查看: 1388|回复: 0
老姨子解锁有问
发表于 2022-10-16 16:21:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
大佬们,你们的老姨子还能正常使用吗?
我是通过x-ui使用,配置如下
  1. {
  2.   "api": {
  3.     "services": [
  4.       "HandlerService",
  5.       "LoggerService",
  6.       "StatsService"
  7.     ],
  8.     "tag": "api"
  9.   },
  10.   "inbounds": [
  11.     {
  12.       "listen": "127.0.0.1",
  13.       "port": 62789,
  14.       "protocol": "dokodemo-door",
  15.       "settings": {
  16.         "address": "127.0.0.1"
  17.       },
  18.       "tag": "api"
  19.     }
  20.   ],
  21.   "outbounds": [
  22.     {
  23.       "protocol": "freedom",
  24.       "settings": {}
  25.     },
  26.     {
  27.       "protocol": "blackhole",
  28.       "settings": {},
  29.       "tag": "blocked"
  30.     },
  31.     {
  32.       "tag": "GoNetflix",
  33.       "protocol": "vmess",
  34.       "streamSettings": {
  35.         "network": "ws",
  36.         "security": "tls",
  37.         "tlsSettings": {
  38.           "allowInsecure": false
  39.         },
  40.         "wsSettings": {
  41.           "path": "ws"
  42.         }
  43.       },
  44.       "mux": {
  45.         "enabled": true,
  46.         "concurrency": 8
  47.       },
  48.       "settings": {
  49.         "vnext": [
  50.           {
  51.             "address": "free-sg-01.unblocknetflix.cf",
  52.             "port": 443,
  53.             "users": [
  54.               {
  55.                 "id": "402d7490-6d4b-42d4-80ed-e681b0e6f1f9",
  56.                 "security": "auto",
  57.                 "alterId": 0
  58.               }
  59.             ]
  60.           }
  61.         ]
  62.       }
  63.     }
  64.   ],
  65.   "policy": {
  66.     "system": {
  67.       "statsInboundDownlink": true,
  68.       "statsInboundUplink": true
  69.     }
  70.   },
  71.   "routing": {
  72.     "rules": [
  73.       {
  74.         "inboundTag": [
  75.           "api"
  76.         ],
  77.         "outboundTag": "api",
  78.         "type": "field"
  79.       },
  80.       {
  81.         "ip": [
  82.           "geoip:private"
  83.         ],
  84.         "outboundTag": "blocked",
  85.         "type": "field"
  86.       },
  87.       {
  88.         "outboundTag": "blocked",
  89.         "protocol": [
  90.           "bittorrent"
  91.         ],
  92.         "type": "field"
  93.       },
  94.       {
  95.         "type": "field",
  96.         "outboundTag": "GoNetflix",
  97.         "domain": ["geosite:netflix","nflxvideo.net","nflxext.com","nflxso.net"]
  98.       }
  99.     ]
  100.   },
  101.   "stats": {}
  102. }
这个月初的时候发现无法解锁了,用圈X测试显示 连接超时 ,后面直接用大佬官网的直连v2,也是无法连接。
是我的姿势不对吗?
GMT+8, 2026-4-16 03:15 , Processed in 0.063007 second(s), 9 queries , Gzip On, MemCache On.
