查看: 3673|回复: 6
[Windows VPS] 求助datashack家 IP申请表 谁会编写呢?看不懂,有知道的
发表于 2012-2-25 17:25:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
DataShack.net                                IP Justification
As part of its standard service, DataShack will assign the amount of IP addresses that customers can justify for use on their server(s). Use this form for initial assignments and additional augments. DataShack.net conforms to the North American IP Registry (ARIN) policies regarding IP address allocation.  We require a written justification form for any IP address blocks requested so that we can demonstrate to ARIN that IP addresses allocated to DataShack are being used efficiently.  Per ARIN guidelines (http://www.arin.net/intro.html), organizations will be assigned address space based on immediate utilization plus three month utilization rate and supply documentation to justify the level of confidence. If you have any questions about the IP assignment policy or process, please refer to the IP Address Assignment Policy and Procedures, and RFC 2050 (ftp://www.arin.net/rfc/rfc2050.txt).  The form for justifying IP use is provided below.  Please complete the form and attach to corresponding ticket. Thank you.
Customer :                                        Technical Contact:
Server  Name                                        ARIN Handle
E-mail                                                Name(Last, First)
Phone Number                                        Title
                                                Phone Number
                                                E-mail
Number of IP addresses required:
A.        Now:
B.        Within three months:
Number of IP addresses requested:                                                Note: If your organization already has IP space assigned, you must utilize 80% before applying for more IP space.
Please use the space provided to describe why you require the number of IP addresses requested.  Please also indicate whether you are conserving address space using address translation.
Please complete a network table to show you have used any existing IP assignments, and show predicted future growth of your network.
                                        SAMPLE
        IP Range         Subnet Mask                Max        Now        3 mo        Description                74.91.x.0         255.255.255.224        29        8        12        SSL based websites
        71.91.x.64         255.255.255.240        13        10        13        Multiple website hosting
        74.91.x.0        255.255.255.0                253        203        250        Client VPS
Use the following Network Table to describe your IP assignments today and in three months.  Expand the table as necessary to accommodate your requirements.  THIS IS REQUIRED!
Include a list of all Domains that will be used on this server:
I verify that I am authorized to represent the organization below and that the above information is true and correct.  I understand that Internet Protocol Version 4 address space is limited and that users of the Internet are responsible for conserving address space and ensuring that space is utilized efficiently.
Print Name                                        Title
Organization                                        Phone# (day)
Email                                                Fax
For Internal Use Only:
                        Customer:                                   Order Number:
Customer Network                                Network Interface
CIDR        Network        Netmask                CIDR        Network        Netmask
有知道的帮助下哈!
发表于 2012-2-25 17:33:56 | 只看该作者
看不懂
发表于 2012-2-25 17:49:06 | 只看该作者
堪萨斯机房 如果再我这边买的 直接一句话 就行了 不用填表
发表于 2012-2-25 17:51:30 | 只看该作者
楼上是高手
发表于 2012-2-25 17:52:03 | 只看该作者
不是吧。。。。
这个没难度吧
发表于 2012-2-25 17:52:49 | 只看该作者
其实他两是一个。。。
发表于 2012-2-25 20:45:11 | 只看该作者
GMT+8, 2026-4-29 22:54 , Processed in 0.196271 second(s), 13 queries , Gzip On, MemCache On.
