查看: 2461|回复: 0
[Windows VPS] sonicvps 回的tk
发表于 2012-2-26 16:46:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
We addressed a few issues:
1. Users who don't immediately install their VM use 100% CPU at start up - these are all manually shut down. It's a bug in KVM. Users simply just need to boot their node when they want to install.
2. Disk I/O: Swap was enabled on KVM03. Swap needs to be disabled so no hard dish space is cached and used as RAM, which is obviously a significant bottleneck. One this was disabled, it caused KVM to play up.
All nodes are currently booting up now. We've modifed a few scripts to prevent this happening again, it will be changed on all nodes.
We apologize for this slight inconvenience, but it's to improve overall performance for everyone, and you can be rest assured that you will be able to see the difference.
Please do some testing, send us some bench marks if you still think things are not running as they should and we'll continue to look in to it.
Thank you to all clients that actually work through with us when addressing issues. We really do appreciate the patience.
Richard Kwan
Support Technician
貌似还是没有解决问题
GMT+8, 2026-4-14 22:27 , Processed in 0.058623 second(s), 10 queries , Gzip On, MemCache On.
