查看: 3665|回复: 7
[Windows VPS] 配置aspx环境,出现Server Error in '/' Application. Runtime Error 是怎
发表于 2012-2-27 13:52:28 | 只看该作者
c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\   给予user权限
 楼主| 发表于 2012-2-27 10:53:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Runtime Error
Description: An application error occurred on the server. The current custom error settings for this application prevent the details of the application error from being viewed remotely (for security reasons). It could, however, be viewed by browsers running on the local server machine.
Details: To enable the details of this specific error message to be viewable on remote machines, please create a <customErrors> tag within a "web.config" configuration file located in the root directory of the current web application. This <customErrors> tag should then have its "mode" attribute set to "Off".
<!-- Web.Config Configuration File -->
<configuration>
    <system.web>
        <customErrors mode="Off"/>
    </system.web>
</configuration>
Notes: The current error page you are seeing can be replaced by a custom error page by modifying the "defaultRedirect" attribute of the application's <customErrors> configuration tag to point to a custom error page URL.
<configuration>
    <system.web>
        <customErrors mode="RemoteOnly" defaultRedirect="mycustompage.htm"/>
    </system.web>
</configuration>
已经能正常运行php。asp 求解决aspx
发表于 2012-2-27 10:59:33 | 只看该作者
开显错,再看错误。
 楼主| 发表于 2012-2-27 13:35:56 | 只看该作者
The current identity (NT AUTHORITY\NETWORK SERVICE) does not have write access to 'c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Temporary ASP.NET Files'.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Web.HttpException: The current identity (NT AUTHORITY\NETWORK SERVICE) does not have write access to 'c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Temporary ASP.NET Files'.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[HttpException (0x80004005): The current identity (NT AUTHORITY\NETWORK SERVICE) does not have write access to 'c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Temporary ASP.NET Files'.]
   System.Web.HttpRuntime.SetUpCodegenDirectory(CompilationSection compilationSection) +8918190
   System.Web.HttpRuntime.HostingInit(HostingEnvironmentFlags hostingFlags) +152
   System.Web.HttpRuntime.FirstRequestInit(HttpContext context) +8890735
   System.Web.HttpRuntime.EnsureFirstRequestInit(HttpContext context) +85
   System.Web.HttpRuntime.ProcessRequestInternal(HttpWorkerRequest wr) +259
发表于 2012-2-27 13:38:14 | 只看该作者
微软的东西就是让人蛋疼
 楼主| 发表于 2012-2-27 14:08:25 | 只看该作者
已解决,谢谢了!!!~
发表于 2012-2-27 14:09:09 | 只看该作者
发表于 2012-2-27 14:18:17 来自手机 | 只看该作者
好吧
GMT+8, 2026-4-26 19:17 , Processed in 0.070810 second(s), 12 queries , Gzip On, MemCache On.
