查看: 3475|回复: 19
[特价VPS] 报! leveloneservers 小盘鸡又有优惠啦 (qty 5)
发表于 2022-9-30 22:33:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
实例规格:
  1. STKVM-512GB
  2. 1v Core CPU
  3. 1GB RAM
  4. None Swap
  5. 512 GB HDD
  6. 1TB [url=home.php?mod=space&uid=175]@[/url] 1Gbps Uplink
  7. 1 IPv4 + 1 IPv6 IP
  8. Included DDoS Protection
  9. blocked SMTP
  10. $25.50/year $18.00/year
  11. Use code: BFNOW
YABS
  1. Fri Sep 30 10:16:27 EDT 2022
  2. Basic System Information:
  3. ---------------------------------
  4. Uptime     : 0 days, 0 hours, 9 minutes
  5. Processor  : Intel(R) Xeon(R) CPU E5-2690 v3 @ 2.60GHz
  6. CPU cores  : 1 @ 2593.992 MHz
  7. AES-NI     : ✔ Enabled
  8. VM-x/AMD-V : ✔ Enabled
  9. RAM        : 990.9 MiB
  10. Swap       : 0.0 KiB
  11. Disk       : 503.9 GiB
  12. Distro     : CentOS Linux 7 (Core)
  13. Kernel     : 3.10.0-1160.15.2.el7.x86_64
  14. fio Disk Speed Tests (Mixed R/W 50/50):
  15. ---------------------------------
  16. Block Size | 4k            (IOPS) | 64k           (IOPS)
  17.   ------   | ---            ----  | ----           ----
  18. Read       | 3.56 MB/s      (892) | 32.30 MB/s     (504)
  19. Write      | 3.60 MB/s      (900) | 32.61 MB/s     (509)
  20. Total      | 7.17 MB/s     (1.7k) | 64.92 MB/s    (1.0k)
  21.            |                      |
  22. Block Size | 512k          (IOPS) | 1m            (IOPS)
  23.   ------   | ---            ----  | ----           ----
  24. Read       | 103.53 MB/s    (202) | 163.05 MB/s    (159)
  25. Write      | 109.03 MB/s    (212) | 173.91 MB/s    (169)
  26. Total      | 212.56 MB/s    (414) | 336.97 MB/s    (328)
  27. iperf3 Network Speed Tests (IPv4):
  28. ---------------------------------
  29. Provider        | Location (Link)           | Send Speed      | Recv Speed
  30.                 |                           |                 |
  31. Clouvider       | London, UK (10G)          | 331 Mbits/sec   | 355 Mbits/sec
  32. Online.net      | Paris, FR (10G)           | busy            | busy
  33. Hybula          | The Netherlands (40G)     | 532 Mbits/sec   | 644 Mbits/sec
  34. Uztelecom       | Tashkent, UZ (10G)        | busy            | 195 Mbits/sec
  35. Clouvider       | NYC, NY, US (10G)         | 687 Mbits/sec   | 46.5 Mbits/sec
  36. Clouvider       | Dallas, TX, US (10G)      | 803 Mbits/sec   | busy
  37. Clouvider       | Los Angeles, CA, US (10G) | 757 Mbits/sec   | 833 Mbits/sec
  38. iperf3 Network Speed Tests (IPv6):
  39. ---------------------------------
  40. Provider        | Location (Link)           | Send Speed      | Recv Speed
  41.                 |                           |                 |
  42. Clouvider       | London, UK (10G)          | 554 Mbits/sec   | 488 Mbits/sec
  43. Online.net      | Paris, FR (10G)           | busy            | busy
  44. Hybula          | The Netherlands (40G)     | 542 Mbits/sec   | 573 Mbits/sec
  45. Uztelecom       | Tashkent, UZ (10G)        | 294 Mbits/sec   | 261 Mbits/sec
  46. Clouvider       | NYC, NY, US (10G)         | 894 Mbits/sec   | 864 Mbits/sec
  47. Clouvider       | Dallas, TX, US (10G)      | 926 Mbits/sec   | 926 Mbits/sec
  48. Clouvider       | Los Angeles, CA, US (10G) | 913 Mbits/sec   | 900 Mbits/sec
  49. Geekbench 5 Benchmark Test:
  50. ---------------------------------
  51. Test            | Value
  52.                 |
  53. Single Core     | 752
  54. Multi Core      | 760
  55. Full Test       | https://browser.geekbench.com/v5/cpu/17652631
流媒体
  1. ============[ Multination ]============
  2. Dazn:                                  No
  3. HotStar:                               Yes (Region: US)
  4. Disney+:                               Yes (Region: US)
  5. Netflix:                               Yes (Region: US)
  6. 有图比 Premium:                       Yes
  7. Amazon Prime Video:                    Yes (Region: US)
  8. TVBAnywhere+:                          Yes
  9. iQyi Oversea Region:                   US
  10. Viu.com:                               No
  11. 有图比 CDN:                           Chicago, IL
  12. Netflix Preferred CDN:                 Associated with [RETN Limited] in [Warsaw ]
  13. Spotify Registration:                  No
  14. Steam Currency:                        USD
  15. =======================================
  16. ===========[ North America ]===========
  17. FOX:                                   Yes
  18. Hulu:                                  Failed
  19. ESPN+:[Sponsored by Jam]               Yes
  20. Epix:                                  No
  21. Starz:                                 Yes
  22. HBO Now:                               Yes
  23. HBO Max:                               Yes
  24. BritBox:                               Yes
  25. NBA TV:                                Yes
  26. Fubo TV:                               Yes
  27. Sling TV:                              Yes
  28. Pluto TV:                              Yes
  29. Acorn TV:                              Yes
  30. SHOWTIME:                              Yes
  31. encoreTVB:                             Yes
  32. CineMax Go:                            Failed (Network Connection)
  33. Funimation:                            Yes (Region: US)
  34. Discovery+:                            Yes
  35. Paramount+:                            Yes
  36. Peacock TV:                            Yes
  37. Directv Stream:                        Yes
  38. ---CA---
  39. CBC Gem:                               No
  40. Crave:                                 No
  41. =======================================
带AFF:https://billing.leveloneservers.com/aff.php?aff=64&pid=88&promocode=BFNOW
不带AFF: https://billing.leveloneservers.com/aff.php?aff=0&pid=88&promocode=BFNOW
发表于 2022-10-1 00:04:04 | 只看该作者
还是上次闪购的那次吧
早卖完了
注册账号。等黑五抢吧
发表于 2022-9-30 22:35:11 | 只看该作者
没听过mjj上
发表于 2022-9-30 22:35:43 | 只看该作者
17.76保种+轻量离线下载挺舒服的
 楼主| 发表于 2022-9-30 22:36:58 | 只看该作者
已经有MJJ身先士卒了
我属于N批次
发表于 2022-9-30 22:38:31 | 只看该作者
建议换成图片
发表于 2022-9-30 22:38:45 来自手机 | 只看该作者
1T流量,那得多轻量呀
发表于 2022-9-30 22:39:50 | 只看该作者
512G容量才给1T流量
 楼主| 发表于 2022-9-30 22:40:32 | 只看该作者
louiejordan 发表于 2022-9-30 22:39
512G容量才给1T流量
上次没入就是纠结流量
这次没忍住还是上车了
发表于 2022-9-30 22:40:40 | 只看该作者
可以用来干些啥?
发表于 2022-9-30 22:41:24 | 只看该作者
senoc 发表于 2022-9-30 22:40
上次没入就是纠结流量
这次没忍住还是上车了
等黑五买欧洲鸡多香,这价格比这配置高的多的是
GMT+8, 2026-4-15 07:53 , Processed in 0.069720 second(s), 11 queries , Gzip On, MemCache On.
