查看: 3419|回复: 26
Arkecx11.11首尔测评
发表于 2022-11-11 17:02:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
去程
IP:156.59.182.* 自己可MTR下,移动去程有点抽象。
回程
CT:
  1. 1. AS6805  5.7.231.1            30.0%    10    7.0   5.9   3.3   8.6   2.0
  2.   2. AS???   ???                  100.0    10    0.0   0.0   0.0   0.0   0.0
  3.   3. AS???   104.254.112.240       0.0%    10    3.2   8.5   1.0  67.9  20.9
  4.   4. AS9318  222.239.162.209       0.0%    10    1.9   1.5   0.6   2.6   0.0
  5.   5. AS9318  218.50.5.233          0.0%    10    1.3   1.6   1.3   2.2   0.0
  6.   6. AS9318  58.229.10.5           0.0%    10    1.9   2.8   1.9   6.8   1.7
  7.   7. AS???   ???                  100.0    10    0.0   0.0   0.0   0.0   0.0
  8.   8. AS4134  202.97.41.33         90.0%    10   24.0  24.0  24.0  24.0   0.0
  9.   9. AS4134  202.97.35.85         80.0%    10   24.0  24.0  24.0  24.0   0.0
  10. 10. AS???   ???                  100.0    10    0.0   0.0   0.0   0.0   0.0
  11. 11. AS4134  202.97.66.198        90.0%    10   30.0  30.0  30.0  30.0   0.0
  12. 12. AS4134  221.229.192.106       0.0%    10   35.5  35.4  35.2  35.6   0.0
  13. 13. AS4134  221.229.193.214       0.0%     7   36.5  36.1  35.7  36.5   0.0
  14. 14. AS4134  221.229.194.65        0.0%     7   35.8  35.9  35.8  36.0   0.0
CU:
  1.   1. AS6805  5.7.231.1            30.0%    10    2.3   8.9   2.3  16.1   5.5
  3.   3. AS???   104.254.112.240       0.0%    10    1.1   1.4   1.1   3.9   0.7
  4.   4. AS9318  222.239.162.209       0.0%    10    1.4   2.5   0.9   4.5   1.3
  5.   5. AS9318  218.50.5.233          0.0%    10    1.6   1.7   1.4   2.7   0.0
  6.   6. AS9318  58.229.10.13          0.0%    10   10.1   4.2   2.2  11.6   3.5
  8.   8. AS4837  219.158.43.13         0.0%    10   50.3  47.6  44.7  50.3   2.3
  9.   9. AS4837  219.158.113.142       0.0%    10   45.4  46.8  43.6  49.9   2.0
  11. 11. AS4837  219.158.104.98        0.0%    10   46.3  46.1  45.9  46.4   0.0
  12. 12. AS4837  221.6.209.150         0.0%    10   54.9  55.6  54.9  59.5   1.3
  13. 13. AS4837  112.85.218.149        0.0%    10   56.0  92.5  54.1 118.9  32.5
CM:
  1.   1. AS6805  5.7.231.1             0.0%    10    2.9   5.7   2.5  15.0   3.6
  2.   2. AS???   104.254.114.180      90.0%    10   13.4  13.4  13.4  13.4   0.0
  3.   3. AS???   104.254.112.240       0.0%    10   19.6   7.3   0.8  44.2  14.2
  4.   4. AS???   104.254.118.218       0.0%    10   33.2  34.4  31.7  52.9   6.5
  5.   5. AS21859 128.1.110.241         0.0%    10   42.5  37.4  31.7  58.6   8.6
  6.   6. AS2914  ae-20.a01.tokyjp09.j  0.0%    10   31.3  32.8  31.1  38.0   2.3
  7.   7. AS2914  ae-1.r30.tokyjp05.jp  0.0%    10   31.6  31.7  31.6  32.0   0.0
  8.   8. AS2914  ae-2.r26.tkokhk01.hk 10.0%    10   83.3  87.6  83.2 119.2  11.8
  9.   9. AS2914  ae-0.a02.tkokhk01.hk  0.0%    10   97.9  86.1  83.2  97.9   4.7
  10. 10. AS2914  ce-0-0-1.a02.tkokhk0 60.0%    10   62.2  62.1  62.0  62.2   0.0
  11. 11. AS58453 223.120.2.53         90.0%    10   62.4  62.4  62.4  62.4   0.0
  12. 12. AS58453 223.120.3.186        80.0%    10   87.3  87.3  87.2  87.3   0.0
  13. 13. AS9808  221.183.89.174       60.0%    10   88.6  88.7  88.6  88.7   0.0
  14. 14. AS9808  221.183.89.69        70.0%    10   88.8  88.8  88.8  88.9   0.0
  15. 15. AS???   ???                  100.0    10    0.0   0.0   0.0   0.0   0.0
  16. 16. AS9808  221.183.113.170      90.0%    10   97.1  97.1  97.1  97.1   0.0
  17. 17. AS???   ???                  100.0     6    0.0   0.0   0.0   0.0   0.0
SuperBench
  1. ----------------------------------------------------------------------
  2. CPU Model            : QEMU Virtual CPU version 2.5+
  3. CPU Cores            : 1 Cores 2099.996 MHz x86_64
  4. CPU Cache            : 16384 KB
  5. OS                   : CentOS 7.9.2009 (64 Bit) KVM
  6. Kernel               : 6.0.5
  7. Total Space          : 1.9 GB / 24.0 GB
  8. Total RAM            : 116 MB / 978 MB (114 MB Buff)
  9. Total SWAP           : 0 MB / 1023 MB
  10. Uptime               : 0 days 0 hour 0 min
  11. Load Average         : 0.47, 0.12, 0.04
  12. TCP CC               : bbr
  13. ASN & ISP            : AS21859, Zenlayer Inc
  14. Organization         : Zenlayer Inc
  15. Location             : Seoul, South Korea / KR
  16. Region               : Seoul
  17. ----------------------------------------------------------------------
  18. I/O Speed( 1.0GB )   : 459 MB/s
  19. I/O Speed( 1.0GB )   : 474 MB/s
  20. I/O Speed( 1.0GB )   : 496 MB/s
  21. Average I/O Speed    : 476.3 MB/s
  22. ----------------------------------------------------------------------
  23. Node Name        Upload Speed      Download Speed      Latency
  24. Speedtest.net    249.42 Mbit/s     2527.01 Mbit/s      (*)333.90 ms
  25. Fast.com         0.00 Mbit/s       125.8 Mbit/s        -
  26. Nanjing 5G   CT  2231.80 Mbit/s    4046.77 Mbit/s      30.01 ms
  27. Hefei 5G     CT  2011.96 Mbit/s    2882.33 Mbit/s      31.02 ms
  28. Shanghai 5G  CU  1602.44 Mbit/s    3910.84 Mbit/s      50.90 ms
  29. ----------------------------------------------------------------------
Superbench-Dev
  1. ----------------------------------------------------------------------------------
  2. Node Name        Upload Speed      Download Speed      Latency     Packet Loss
  3. Speedtest.net    970.77 Mbit/s     3099.51 Mbit/s      (*)82.58 ms 0.0%
  4. Shanghai     CT  1952.30 Mbit/s    3237.47 Mbit/s      24.52 ms    Not available
  5. TianJin 5G   CT  1236.50 Mbit/s    1868.54 Mbit/s      51.45 ms    0.4%
  6. Shanghai 5G  CU  1636.48 Mbit/s    3720.41 Mbit/s      50.82 ms    0.0%
  7. Wu Xi        CU  1702.55 Mbit/s    3492.79 Mbit/s      47.16 ms    0.0%
  8. Chengdu      CM  657.80 Mbit/s     3250.16 Mbit/s      123.44 ms   0.0%
  9. ----------------------------------------------------------------------------------
YABS
  1. Processor  : QEMU Virtual CPU version 2.5+
  2. CPU cores  : 1 @2099.996 MHz
  3. AES-NI     : ❌ Disabled
  4. VM-x/AMD-V : ❌ Disabled
  5. RAM        : 990.7 MiB
  6. Swap       : 1024.0 MiB
  7. Disk       : 23.6 GiB
  8. Distro     : CentOS Linux 7 (Core)
  9. Kernel     : 3.10.0-1160.80.1.el7.x86_64
  10. fio Disk Speed Tests (Mixed R/W 50/50):
  11. ---------------------------------
  12. Block Size | 4k            (IOPS) | 64k           (IOPS)
  13.   ------   | ---            ----  | ----           ----
  14. Read       | 45.34 MB/s   (11.3k) | 333.48 MB/s   (5.2k)
  15. Write      | 45.43 MB/s   (11.3k) | 335.24 MB/s   (5.2k)
  16. Total      | 90.78 MB/s   (22.6k) | 668.73 MB/s  (10.4k)
  17.            |                      |
  18. Block Size | 512k          (IOPS) | 1m            (IOPS)
  19.   ------   | ---            ----  | ----           ----
  20. Read       | 314.48 MB/s    (614) | 336.91 MB/s    (329)
  21. Write      | 331.19 MB/s    (646) | 359.35 MB/s    (350)
  22. Total      | 645.67 MB/s   (1.2k) | 696.26 MB/s    (679)
  23. Geekbench 5 Benchmark Test:
  25. Test            | Value
  26.                 |
  27. Single Core     | 629
  28. Multi Core      | 607
  29. Full Test       | https://browser.geekbench.com/v5/cpu/18566528
最低配购买
  1. 内存:1G
  2. CPU:1核
  3. 硬盘:25G SSD(raid10)
  4. 流量:1T/月(1Gbps带宽)
  5. 价格:120美元/年
https://www.arkecx.com/aff.php?aff=37&pid=35
6折优惠码,截止11.30日。
  1. arkc221001
ps: 这机器,也不适合爱发TK的MJJ,Zenlayer估计不加钱工单回复速度很慢的。
发表于 2022-11-11 17:03:21 | 只看该作者
这个鸡能溢价到500? 不太懂
发表于 2022-11-11 17:03:23 | 只看该作者
速度真快 顶一个
发表于 2022-11-11 17:03:28 | 只看该作者
卧槽 羡慕MJJ老哥 可惜不是TW的
发表于 2022-11-11 17:04:13 | 只看该作者
出吗,想收一只
发表于 2022-11-11 17:04:23 | 只看该作者
刚知道商家名字,你们都抢完了
发表于 2022-11-11 17:04:26 | 只看该作者
czx 发表于 2022-11-11 17:03
卧槽 羡慕MJJ老哥 可惜不是TW的
TW解锁巨垃圾
 楼主| 发表于 2022-11-11 17:04:44 | 只看该作者
卧槽 羡慕MJJ老哥 可惜不是TW的
主要TW只有电信暂时是直的,我是联通。
发表于 2022-11-11 17:05:26 | 只看该作者
首尔那些都有了 缺只TW的解锁
 楼主| 发表于 2022-11-11 17:05:45 | 只看该作者
暂不出哈。
GMT+8, 2026-1-12 23:53 , Processed in 0.068996 second(s), 10 queries , Gzip On, MemCache On.
