查看: 2342|回复: 8
[不限流量] 动易数据T楼128MB XEN测试结果
发表于 2012-2-22 11:32:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
前几天T中了一台动易数据的VPS,大家都按照惯例写了结果在这边,因为最近确实私事一堆,我装了个lnmp就一直没动,今天抽空发下。
前面有朋友也基本上说了, 母鸡84斯克兰顿,配置就直接看探针吧
http://184.22.87.170/p.php
128MB内存,256MB的SWAP,20GB硬盘,100GB月流量
探针只看到10GB硬盘,可能还有一半要挂载,就没去弄了。
CPU:i5-2400*1
端口速率和DD结果:
[root@MyVPS ~]# wget http://cachefly.cachefly.net/100mb.test
--2012-02-22 03:30:08--  http://cachefly.cachefly.net/100mb.test
Resolving cachefly.cachefly.net... 205.234.175.175
Connecting to cachefly.cachefly.net|205.234.175.175|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 104857600 (100M) [application/octet-stream]
Saving to: `100mb.test'
100%[======================================>] 104,857,600 8.31M/s   in 12s
2012-02-22 03:30:20 (8.25 MB/s) - `100mb.test' saved [104857600/104857600]
[root@MyVPS ~]# dd if=/dev/zero of=test bs=64k count=16k conv=fdatasync
16384+0 records in
16384+0 records out
1073741824 bytes (1.1 GB) copied, 33.7087 seconds, 31.9 MB/s
[root@MyVPS ~]# dd if=/dev/zero of=test bs=64k count=4k oflag=dsync
4096+0 records in
4096+0 records out
268435456 bytes (268 MB) copied, 13.0957 seconds, 20.5 MB/s
使用国人常见的XENSERVER面板,虽然面板端口写的2M,但是貌似是百兆共享的吧,可能是2M保证。
Benchmark Run: Wed Feb 22 2012 03:39:16 - 04:07:55
1 CPU in system; running 1 parallel copy of tests
Dhrystone 2 using register variables       14944277.9 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     2668.4 MWIPS (10.0 s, 7 samples)
Execl Throughput                               2866.9 lps   (30.0 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        571046.8 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks          153346.4 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks       1572032.8 KBps  (30.0 s, 2 samples)
Pipe Throughput                              784558.4 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                 112687.3 lps   (10.0 s, 7 samples)
Process Creation                               5400.0 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   4641.7 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                    656.7 lpm   (60.1 s, 2 samples)
System Call Overhead                         549935.6 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   14944277.9   1280.6
Double-Precision Whetstone                       55.0       2668.4    485.2
Execl Throughput                                 43.0       2866.9    666.7
File Copy 1024 bufsize 2000 maxblocks          3960.0     571046.8   1442.0
File Copy 256 bufsize 500 maxblocks            1655.0     153346.4    926.6
File Copy 4096 bufsize 8000 maxblocks          5800.0    1572032.8   2710.4
Pipe Throughput                               12440.0     784558.4    630.7
Pipe-based Context Switching                   4000.0     112687.3    281.7
Process Creation                                126.0       5400.0    428.6
Shell Scripts (1 concurrent)                     42.4       4641.7   1094.7
Shell Scripts (8 concurrent)                      6.0        656.7   1094.5
System Call Overhead                          15000.0     549935.6    366.6
System Benchmarks Index Score                                         779.3
建议:首页还需大力完善......
发表于 2012-2-22 11:32:44 | 只看该作者
动易.....这名字......
发表于 2012-2-22 11:44:52 | 只看该作者
看错,还以为是T某个站的数据
发表于 2012-2-22 12:51:43 | 只看该作者
dvbbs
发表于 2012-2-22 12:54:28 | 只看该作者
动网论坛。。。
发表于 2012-2-22 12:56:44 | 只看该作者
动易CMS
发表于 2012-2-22 13:00:13 | 只看该作者
这个 个动网论坛很相似
发表于 2012-2-22 13:00:49 | 只看该作者
貌似我这破站名起的……
发表于 2012-2-22 14:50:57 | 只看该作者
pinbar 发表于 2012-2-22 13:00
貌似我这破站名起的……
霸气
GMT+8, 2026-4-13 22:26 , Processed in 0.175309 second(s), 12 queries , Gzip On, MemCache On.
