CeraNetworks网络延迟测速工具IP归属甄别
查看: 7227|回复: 16
狗屎的SS……!
发表于 2012-2-28 16:27:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
一台母鸡,分配了几个IP地址。然后拿这些IP开了小鸡
悲剧的是,某些IP开的小鸡,居然无法与母鸡通信?
我靠了。
Can you confirm if your issue is between hosts on the same XEN server?
I've checked external connectivity and routing and found no issues.
机房这么告诉我滴!
于是偶就这样回复!!!
Hi,thank you help me.
I am creating two new vps hosting.
use the IP 108.170.21.229 and 108.170.21.230
that can ping connect 108.170.21.226
but 108.170.21.227and108.170.21.228 can not ping connect 108.170.21.226
so , i need you help . I think that is your route will have some question.
108.170.21.227 have some time connect to 108.170.21.226
but more and more can not ping connect 108.170.21.226
I am confirm the xenserver system is no any problem. The dedicated server is New , and all user is use the same  xenserver.iso ,so , i am confirm that is no problem
If you can't confirm this question,I hope you can change 108.170.21.227 and 108.170.21.228 IP to other new IP address.
Thanks again.
 楼主| 发表于 2012-2-28 16:32:52 | 只看该作者
这是机房最新回复。
 楼主| 发表于 2012-2-28 16:33:47 | 只看该作者
Yes . i am sure.
the .229 ip  VPS hosting and .230 ip VPS hosting all in this server!
the .227 and .228 same too in this server!
but .229 and .230 ip can be ping connect to .226 ip
the .227 and .228 ip can not.
so , i hope you can help me change .227 and .228 ip to new ohter ip address.
thanks again.
我回复机房的
 楼主| 发表于 2012-2-28 17:27:18 | 只看该作者
I need you help me check my ip address 's gateway and netmask.
我发给机房的
 楼主| 发表于 2012-2-28 17:50:26 | 只看该作者
because if they're the same range the gateway is going to be the same as well as the netmask
What is the main range that those IP's belong too?
机房回复。
 楼主| 发表于 2012-2-28 17:50:58 | 只看该作者
we will continue to investigate, we will update you on any more information we have.
We will now be ending this chat, If you have any further questions or concerns please feel free to contact us. Thank you.
5:53 pm Thank you for your chat. Feel free to contact us again.
最后,在livechat 上面,就这样回复了……
发表于 2012-2-29 04:02:29 | 只看该作者
看起来是你自己的问题.小鸡和母鸡的通信是母鸡内部进行的, 不会到上层网络
 楼主| 发表于 2012-2-29 11:09:31 | 只看该作者
domin 发表于 2012-2-29 04:02
看起来是你自己的问题.小鸡和母鸡的通信是母鸡内部进行的, 不会到上层网络 ...
xensystem的工作人员告诉我是SS机房的问题,不会是他们的问题。因为SS提供的KVM,他们的工作人员安装的xenserver。然后配置的xensystem。然后告诉我这些IP不能通讯。郁闷啊。
发表于 2012-2-29 11:49:01 | 只看该作者
pinbar 发表于 2012-2-29 11:09
xensystem的工作人员告诉我是SS机房的问题,不会是他们的问题。因为SS提供的KVM,他们的工作人员安装的xe ...
试试把IP绑到母鸡看看
 楼主| 发表于 2012-2-29 11:54:45 | 只看该作者
domin 发表于 2012-2-29 11:49
试试把IP绑到母鸡看看
然后让其他IP跟它通讯?
GMT+8, 2026-4-15 00:28 , Processed in 0.073322 second(s), 11 queries , Gzip On, MemCache On.
