查看: 2375|回复: 13
HH 离线
发表于 2022-9-9 12:46:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
HH, HK 216 段离线了吗
发表于 2022-9-9 12:47:01 来自手机 | 只看该作者
收 hh  hk   出的大佬pm我
发表于 2022-9-9 12:52:04 来自手机 | 只看该作者
维护你没收到邮件吗
发表于 2022-9-9 12:54:04 | 只看该作者
9点多就恢复了吧
发表于 2022-9-9 12:58:02 | 只看该作者
是离线了吗?也是216的 TM的衰人,我刚重装系统,然后一直连不了,也ping不通,还以为我这出什么问题了。
发表于 2022-9-9 12:59:19 | 只看该作者
fangfang22 发表于 2022-9-9 12:52
维护你没收到邮件吗
我没有收到维护邮件
发表于 2022-9-9 13:04:26 | 只看该作者
老哥是2年60刀的吗? 如果是的配置发一个看下,我感觉HH忽悠我了
发表于 2022-9-9 13:06:25 | 只看该作者
mazilong 发表于 2022-9-9 12:59
我没有收到维护邮件
You are receiving this email because you currently have an active VM in Hong Kong with us, that has an IP address assigned from the range 194.29.186.0/24
In the recent past, we have outgrown our network design and capacity in this location, and have decided to install the new Juniper kits with 40G capacity, as is the standard in all of our other locations.
We will be performing a migration to our new network infrastructure in the coming few days.
Your active VMs in the IP range above will be migrated during the following time window:
Friday, 9th September 2022
Start: 16:00 GMT+8
End: 20:00 GMT+8
Total expected downtime: <15 minutes
Expected impact: Shutdown and boot, no data changes
发表于 2022-9-9 13:07:32 | 只看该作者
2021-08-10 hosthatch香港 65美元每两年(422.16)2核 8G 40G SSD 2T流量 1Gbps带宽
我是这款
 楼主| 发表于 2022-9-9 13:12:43 | 只看该作者
fangfang22 发表于 2022-9-9 13:06
You are receiving this email because you currently have an active VM in Hong Kong with us, that ha ...
看来因该和维护有关
GMT+8, 2026-4-15 15:28 , Processed in 0.063962 second(s), 8 queries , Gzip On, MemCache On.
