查看: 2475|回复: 10
20出个webhorizon李家坡
发表于 2022-9-16 16:41:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
128NAT-年付4.4刀-11月6号到期
原始邮箱给不了,不能改邮箱,开2步验证出。
有意回帖或者私聊。
附上流媒体测试:
[流媒体平台及游戏区域限制测试]
项目地址 https://github.com/lmc999/RegionRestrictionCheck
BUG反馈或使用交流可加TG群组 https://t.me/gameaccelerate
脚本适配OS: CentOS 6+, Ubuntu 14.04+, Debian 8+, MacOS, Android (Termux), iOS (iSH)
** 测试时间: Fri Sep 16 15:14:24 CEST 2022
** 正在测试IPv4解锁情况
** 您的网络为: Shock Hosting LLC ()
Dazn:                                        No
HotStar:                                No
Disney+:                                No
Netflix:                                Originals Only
有图比 Premium:                        Yes (Region: SG)
Amazon Prime Video:                        Yes (Region: SG)
iQyi Oversea Region:                        ->(23) Failed writing body
iQyi Oversea Region:                        Failed
Viu.com:                                Yes (Region: SG)
有图比 CDN:                                Singapore
Netflix Preferred CDN:                        ->/dev/fd/63: line 1909: nslookup: command not found
Netflix Preferred CDN:                        Failed (CDN IP Not Found)
Spotify Registration:                        No
Steam Currency:                        SGD
==============[ Oceania ]==============
NBA TV:                                Yes
Acorn TV:                                Yes
SHOWTIME:                                Yes
BritBox:                                Yes
Funimation:                                ->(23) Failed writing body
Paramount+:                                No
---AU---
Stan:                                        Yes
Binge:                                        No
Docplay:                                No
Channel 7:                                ->curl: no URL specified!
curl: try 'curl --help' or 'curl --manual' for more information
Channel 7:                                Failed (Network Connection)
Channel 9:                                No
Channel 10:                                No
ABC iView:                                No
Kayo Sports:                                No
Optus Sports:                                No
SBS on Demand:                                No
---NZ---
Neon TV:                                No
SkyGo NZ:                                Failed (Unexpected Result: 401)
ThreeNow:                                No
Maori TV:                                Yes
** 正在测试IPv6解锁情况
Dazn:                                        Failed (Network Connection)
HotStar:                                Yes (Region: SG)
Disney+:                                No
有图比 Premium:                        No
Amazon Prime Video:                        Unsupported
TVBAnywhere+:                                Failed (Network Connection)
Viu.com:                                Failed
有图比 CDN:                                Singapore
Netflix Preferred CDN:                        ->/dev/fd/63: line 1901: nslookup: command not found
Steam Currency:                        Failed (Network Connection)
NBA TV:                                Yes
Acorn TV:                                Failed (Network Connection)
SHOWTIME:                                Failed (Network Connection)
BritBox:                                Yes
Funimation:                                IPv6 Not Support
Paramount+:                                Yes
---AU---
Stan:                                        ->curl: (6) Could not resolve host: api.stan.com.au
Stan:                                        Failed (Network Connection)
Binge:                                        No
Docplay:                                ->curl: (6) Could not resolve host: www.docplay.com
Docplay:                                Yes
Channel 7:                                IPv6 Not Support
Channel 9:                                No
Channel 10:                                Failed (Network Connection)
ABC iView:                                ->curl: (6) Could not resolve host: api.iview.abc.net.au
ABC iView:                                Failed (Network Connection)
Kayo Sports:                                Yes
Optus Sports:                                No
SBS on Demand:                                Failed (Network Connection)
---NZ---
Neon TV:                                ->curl: (6) Could not resolve host: api.neontv.co.nz
Neon TV:                                Failed (Network Connection)
SkyGo NZ:                                Failed (Network Connection)
ThreeNow:                                Failed (Network Connection)
Maori TV:                                Failed (Network Connection)
本次测试已结束,感谢使用此脚本
发表于 2022-9-16 16:52:54 | 只看该作者
请教一下老哥,这个怎么转号?我也有一个想出了
 楼主| 发表于 2022-9-16 17:22:02 | 只看该作者
刚刚才发现这玩意改不了邮箱,只能开2步验证。。
发表于 2022-9-16 17:23:50 | 只看该作者
应该可以 昨天收了一个 就是改邮箱收的 具体怎么改不清楚
发表于 2022-9-16 17:30:46 来自手机 | 只看该作者
那个改的邮箱没啥用 他这个机器有两个控制面板 其中一个控制面板是没法改邮箱的 而且这个控制面板更底层
发表于 2022-9-16 17:37:02 | 只看该作者
mingyun 发表于 2022-9-16 17:30
那个改的邮箱没啥用 他这个机器有两个控制面板 其中一个控制面板是没法改邮箱的 而且这个控制面板更底层  ...
哪里的控制面板 有链接吗 我看看去
发表于 2022-9-16 17:44:32 | 只看该作者
renny 发表于 2022-9-16 17:37
哪里的控制面板 有链接吗 我看看去
我没有那个链接  我上一次收的别人的新加坡的 那个老哥给我了两个连接 两个里面只有一个能改邮箱 但是两个面板都可以控制
发表于 2022-9-16 21:15:02 | 只看该作者
多谢老哥
GMT+8, 2026-4-22 17:23 , Processed in 0.066667 second(s), 10 queries , Gzip On, MemCache On.
