查看: 3276|回复: 13
[不限流量] buyvm迁移vps,是不是准备上货了??
发表于 2012-3-1 14:09:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我那在线近200天的vps要挂了
We are sending this email to inform you that we are currently in the process of migrating your VPS to one of our other 128MB nodes as we need to upgrade and re-purpose your existing node before designating it for other plans to keep up with demand for stock.
Downtime should be no longer than 1 minute but your VPS will appear offline in the control panel until it is updated with the new node location, since we are migrating node22 containers to multiple nodes to prevent overfilling we cannot give an ETA for when your node location will be updated.
As always, if you have an issue that requires the serial console function please issue a ticket and we will take care of it until panel access is restored.
发表于 2012-3-1 14:10:12 | 只看该作者
是的..
发表于 2012-3-1 14:11:09 来自手机 | 只看该作者
哦也。让你们不折腾省内存……转移过去继续超售
发表于 2012-3-1 14:11:20 | 只看该作者
我的那台重启了
发表于 2012-3-1 14:14:10 | 只看该作者
内存全部减半,进行强制迁移,意思应该很浅白了。。。
参与人数 1威望 +20 收起 理由
Kokgog + 20 咩,去咬死马
 楼主| 发表于 2012-3-1 14:16:20 | 只看该作者
服务器已运行时间:  3小时14分
发表于 2012-3-1 14:19:32 | 只看该作者
估计是腾出服务器上货
发表于 2012-3-1 14:20:52 | 只看该作者
 楼主| 发表于 2012-3-1 15:02:36 | 只看该作者
硬盘速度不错,得重新开始折腾了....
[root@x tmp]# dd if=/dev/zero of=test bs=64k count=4k oflag=dsync
4096+0 records in
4096+0 records out
268435456 bytes (268 MB) copied, 4.32597 seconds, 62.1 MB/s
suzizi 该用户已被删除
发表于 2012-3-1 15:25:08 | 只看该作者
GMT+8, 2026-4-15 11:09 , Processed in 0.102006 second(s), 14 queries , Gzip On, MemCache On.
