查看: 3180|回复: 4
[疑问] theplanet存储云什么意思?
发表于 2010-2-15 13:52:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
前2天代购了一台theplanet服务器,因为很久以前代购过这家,现在居然老帐户无效,重新经过一系列复杂的验证,终于重新进了这家的门。
他们给我发来的邮件中有一个关于这个存储云的,没有用过,不知道怎么用,请C大和过来人看下。
Your Storage Cloud account has been created and is now ready for immediate use. Within the Orbit customer portal you will find the account information required to access your account. This includes username, as well as the application name and key.
ACCOUNT INFORMATION:
Username:xxx
Password: xxx
Application Key: xxx
Application Name: xxx
STORAGE CLOUD ACCESS METHODS
CloudNAS is the recommended access method for the Storage Cloud. It has two access methods- CloudNAS for Windows file systems and CloudNAS for Linux file systems. CloudNAS provides a local directory with local file system access to your Storage Cloud account. This directory allows you to copy files in/out, make directories, or edit files directly.
CloudNAS Download: http://downloads.theplanet.com/storagecloud
This link contains links to the CloudNAS installer and CloudNAS user manuals.
Activation Key
CloudNAS Activation Key (asked for during installation): xxx
Please do not lose your CloudNAS Activation Key. It will not appear in Orbit.
发表于 2010-2-15 14:05:22 | 只看该作者
原帖由 zhihao 于 2010-2-15 14:01 发表
云存储,你可以当作gd的免费空间一样用,用来做备份的。
发表于 2010-2-15 19:05:07 | 只看该作者
就是将鸡蛋放在多个篮子的意思。
发表于 2010-2-15 21:38:49 | 只看该作者
原帖由 cnx 于 2010-2-15 19:05 发表
就是将鸡蛋放在多个篮子的意思。
未来的趋势。。。
发表于 2010-2-15 23:06:22 | 只看该作者
GMT+8, 2026-4-20 00:01 , Processed in 0.061217 second(s), 10 queries , Gzip On, MemCache On.
