查看: 2082|回复: 9
[疑问] How to re-install Centos yourself remotely
发表于 2012-2-27 21:30:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  大牛们 告诉下。这个必须服务器支持啥可以正常运行。。
sentris的机器。我正在重装..好像可以  ~~~~.. VPS的不知道行不行。。。
Assuming you currently have a Centos 5 64-bit that was installed by us (if you have or want 32-bit, set/use 32-bit accordingly).
Below will reinstall to Centos 5.6 64-bit, change it accordingly if you want other versions of centos.
1. SSH to your server and login as root
2. Type below:
mkdir /centos_install
cd /centos_install
wget http://vault.centos.org/5.6/os/x86_64/images/pxeboot/initrd.img
wget http://vault.centos.org/5.6/os/x86_64/images/pxeboot/vmlinuz
cp vmlinuz /boot/vmlinuz.cent.pxe
cp initrd.img /boot/initrd.img.cent.pxe3. Add to/Edit the grub menu.lst entry to load the pxe kernel (note: if you were already using grub you do not need to type again the first 2 lines)nano -w /etc/grub.conf
in that file paste this in BETWEEN "hiddenmenu" and "title CentOS..." (IMPORTANT):
title Centos Install (PXE)
root (hd0,0)
kernel /vmlinuz.cent.pxe vnc vncpassword=YOURPSW headless ip=YOURIP netmask=255.255.255.0 gateway=GATEWAYIP dns=8.8.8.8 ksdevice=eth0 method=http://vault.centos.org/5.6/os/x86_64/ lang=en_US keymap=us
initrd /initrd.img.cent.pxe
replace
YOURPSW with the VNC password you want setup
YOURIP with the ip of the box…
GATEWAYIP with the gateway assigned to your box
Hint: you can see the gateway ip by issuing
route -n | grep UG
once you have done this you need to count the number of times “title” appears in the file, press ctrl +x, and save the file
4. Reboot the server by typing
reboot
5. Assuming above is done correctly, you can then use vncviewer (download from realvnc.com) and connect to YOURIPHERE:1
And password is whatever you set above.
For Centos 6.2 64-bit, you can use this:
cd /centos_install
wget http://linux.mirrors.es.net/centos/6.2/os/x86_64/images/pxeboot/initrd.img
wget http://linux.mirrors.es.net/centos/6.2/os/x86_64/images/pxeboot/vmlinuz
root (hd0,0)
kernel /vmlinuz.cent.pxe vnc vncpassword=YOURPSW headless ip=YOURIP netmask=255.255.255.0 gateway=GATEWAYIP dns=8.8.8.8 ksdevice=eth0 method=http://linux.mirrors.es.net/centos/6.2/os/x86_64/ lang=en_US keymap=us
相关帖子
发表于 2012-2-27 21:32:15 | 只看该作者
作为二楼.我深感责任重大.要是我不回复..楼主还以为自己玩的是单机版的主机论坛,另外.我要摸摸4楼的狗头,我之所以不摸3楼的.是因为怕有孙子跟我抢2楼.一不小心就摸了自己.
发表于 2012-2-27 21:32:59 来自手机 | 只看该作者
3楼
发表于 2012-2-27 22:04:47 | 只看该作者
没有ipmi/kvm的吗
发表于 2012-2-27 22:05:35 | 只看该作者
去申请ipmi试试。。。
 楼主| 发表于 2012-2-27 22:06:19 | 只看该作者
guaku 发表于 2012-2-27 22:04
没有ipmi/kvm的吗
  没 我这样都重装好了。。
发表于 2012-2-27 22:12:55 | 只看该作者
winder 发表于 2012-2-27 21:32
作为二楼.我深感责任重大.要是我不回复..楼主还以为自己玩的是单机版的主机论坛,另外.我要摸摸4楼的狗头,我 ...
经典
发表于 2012-2-27 22:43:39 | 只看该作者
这个教程基本所以的机房都支持,包括在本地。
但是,路径一定一定一定要写对,不然。。。。
 楼主| 发表于 2012-2-27 22:44:54 | 只看该作者
但是,路径一定一定一定要写对,不然。。。。 ...
我的对了  现在在折腾中。。
发表于 2012-2-27 23:02:13 | 只看该作者
ㄒiger 发表于 2012-2-27 22:44
我的对了  现在在折腾中。。
kvm架构和xen-hvm架构的vps也可以这么做,之前试验成功。
GMT+8, 2026-5-4 16:03 , Processed in 0.076176 second(s), 14 queries , Gzip On, MemCache On.
