 Mbits/sec   | 88.2 Mbits/sec  | 315 ms
Clouvider       | NYC, NY, US (10G)         | 777 Mbits/sec   | 196 Mbits/sec   | 171 ms
Clouvider       | Dallas, TX, US (10G)      | 728 Mbits/sec   | 191 Mbits/sec   | 145 ms
Clouvider       | Los Angeles, CA, US (10G) | 739 Mbits/sec   | 78.8 Mbits/sec  | 104 ms
Geekbench 5 Benchmark Test:
Test            | Value
Single Core     | 712
Multi Core      | 1426
Full Test       | https://browser.geekbench.com/v5/cpu/18862097
 楼主| 发表于 2022-11-25 14:57:12 | 只看该作者
流媒体全部不解锁
LemonBench Server Test Tookit 20201005 Intl BetaVersion (C)iLemonrain. All Rights Reserved.
[Info] Bench Start Time: 2022-11-25 01:54:50
[Info] Test Mode: Fast Mode
-> System Information
OS Release:            Debian GNU/Linux "Buster" 10.1 (x86_64)
CPU Model:             Intel(R) Xeon(R) CPU E5-2690 v3 @ 2.60GHz  2.60 GHz
CPU Cache Size:        16384 KB
CPU Number:            2 vCPU
VirtReady:             Yes (Nested Virtualization)
Virt Type:             KVM
Memory Usage:          87.61 MB / 3.85 GB
Swap Usage:            0 KB / 2.00 GB
Boot Device:           /dev/vda1
Disk Usage:            1.05 GB / 514.42 GB
CPU Usage:             0.0% used, 0.0% iowait, 0.0% steal
Load (1/5/15min):      0.32 0.30 0.16
Uptime:                0 Days, 4 Hours, 21 Minutes, 45 Seconds
Kernel Version:        4.19.0-6-amd64
Network CC Method:     cubic + pfifo_fast
-> Network Infomation
-> Media Unlock Test
HBO Now:                               Yes
Bahamut Anime:                         Failed (due to parse fail)
Abema.TV:                              No
Princess Connect Reive Japan:        No
BBC:                                   No
BiliBili China Mainland Only:          No
BiliBili Hongkong/Macau/Taiwan:        No
Bilibili Taiwan Only:                  No
-> CPU Performance Test (Fast Mode, 1-Pass @ 5sec)
1 Thread Test:                 841 Scores
2 Threads Test:                1678 Scores
-> Memory Performance Test (Fast Mode, 1-Pass @ 5sec)
1 Thread - Read Test :         19074.83 MB/s
1 Thread - Write Test:         13300.74 MB/s
-> Disk Speed Test (4K Block/1M Block, Direct Mode)
Test Name              Write Speed                             Read Speed
100MB-4K Block         29.7 MB/s (7252 IOPS, 3.53s)            29.4 MB/s (7184 IOPS, 3.56s)
1GB-1M Block           384 MB/s (366 IOPS, 2.73s)              65.5 MB/s (62 IOPS, 16.00s)
发表于 2022-11-25 14:59:09 | 只看该作者
还行,正常水平
发表于 2022-11-25 15:04:25 | 只看该作者
这是哪家的机
发表于 2022-11-25 15:05:47 | 只看该作者
io 有点拉,不过价格在那儿
 楼主| 发表于 2022-11-25 15:06:43 | 只看该作者
绿帽云啊
发表于 2022-11-25 15:12:37 | 只看该作者
快赶上999的性能了
发表于 2022-11-25 19:29:58 | 只看该作者
习惯就好了
GMT+8, 2026-4-13 22:20 , Processed in 0.072252 second(s), 10 queries , Gzip On, MemCache On.
