查看: 1313|回复: 0
动易数据T楼VPS评测
发表于 2012-2-20 17:35:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
直接上数据,大家自己看
  1. [root@MyVPS ~]# cat /proc/cpuinfo
  2. processor       : 0
  3. vendor_id       : GenuineIntel
  4. cpu family      : 6
  5. model           : 42
  6. model name      : Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
  7. stepping        : 7
  8. cpu MHz         : 3092.972
  9. cache size      : 6144 KB
  10. fdiv_bug        : no
  11. hlt_bug         : no
  12. f00f_bug        : no
  13. coma_bug        : no
  14. fpu             : yes
  15. fpu_exception   : yes
  16. cpuid level     : 13
  17. wp              : yes
  18. flags           : fpu de tsc msr pae cx8 apic cmov pat clflush acpi mmx fxsr sse sse2 ss ht nx constant_tsc up nonstop_tsc pni ssse3 sse4_1 sse4_2 popcnt [8]
  19. bogomips        : 7736.19
  20. [root@MyVPS ~]# free -m
  21.              total       used       free     shared    buffers     cached
  22. Mem:           256        253          3          0         20        182
  23. -/+ buffers/cache:         50        205
  24. Swap:          255          0        255
  25. [root@MyVPS ~]# df -h
  26. Filesystem            Size  Used Avail Use% Mounted on
  27. /dev/mapper/VolGroup00-LogVol00
  28.                       9.3G  1.2G  7.7G  13% /
  29. /dev/xvda1             99M   29M   66M  31% /boot
  30. tmpfs                 129M     0  129M   0% /dev/shm
  31. [root@MyVPS ~]# fdisk -l
  32. Disk /dev/xvda: 10.7 GB, 10737418240 bytes
  33. 255 heads, 63 sectors/track, 1305 cylinders
  34. Units = cylinders of 16065 * 512 = 8225280 bytes
  35.     Device Boot      Start         End      Blocks   Id  System
  36. /dev/xvda1   *           1          13      104391   83  Linux
  37. /dev/xvda2              14        1044     8281507+  8e  Linux LVM
  38. /dev/xvda3            1045        1305     2096482+  8e  Linux LVM
  39. Disk /dev/xvdb: 21.4 GB, 21474836480 bytes
  40. 255 heads, 63 sectors/track, 2610 cylinders
  41. Units = cylinders of 16065 * 512 = 8225280 bytes
  42. Disk /dev/xvdb doesn't contain a valid partition table
  43. [root@MyVPS ~]# vmstat
  44. procs -----------memory---------- ---swap-- -----io---- --system-- -----cpu------
  45. r  b   swpd   free   buff  cache   si   so    bi    bo   in   cs us sy id wa st
  46. 0  0      0   3112  20844 186904    0    0    46    33   23   51  1  1 98  1  0
  47. [root@MyVPS ~]# dd if=/dev/zero of=test bs=64k count=16k conv=fdatasync
  48. 16384+0 records in
  49. 16384+0 records out
  50. 1073741824 bytes (1.1 GB) copied, 15.3009 seconds, 70.2 MB/s
  51. [root@MyVPS ~]# wget cachefly.cachefly.net/100mb.test -O /dev/null
  52. --2012-02-20 09:31:14--  http://cachefly.cachefly.net/100mb.test
  53. Resolving cachefly.cachefly.net... 205.234.175.175
  54. Connecting to cachefly.cachefly.net|205.234.175.175|:80... connected.
  55. HTTP request sent, awaiting response... 200 OK
  56. Length: 104857600 (100M) [application/octet-stream]
  57. Saving to: `/dev/null'
  58. 100%[======================================>] 104,857,600 17.1M/s   in 5.9s
  59. 2012-02-20 09:31:21 (16.9 MB/s) - `/dev/null' saved [104857600/104857600]
GMT+8, 2025-12-25 06:45 , Processed in 0.156846 second(s), 10 queries , Gzip On, MemCache On.
