查看: 1078|回复: 0
【灵车翻车】sQuote 月抛大盘鸡翻车
发表于 2022-11-24 16:59:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
本来刚开始没看到一次性折扣,就想着上车试试机器,但只能说灵车名副其实。
但毕竟是灵车,遇到啥问题好像也挺正常。
先做下连通性测试
  1. PING 91.197.55.* (91.197.55.*) 56(84) bytes of data.
  2. ^C
  3. --- 91.197.55.* ping statistics ---
  4. 44 packets transmitted, 0 received, 100% packet loss, time 57ms
  5. 嗯,挺好,内地连不上,下边是通过另一台小鸡做跳板连接的。
  6. [code]# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## #
  7. #              Yet-Another-Bench-Script              #
  8. #                     v2022-11-22                    #
  9. # https://github.com/masonr/yet-another-bench-script #
  10. # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## #
  11. Thu 24 Nov 2022 08:34:22 AM UTC
  12. Basic System Information:
  13. ---------------------------------
  14. Uptime     : 0 days, 0 hours, 5 minutes
  15. Processor  : Common KVM processor
  16. CPU cores  : 2 [url=home.php?mod=space&uid=175]@[/url] 2794.748 MHz
  17. AES-NI     : ✔ Enabled
  18. VM-x/AMD-V : ❌ Disabled
  19. RAM        : 3.8 GiB
  20. Swap       : 5.4 GiB
  21. Disk       : 43.6 GiB
  22. Distro     : Debian GNU/Linux 10 (buster)
  23. Kernel     : 4.19.0-22-amd64
  24. fio Disk Speed Tests (Mixed R/W 50/50):
  25. ---------------------------------
  26. Block Size | 4k            (IOPS) | 64k           (IOPS)
  27.   ------   | ---            ----  | ----           ----
  28. Read       | 266.22 MB/s  (66.5k) | 786.62 MB/s  (12.2k)
  29. Write      | 266.92 MB/s  (66.7k) | 790.76 MB/s  (12.3k)
  30. Total      | 533.15 MB/s (133.2k) | 1.57 GB/s    (24.6k)
  31.            |                      |
  32. Block Size | 512k          (IOPS) | 1m            (IOPS)
  33.   ------   | ---            ----  | ----           ----
  34. Read       | 1.18 GB/s     (2.3k) | 1.26 GB/s     (1.2k)
  35. Write      | 1.24 GB/s     (2.4k) | 1.34 GB/s     (1.3k)
  36. Total      | 2.43 GB/s     (4.7k) | 2.61 GB/s     (2.5k)
  37. iperf3 Network Speed Tests (IPv4):
  38. ---------------------------------
  39. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  40. -----           | -----                     | ----            | ----            | ----
  41. Clouvider       | London, UK (10G)          | 1.86 Gbits/sec  | 1.81 Gbits/sec  | 10.7 ms
  42. Scaleway        | Paris, FR (10G)           | 1.87 Gbits/sec  | busy            | 15.9 ms
  43. NovoServe       | North Holland, NL (40G)   | 1.87 Gbits/sec  | 1.87 Gbits/sec  | 7.68 ms
  44. Uztelecom       | Tashkent, UZ (10G)        | 1.53 Gbits/sec  | 497 Mbits/sec   | 81.8 ms
  45. Clouvider       | NYC, NY, US (10G)         | 1.71 Gbits/sec  | 301 Mbits/sec   | 78.7 ms
  46. Clouvider       | Dallas, TX, US (10G)      | 1.34 Gbits/sec  | 183 Mbits/sec   | 118 ms
  47. Clouvider       | Los Angeles, CA, US (10G) | 995 Mbits/sec   | 210 Mbits/sec   | 136 ms
  48. Geekbench 5 Benchmark Test:
  49. ---------------------------------
  50. Test            | Value
  51.                 |
  52. Single Core     | 916
  53. Multi Core      | 1803
  54. Full Test       | https://browser.geekbench.com/v5/cpu/18842336
然后我的大盘就不见了,用fdisk看一下,确实也是如此
  1. Disk /dev/sda: 50 GiB, 53687091200 bytes, 104857600 sectors
  2. Disk model: QEMU HARDDISK
  3. Units: sectors of 1 * 512 = 512 bytes
  4. Sector size (logical/physical): 512 bytes / 512 bytes
  5. I/O size (minimum/optimal): 512 bytes / 512 bytes
  6. Disklabel type: dos
  7. Disk identifier: 0xf5fb8587
  8. Device     Boot   Start       End   Sectors  Size Id Type
  9. /dev/sda1  *       2048   2000895   1998848  976M 83 Linux
  10. /dev/sda2       2002942 104855551 102852610   49G  5 Extended
  11. /dev/sda5       2002944 104855551 102852608   49G 8e Linux LVM
  12. Disk /dev/mapper/pan--vg-root: 43.7 GiB, 46871347200 bytes, 91545600 sectors
  13. Units: sectors of 1 * 512 = 512 bytes
  14. Sector size (logical/physical): 512 bytes / 512 bytes
  15. I/O size (minimum/optimal): 512 bytes / 512 bytes
  16. Disk /dev/mapper/pan--vg-swap: 5.4 GiB, 5788139520 bytes, 11304960 sectors
  17. Units: sectors of 1 * 512 = 512 bytes
  18. Sector size (logical/physical): 512 bytes / 512 bytes
  19. I/O size (minimum/optimal): 512 bytes / 512 bytes
最后就看看流媒体吧
  1. ============[ Multination ]============
  2. Dazn:                                  No
  3. HotStar:                               No
  4. Disney+:                               Yes (Region: DE)
  5. Netflix:                               Yes (Region: DE)
  6. 有图比 Premium:                       Yes
  7. Amazon Prime Video:                    Yes (Region: DE)
  8. TVBAnywhere+:                          Yes
  9. iQyi Oversea Region:                   DE
  10. Viu.com:                               No
  11. 有图比 CDN:                           Associated with [RETNRU]
  12. Netflix Preferred CDN:                 Frankfurt
  13. Spotify Registration:                  No
  14. Steam Currency:                        RUB
  15. =======================================
  16. ===============[ Europe ]==============
  17. Rakuten TV:                            Yes
  18. Funimation:                            No
  19. HBO Nordic:                            Failed (Network Connection)
  20. HBO GO Europe:                         Failed (Network Connection)
  21. ---GB---
  22. Sky Go:                                No
  23. BritBox:                               Yes
  24. ITV Hub:                               No
  25. Channel 4:                             No
  26. Channel 5:                             No
  27. BBC iPLAYER:                           No
  28. Discovery+ UK:                         No
  29. ---FR---
  30. Salto:                                 No
  31. Canal+:                                No
  32. Molotov:                               No
  33. ---DE---
  34. Joyn:                                  No
  35. Sky:                                   Yes
  36. ZDF:                                   Yes
  37. ---NL---
  38. NLZIET:                                Failed
  39. videoland:                             No
  40. NPO Start Plus:                        No
  41. ---ES---
  42. HBO Spain:                             Failed (Network Connection)
  43. PANTAYA:                               No
  44. ---IT---
  45. Rai Play:                              Yes
  46. ---RU---
  47. Amediateka:                            Yes
  48. ---PT---
  49. HBO Portugal:                          Failed (Network Connection)
  50. =======================================
反正就这个样子了,灵车嘛,也正常。
打个小小的广告,楼主想出一个ikoula 的10o机(G3930+2T 无独显),不知道有没有MJJ接盘
GMT+8, 2026-1-2 03:41 , Processed in 0.092933 second(s), 10 queries , Gzip On, MemCache On.
