查看: 3564|回复: 14
hostigation 牛逼的 磁盘。!~!
发表于 2012-2-22 16:28:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我有一个oz 10美元的     今天心血来潮 测试一下。差点没乐死我。
Last login: Wed Feb 22 02:50:06 2012 from 61.137.189.131
[root@zijivps ~]# wget http://cachefly.cachefly.net/100mb.test
--2012-02-22 02:52:35--  http://cachefly.cachefly.net/100mb.test
Resolving cachefly.cachefly.net... 205.234.175.175
Connecting to cachefly.cachefly.net|205.234.175.175|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 104857600 (100M) [application/octet-stream]
Saving to: ?.00mb.test?
100%[===============================================================>] 104,857,600 54.5M/s   in 1.8s
2012-02-22 02:52:37 (54.5 MB/s) - ?.00mb.test?.saved [104857600/104857600]
[root@zijivps ~]#
[root@zijivps ~]# dd if=/dev/zero of=test bs=64k count=4k oflag=dsync
4096+0 records in
4096+0 records out
268435456 bytes (268 MB) copied, 158.939 s, 1.7 MB/s
You have new mail in /var/spool/mail/root
[root@zijivps ~]#
4096+0 records in
4096+0 records out
268435456 bytes (268 MB) copied, 74.7623 s, 3.6 MB/s
[root@zijivps ~]#
4096+0 records in
4096+0 records out
268435456 bytes (268 MB) copied, 81.5272 s, 3.3 MB/s
[root@zijivps ~]#
发表于 2012-2-22 16:29:22 | 只看该作者
  1. dd if=/dev/zero of=test bs=64k count=4k
发表于 2012-2-22 16:29:25 | 只看该作者
看不出来nb
发表于 2012-2-22 16:30:39 | 只看该作者
还不是 钻石级的,钻石级的约17K/s
发表于 2012-2-22 16:31:24 | 只看该作者
root@host:~# dd if=/dev/zero of=test.bin bs=64k count=4k conv=fdatasync && rm -r             f test.bin
dd if=/dev/zero of=test.bin bs=64k count=4k conv=fdatasync && rm -rf test.bin
dd if=/dev/zero of=test.bin bs=64k count=4k oflag=dsync && rm -rf test.bin
4096+0 records in
4096+0 records out
268435456 bytes (268 MB) copied, 1.48298 s, 181 MB/s
root@host:~# dd if=/dev/zero of=test.bin bs=64k count=4k oflag=dsync && rm -rf t             est.bin
4096+0 records in
4096+0 records out
268435456 bytes (268 MB) copied, 4.50589 s, 59.6 MB/s
4096+0 records in
4096+0 records out
268435456 bytes (268 MB) copied, 1.40463 s, 191 MB/s
4096+0 records in
4096+0 records out
268435456 bytes (268 MB) copied, 4.70855 s, 57.0 MB/s
4096+0 records in
4096+0 records out
268435456 bytes (268 MB) copied, 1.51558 s, 177 MB/s
4096+0 records in
4096+0 records out
268435456 bytes (268 MB) copied, 4.71793 s, 56.9 MB/s
发表于 2012-2-22 16:33:21 | 只看该作者
这个硬盘速度不给力啊
发表于 2012-2-22 16:33:57 | 只看该作者
好给力的石头
发表于 2012-2-22 16:36:53 | 只看该作者
好强力的金刚石……
 楼主| 发表于 2012-2-22 16:38:24 | 只看该作者
**。气死我了。   10美元一个月呢。就这质量啊。网络真不错。就**磁盘儿子。
发表于 2012-2-22 16:43:10 | 只看该作者
他家的最早一批,3刀KVM,很给力。
GMT+8, 2026-5-4 02:40 , Processed in 0.069355 second(s), 8 queries , Gzip On, MemCache On.
