查看: 2289|回复: 14
[美国VPS] signaltransmitter 评测 4核16G100G
发表于 2022-8-20 21:17:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
9.99欧,还行吧?》
  1. LemonBench Linux System Benchmark Utility Version 20201005 Intl BetaVersion
  2. Bench Start Time:        2022-08-20 12:08:29
  3. Bench Finish Time:        2022-08-20 12:51:35
  4. Test Mode:                Full Mode
  5. -> System Information
  6. OS Release:                Ubuntu 20.04.4 LTS (Focal Fossa)  (x86_64)
  7. CPU Model:                Intel(R) Xeon(R) Gold 5120 CPU [url=home.php?mod=space&uid=175]@[/url] 2.20GHz  2.20 GHz
  8. CPU Cache Size:        16384 KB
  9. CPU Number:                4 vCPU
  10. Virt Type:                KVM
  11. Memory Usage:                243.41 MB / 15.64 GB
  12. Swap Usage:                [ No Swapfile / Swap partition ]
  13. Disk Usage:                2.02 GB / 101.45 GB
  14. Boot Device:                /dev/sda1
  15. Load (1/5/15min):        1.39 1.34 0.94
  16. CPU Usage:                0.0% used, 0.0% iowait, 0.0% steal
  17. Kernel Version:        5.4.0-72-generic
  18. Network CC Method:        bbr + fq
  19. -> Network Information
  20. -> Media Unlock Test
  21. HBO Now:                                No
  22. Bahamut Anime:                                Failed (due to parse fail)
  23. Abema.TV:                                No
  24. Princess Connect Re:Dive Japan:        Yes
  25. BBC:                                        No
  26. Bilibili China Mainland Only:                No
  27. Bilibili Hongkong/Macau/Taiwan:        No
  28. Bilibili Taiwan Only:                        No
  29. -> CPU Performance Test (Standard Mode, 3-Pass @ 30sec)
  30. 1 Thread Test:                        842 Scores
  31. 4 Threads Test:                3376 Scores
  32. -> Memory Performance Test (Standard Mode, 3-Pass @ 30sec)
  33. 1 Thread - Read Test :                17411.64 MB/s
  34. 1 Thread - Write Test:                12177.67 MB/s
  35. -> Disk Speed Test (4K Block/1M Block, Direct-Write)
  36. Test Name                Write Speed                                Read Speed
  37. 10MB-4K Block                457 kB/s (111 IOPS, 22.94 s)                42.4 MB/s (10351 IOPS, 0.25 s)
  38. 10MB-1M Block                1.3 GB/s (1209 IOPS, 0.01 s)                2.1 GB/s (1968 IOPS, 0.01 s)
  39. 100MB-4K Block                4.6 MB/s (1114 IOPS, 22.97 s)                40.8 MB/s (9964 IOPS, 2.57 s)
  40. 100MB-1M Block                1.8 GB/s (1753 IOPS, 0.06 s)                2.2 GB/s (2055 IOPS, 0.05 s)
  41. 1GB-4K Block                2.4 MB/s (574 IOPS, 445.37 s)                16.1 MB/s (3936 IOPS, 65.04 s)
  42. 1GB-1M Block                5.3 MB/s (5 IOPS, 198.73 s)                170 MB/s (162 IOPS, 6.17 s)
  43. -> Speedtest.net Network Speed Test
  44. Node Name                        Upload Speed        Download Speed        Ping Latency        Server Name
  45. Speedtest Default                72.28 MB/s        71.25 MB/s        4.76 ms                goetel GmbH (Germany G枚ttingen)
  46. China, Nanjing CU                  Fail: Timeout Exceeded after 60 seconds
  47. China, Shanghai CU                 19.32 MB/s        72.29 MB/s        187.35 ms        China Unicom 5G (China ShangHai)
  48. China, Hangzhou CT                 Fail: Timeout Exceeded after 60 seconds
  49. China, Nanjing CT                  32.09 MB/s        72.85 MB/s        263.25 ms        China Telecom JiangSu 5G (China Nanjing)
  50. China, Guangzhou CT                Fail: Timeout Exceeded after 60 seconds
  51. China, Wuhan CT                    0.91 MB/s        27.68 MB/s        270.52 ms        China Telecom Wuhan Branch (China Wuhan)
  52. China, Shenyang CM                 Fail: Timeout Exceeded after 60 seconds
  53. China, Hangzhou CM                 Fail: Timeout Exceeded after 60 seconds
  54. China, Nanning CM                  38.28 MB/s        72.51 MB/s        250.90 ms        GX ChinaMobile (China Nanning)
  55. China, Lanzhou CM                  41.05 MB/s        58.76 MB/s        223.48 ms        Lanzhou,China Mobile,Gansu (China Lanzhou)
  56. Hong Kong, CSL                     17.06 MB/s        0.20 MB/s        180.32 ms        CSL (Hong Kong Kwai Chung)
  57. Hong Kong, PCCW                    52.49 MB/s        72.67 MB/s        164.55 ms        STC (China Hong Kong)
  58. Korea, South Korea                 38.22 MB/s        56.42 MB/s        233.33 ms        kdatacenter.com (South Korea Seoul)
  59. Japan, GLBB                        16.75 MB/s        58.40 MB/s        220.69 ms        Allied Telesis Capital Corporation (Japan Fussa-shi)
  60. Taiwan, FET                        Fail: Timeout Exceeded after 60 seconds
  61. Taiwan, Chief                      Fail: Latency test failed for both TCP, and no HTTP URL available.
  62. Taiwan, TWM                        Fail: Cannot open socket: Timeout occurred in connect.
  63. Singapore, Singtel                 36.50 MB/s        71.90 MB/s        255.42 ms        Singtel (Singapore Singapore)
  64. Singapore, M1                      55.65 MB/s        71.32 MB/s        176.38 ms        M1 Limited (Singapore Singapore)
  65. Singapore, NME                     Fail: Timeout Exceeded after 60 seconds
  66. USA, Century Link                  Fail: Timeout Exceeded after 60 seconds
  67. -> Traceroute Test (IPV4)
  68. Traceroute to China, Beijing CU (TCP Mode, Max 30 Hop)
  69. ============================================================
  70. traceroute to 123.125.99.1 (123.125.99.1), 30 hops max, 32 byte packets
  71. 1  *
  72. 2  45.91.100.4  0.35 ms  AS48314  Germany, Hesse, Frankfurt, ip-projects.de
  73. 3  84.200.7.117  0.44 ms  AS44066  Germany, Hesse, Frankfurt, first-colo.net
  74. 4  212.224.104.22  0.77 ms  AS44066  Germany, Hesse, Frankfurt, first-colo.net
  75. 5  62.115.161.106  0.91 ms  AS1299  Germany, Hesse, Frankfurt, telia.com
  76. 6  *
  77. 7  219.158.14.189  171.01 ms  AS4837  China, Guangdong, Guangzhou, ChinaUnicom
  78. 8  219.158.115.121  247.04 ms  AS4837  China, Beijing, ChinaUnicom
  79. 9  219.158.9.218  251.42 ms  AS4837  China, Beijing, ChinaUnicom
  80. 10  *
  81. 11  *
  82. 12  61.51.169.178  254.56 ms  AS4808  China, Beijing, ChinaUnicom
  83. 13  *
  84. 14  *
  85. 15  *
  86. 16  *
  87. 17  *
  88. 18  *
  89. 19  *
  90. 20  *
  91. 21  *
  92. 22  *
  93. 23  *
  94. 24  *
  95. 25  *
  96. 26  *
  97. 27  *
  98. 28  *
  99. 29  *
  100. 30  *
  101. Traceroute to China, Beijing CT (TCP Mode, Max 30 Hop)
  102. ============================================================
  1. 10 packets transmitted, 10 packets received, 0.0% packet loss
  2. round-trip min/avg/max/stddev = 248.882/268.993/345.192/29.743 ms
  1. 2022-08-20 19:30:56 (1.79 MB/s) - 已保存 “1000MB.bin.1” [1000000000/1000000000])
  1. 2022-08-20 13:17:16 (39.3 MB/s) - ‘nf’ saved [4550656/4550656]
  2. **NetFlix 解锁检测小工具 v3.0 By @sjlleo**
  3. [IPv4]
  4. 您的出口IP完整解锁Netflix,支持非自制剧的观看
  5. NF所识别的IP地域信息:德国
  6. [IPv6]
  7. 您的出口IP完整解锁Netflix,支持非自制剧的观看
  8. NF所识别的IP地域信息:德国
发表于 2022-8-20 21:29:53 来自手机 | 只看该作者
prehosting24那个5欧也行 就是硬盘只有50G
发表于 2022-8-20 21:33:51 来自手机 | 只看该作者
啥时候的优惠?这家很稳定的
 楼主| 发表于 2022-8-20 21:34:52 | 只看该作者
佳辉的春天 发表于 2022-8-20 21:33
啥时候的优惠?这家很稳定的
今天刚买的
发表于 2022-8-20 21:40:12 | 只看该作者
老哥跑一下国内测速脚本呀
  1. bash <(curl -Lso- https://2life.top/speedtest.sh)
发表于 2022-8-20 21:54:48 来自手机 | 只看该作者
南风大叔 发表于 2022-8-20 21:34
今天刚买的
求优惠页面
 楼主| 发表于 2022-8-20 21:58:08 | 只看该作者
https://signaltransmitter.de/en/ssd-kvm-rootserver
发表于 2022-8-20 22:08:10 来自手机 | 只看该作者
加2欧就可以上ne tcup了,硬盘更大带宽更高
发表于 2022-8-20 22:14:29 | 只看该作者
非要说的话 不如netcup 9.4o 而且cpu也不是专用的
发表于 2022-8-20 22:15:44 | 只看该作者
我只能说得分一般,不如别家,当然有地区需求这个还不错
GMT+8, 2026-4-26 09:57 , Processed in 0.071060 second(s), 10 queries , Gzip On, MemCache On.
