CeraNetworks网络延迟测速工具IP归属甄别
查看: 4002|回复: 4
偶去了Secured Servers 溜达。然后跟客服扯了几句。
发表于 2012-2-22 18:50:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Order Summary Price/Period   Setup
  X3430 (2bays) $ 78.00
  RAM Upgrade: 8 GB REG ECC DDR3 $ 20.00
  Raid Options: Software RAID 1
  Primary Hard Drive Options: 500 GB Enterprise Grade SATA II (Standard) $ 0.00
  Hard Drive 2 Options: 500 GB Enterprise Grade SATA II $ 15.00
  Bandwidth : 3200 GB Transfer (1 Gbps Uplink)  $ 5.00
  Primary IP Allocation: /29 IP allocation (5 usable IPs) = Standard $ 0.00
  Additional IP Addresses: /27 IP allocation (29 Ip's) = $26 per month  $ 26.00
  Operating System: Custom (Client Installed via IPKVM)
Total Cost $ 144.00   0.00
这是偶看着弄出来的一个配置。
然后跟他们的客服扯了几句。
Me: I want to know what line do you use?
I am referring to the routing line.Such as CO, or by HE?
Customer server:  We use a blend of a few major providers including: Level3, Global Crossing, Highwinds, and Cogent.
these carriers are a part of our BGP blend.
然后客服给了我一个测试IP:174.138.175.114
Tracing route to 174.138.175.114 over a maximum of 30 hops
  1    <1 ms    <1 ms    <1 ms  192.168.1.1
  2     2 ms     3 ms     3 ms  59.46.65.209
  3     2 ms     2 ms     2 ms  219.148.240.73
  4     2 ms     2 ms     2 ms  219.148.240.29
  5     9 ms    10 ms     8 ms  219.148.216.17
  6    27 ms    27 ms    27 ms  202.97.54.109
  7    28 ms    28 ms    28 ms  202.97.53.158
  8    27 ms    27 ms    29 ms  202.97.53.246
  9   217 ms   216 ms   216 ms  202.97.51.190
10   216 ms   198 ms   198 ms  202.97.50.62
11   451 ms   426 ms   420 ms  te3-2.mpd01.sjc03.atlas.cogentco.com [154.54.11.89]
12   193 ms   194 ms   193 ms  te3-2.mpd01.sjc01.atlas.cogentco.com [154.54.6.81]
13   254 ms   251 ms   245 ms  te0-3-0-2.ccr21.lax01.atlas.cogentco.com [154.54.25.185]
14   244 ms   241 ms   311 ms  te3-4.ccr01.phx02.atlas.cogentco.com [154.54.80.202]
15   256 ms   261 ms   261 ms  vl3812.na41.b023003-0.phx02.atlas.cogentco.com [38.20.49.218]
16   261 ms   262 ms   265 ms  38.104.116.74
17     *        *        *     Request timed out.
18   255 ms   253 ms   263 ms  64.38.200.29
19   239 ms   240 ms   245 ms  174.138.175.114
Trace complete.
偶是沈阳广电宽带,广东电信出口。
大家看这个测试IP是否给力?
发表于 2012-2-22 22:31:38 | 只看该作者
不抽风的话
可以的
发表于 2012-2-22 22:32:54 | 只看该作者
2个盘 Software RAID 1
效果好吗?
发表于 2012-2-23 16:04:21 | 只看该作者
肯定没有Peer1 电信12跳给力
 楼主| 发表于 2012-2-24 09:22:40 | 只看该作者
08host 发表于 2012-2-23 16:04
肯定没有Peer1 电信12跳给力
价格在那里摆着呢。但是据他们所给的IP,表现确实不错。
GMT+8, 2026-4-14 10:48 , Processed in 0.207009 second(s), 13 queries , Gzip On, MemCache On.
