查看: 1601|回复: 8
[疑问] HH的香港是不是有问题?
发表于 2022-9-6 19:10:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
HH的香港是不是有问题?
发表于 2022-9-6 19:11:52 | 只看该作者
啥问题? 说说
发表于 2022-9-6 19:12:34 | 只看该作者
问题在哪啊?找了半天品了半天,也没品出问题在哪
 楼主| 发表于 2022-9-6 19:18:04 | 只看该作者
小猫咪显示都是通的,就是访问不了外面,机器也能正常访问
发表于 2022-9-6 19:25:03 来自手机 | 只看该作者
You are receiving this email because you currently have an active VM in Hong Kong with us, that has an IP address assigned from the range 103.73.66.0/24   In the recent past, we have outgrown our network design and capacity in this location, and have decided to install the new Juniper kits with 40G capacity, as is the standard in all of our other locations.   We will be performing a migration to our new network infrastructure in the coming few days.   Your active VMs in the IP range above will be migrated during the following time window:  Sunday, 11th September 2022 Start: 14:00 GMT+8 End: 20:00 GMT+8 Total expected downtime: <15 minutes Expected impact: Shutdown and boot, no data changes  Please note if you are using a legacy VM, the following applies to you:  During this maintenance, we will make updates to the host server, and also boot it into our new cloud platform - cloud.hosthatch.com, from where you will be able to manage your server after it comes back online   Please note if
发表于 2022-9-7 08:33:07 | 只看该作者
收到邮件说要升级40G,不知道具体哪天开始搞
发表于 2022-9-7 08:40:19 | 只看该作者
好像是有点问题
发表于 2022-9-7 09:00:18 来自手机 | 只看该作者
升级了吗?  ip会变吗?
 楼主| 发表于 2022-9-7 09:02:44 | 只看该作者
半夜小鸡重启了,现在恢复了,IP没变
GMT+8, 2026-5-1 06:13 , Processed in 0.062787 second(s), 10 queries , Gzip On, MemCache On.
