查看: 1558|回复: 8
[特价VPS] 长期出租op的5o 巴黎的5欧
发表于 2022-9-7 14:53:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
oneprovide,法国巴黎,C2350,4GB内存1TB硬盘,2.5G口对等宽带不限流量,IO100左右,40/月,115/季度,给root和密码,随时帮重装系统。站内PM或者电报 https://t.me/urmdr
  1. -------------------- A Bench.sh Script By Teddysun -------------------
  2. Version            : v2022-06-01
  3. Usage              : wget -qO- bench.sh | bash
  4. ----------------------------------------------------------------------
  5. CPU Model          : Intel(R) Atom(TM) CPU  C2350  [url=home.php?mod=space&uid=175]@[/url] 1.74GHz
  6. CPU Cores          : 2 @ 1745.555 MHz
  7. CPU Cache          : 1024 KB
  8. AES-NI             : Enabled
  9. VM-x/AMD-V         : Enabled
  10. Total Disk         : 914.9 GB (6.0 GB Used)
  11. Total Mem          : 3.8 GB (208.9 MB Used)
  12. Total Swap         : 976.0 MB (0 Used)
  13. System uptime      : 11 days, 12 hour 49 min
  14. Load average       : 0.32, 0.27, 0.11
  15. OS                 : Debian GNU/Linux 11
  16. Arch               : x86_64 (64 Bit)
  17. Kernel             : 5.18.0-0.bpo.1-amd64
  18. TCP CC             : bbrx
  19. Virtualization     : Dedicated
  20. Organization       : AS12876 ONLINE S.A.S.
  21. Location           : Paris / FR
  22. Region             : Île-de-France
  23. ----------------------------------------------------------------------
  24. I/O Speed(1st run) : 98.4 MB/s
  25. I/O Speed(2nd run) : 99.4 MB/s
  26. I/O Speed(3rd run) : 98.8 MB/s
  27. I/O Speed(average) : 98.9 MB/s
  28. ----------------------------------------------------------------------
  29. Node Name        Upload Speed      Download Speed      Latency
  30. Speedtest.net    2344.75 Mbps      2362.77 Mbps        0.62 ms
  31. Los Angeles, US  626.16 Mbps       1410.98 Mbps        145.12 ms
  32. Dallas, US       769.03 Mbps       1532.58 Mbps        117.67 ms
  33. Montreal, CA     412.06 Mbps       554.88 Mbps         95.45 ms
  34. Paris, FR        1704.74 Mbps      2338.42 Mbps        1.13 ms
  35. Amsterdam, NL    1728.84 Mbps      2375.02 Mbps        13.04 ms
  36. Shanghai, CN     1162.87 Mbps      1784.96 Mbps        275.03 ms
  37. Nanjing, CN      23.87 Mbps        957.08 Mbps         310.85 ms
  38. Seoul, KR        325.52 Mbps       468.59 Mbps         201.93 ms
  39. Singapore, SG    573.74 Mbps       955.76 Mbps         148.89 ms
  40. Tokyo, JP        384.97 Mbps       876.76 Mbps         235.15 ms
  41. ----------------------------------------------------------------------
  3. #                     v2022-08-20                    #
  6. Wed 07 Sep 2022 02:22:57 AM EDT
  7. Basic System Information:
  9. Uptime     : 11 days, 12 hours, 58 minutes
  10. Processor  : Intel(R) Atom(TM) CPU  C2350  @ 1.74GHz
  11. CPU cores  : 2 @ 1667.301 MHz
  12. AES-NI     : ✔ Enabled
  13. VM-x/AMD-V : ✔ Enabled
  14. RAM        : 3.8 GiB
  15. Swap       : 976.0 MiB
  16. Disk       : 914.9 GiB
  17. Distro     : Debian GNU/Linux 11 (bullseye)
  18. Kernel     : 5.18.0-0.bpo.1-amd64
  19. fio Disk Speed Tests (Mixed R/W 50/50):
  20. ---------------------------------
  21. Block Size | 4k            (IOPS) | 64k           (IOPS)
  22.   ------   | ---            ----  | ----           ----
  23. Read       | 300.00 KB/s     (75) | 3.75 MB/s       (58)
  24. Write      | 317.00 KB/s     (79) | 4.02 MB/s       (62)
  25. Total      | 617.00 KB/s    (154) | 7.77 MB/s      (120)
  26.            |                      |
  27. Block Size | 512k          (IOPS) | 1m            (IOPS)
  28.   ------   | ---            ----  | ----           ----
  29. Read       | 17.84 MB/s      (34) | 22.58 MB/s      (22)
  30. Write      | 19.47 MB/s      (38) | 24.94 MB/s      (24)
  31. Total      | 37.31 MB/s      (72) | 47.52 MB/s      (46)
  32. iperf3 Network Speed Tests (IPv4):
  33. ---------------------------------
  34. Provider        | Location (Link)           | Send Speed      | Recv Speed
  35.                 |                           |                 |
  36. Clouvider       | London, UK (10G)          | 1.79 Gbits/sec  | 2.37 Gbits/sec
  37. Online.net      | Paris, FR (10G)           | 1.79 Gbits/sec  | busy
  38. Hybula          | The Netherlands (40G)     | 1.78 Gbits/sec  | 2.35 Gbits/sec
  39. Uztelecom       | Tashkent, UZ (10G)        | 1.71 Gbits/sec  | 1.39 Gbits/sec
  40. Clouvider       | NYC, NY, US (10G)         | 1.73 Gbits/sec  | 1.09 Gbits/sec
  41. Clouvider       | Dallas, TX, US (10G)      | 1.57 Gbits/sec  | 583 Mbits/sec
  42. Clouvider       | Los Angeles, CA, US (10G) | 1.20 Gbits/sec  | 721 Mbits/sec
  43. Geekbench 5 Benchmark Test:
  44. ---------------------------------
  45. Test            | Value
  46.                 |
  47. Single Core     | 184
  48. Multi Core      | 345
  49. Full Test       | https://browser.geekbench.com/v5/cpu/17105265
  1.    Speedtest by Ookla
  2.       Server: Asthriona - Paris (id: 10676)
  3.          ISP: Scaleway
  4. Idle Latency:     0.75 ms   (jitter: 0.02ms, low: 0.72ms, high: 0.77ms)
  5.     Download:  2333.52 Mbps (data used: 1.0 GB)
  6.                   3.29 ms   (jitter: 0.65ms, low: 1.21ms, high: 5.99ms)
  7.       Upload:  2360.09 Mbps (data used: 1.1 GB)
  8.                   2.73 ms   (jitter: 0.76ms, low: 1.62ms, high: 8.99ms)
  9. Packet Loss:     0.0%
  10.   Result URL: https://www.speedtest.net/result/c/07cec67d-7958-40a5-8c0d-575dd761aa14
发表于 2022-9-7 15:27:57 来自手机 | 只看该作者
为什么不直接网站买
发表于 2022-9-7 14:59:05 | 只看该作者
2.5g口可还行
发表于 2022-9-7 15:02:40 | 只看该作者
同出租,IO比楼主的差,别的都一样,可以便宜。
 楼主| 发表于 2022-9-7 17:01:02 | 只看该作者
Howardlink 发表于 2022-9-7 15:27
为什么不直接网站买
IO和宽带要抽奖
 楼主| 发表于 2022-9-8 11:36:22 | 只看该作者
顶一下
发表于 2022-9-8 11:48:25 | 只看该作者
这个确实厉害 我整了几次都没挣到
 楼主| 发表于 2022-9-10 19:19:02 | 只看该作者
长期出租,需要的站内PM或者电报联系。
 楼主| 发表于 2022-10-4 19:37:06 | 只看该作者
长期继续出租,有需求的站内PM或者电报联系 https://t.me/urmdr
GMT+8, 2026-4-22 09:48 , Processed in 0.063531 second(s), 11 queries , Gzip On, MemCache On.
